Biggles Posted April 30, 2012 Report Share Posted April 30, 2012 Is there a wall thickness specification on 15mm copper pipe used in a boat? Ta. Link to comment Share on other sites More sharing options...
mrsmelly Posted April 30, 2012 Report Share Posted April 30, 2012 Is there a wall thickness specification on 15mm copper pipe used in a boat? Ta. 15mm is ok for water pipes but you need good old imperial half inch pipe for your gas supply, it has a thicker wall and is what your boats gas supply should be piped in, not metric stuff. Tim Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 Is there a wall thickness specification on 15mm copper pipe used in a boat? Ta. Usually 8-10mm soft copper pipe is used for gas pipework. Alex Link to comment Share on other sites More sharing options...
RobinJ Posted April 30, 2012 Report Share Posted April 30, 2012 ... it has a thicker wall and is what your boats gas supply should be piped in, not metric stuff ... In fact normal copper used for water is about a tenth of the wall thickness needed for gas! Link to comment Share on other sites More sharing options...
Proper Job Posted April 30, 2012 Report Share Posted April 30, 2012 3/8" and 5/16" gas pipe is the norm. It's usually available from any good Chandlers (along with the fittings). Do not use water pipe. It's a very different beast. Link to comment Share on other sites More sharing options...
dor Posted April 30, 2012 Report Share Posted April 30, 2012 3/8" and 5/16" gas pipe is the norm But you may have flow restrictions depending on appliances. E.g. if you have a gas boiler and a gas oven & hob, it may be better to run the main pipe in 1/2" with 3/8" teed off to the appliances. Link to comment Share on other sites More sharing options...
MtB Posted April 30, 2012 Report Share Posted April 30, 2012 Is there a wall thickness specification on 15mm copper pipe used in a boat? Ta. Yes, its either 1.0 or 1.6mm from memory. Yes, feckin thick and seriously expensive IF you can find it. Correct wall thickness only normally available in imperial sizes. And it has to be annealed copper tube too, don't forget, not the half-hard stuff sold in plumbers' merchants.... Mike Usually 8-10mm soft copper pipe is used for gas pipework. Alex No it isn't. Mike Link to comment Share on other sites More sharing options...
mrsmelly Posted April 30, 2012 Report Share Posted April 30, 2012 Usually 8-10mm soft copper pipe is used for gas pipework. Alex Err Nope it isnt Tim Link to comment Share on other sites More sharing options...
Proper Job Posted April 30, 2012 Report Share Posted April 30, 2012 There's an echo around her somewhere Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 (edited) No it isn't. Mike Eeerr - What are the recommendations then? Alex Edited April 30, 2012 by steelaway Link to comment Share on other sites More sharing options...
dor Posted April 30, 2012 Report Share Posted April 30, 2012 Eeerr - What are the recommendations then? As mentioned above, gas pipe should be 5/16", 3/8" or 1/2". These will have the thicker walls and most chandlers stock the imperial fittings (although I believe you can use 10 mm as a substitute for 5/16" although not recommended). Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 As mentioned above, gas pipe should be 5/16", 3/8" or 1/2". These will have the thicker walls and most chandlers stock the imperial fittings (although I believe you can use 10 mm as a substitute for 5/16" although not recommended). Hi Why should we be using the old fashioned imperial tube? When metric tube is so readily available and 8mm is a direct replacement for 5/16. Alex Link to comment Share on other sites More sharing options...
PaulJ Posted April 30, 2012 Report Share Posted April 30, 2012 10mm is slightly bigger than 3/8 (9.5mm) and some do use it but you really shouldnt mix it.... Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 10mm is slightly bigger than 3/8 (9.5mm) and some do use it but you really shouldnt mix it.... 5/16" is 7.9375mm 10 mm needs 10mm fittings of course Alex Link to comment Share on other sites More sharing options...
alan_fincher Posted April 30, 2012 Report Share Posted April 30, 2012 Why should we be using the old fashioned imperial tube? Because if you do, you will almost certainly be using something that meets all the required standards, whereas this is very much harder to do with metric, particularly as there are unscrupulous chandlers out there prepared to tell you "metric is the way to go these days", but who are actually selling stuff that does not comply. Imperial may be "old fashioned", but is is the proper stuff, IMO, and by far the easiest way of getting things right. Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 Because if you do, you will almost certainly be using something that meets all the required standards, whereas this is very much harder to do with metric, particularly as there are unscrupulous chandlers out there prepared to tell you "metric is the way to go these days", but who are actually selling stuff that does not comply. Imperial may be "old fashioned", but is is the proper stuff, IMO, and by far the easiest way of getting things right. Were these rules on 'getting things right' written pre-second world war or shortly after? Can any one point me to the latest gas pipe requirements, I have a feeling there are many post war boats out there - 'wrongly' piped . Alex Link to comment Share on other sites More sharing options...
mrsmelly Posted April 30, 2012 Report Share Posted April 30, 2012 Were these rules on 'getting things right' written pre-second world war or shortly after? Can any one point me to the latest gas pipe requirements, I have a feeling there are many post war boats out there - 'wrongly' piped . Alex Hi ocasionaly we all get things wrong and on this occasion you are wrong. Imperial may be old fashioned but it is superior quality and CORRECT for gas. If you wish to measure in foreign European measurements do so but let the rest of us Brits use proper imperial.....I always do Tim Link to comment Share on other sites More sharing options...
the grinch Posted April 30, 2012 Report Share Posted April 30, 2012 (edited) 0.8 wall for pipes under 12mm and 1.5 wall for pipes over 12 mm solid drawn copper or drawn stainless steel copper must comply with BS EN 1057 Stainless to BS 6362 aluminium,lead,brass tubing,steel tubing and plastics are NOT SUITABLE materials Alex - further reading PD 5482-3 (2005) Edited April 30, 2012 by hamsterfan Link to comment Share on other sites More sharing options...
Biggles Posted April 30, 2012 Author Report Share Posted April 30, 2012 (edited) copper must comply with BS EN 1057 So is this standad stock in a plumbers merchants? Edited April 30, 2012 by Biggles Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 Hi ocasionaly we all get things wrong and on this occasion you are wrong. Imperial may be old fashioned but it is superior quality and CORRECT for gas. If you wish to measure in foreign European measurements do so but let the rest of us Brits use proper imperial.....I always do Tim Hi I'm the last person to want to be pedantic, but why is imperial CORRECT for gas and metric isn't? Gas is even measured in cubic METRES! I can understand people with vintage boats wanting to maintain correctness but not us average boaters. How come the imperial pipe size is better ---- Oh I see ! - OK, yes you're right good old British Imperial is best Having spent a life time trying to forget what we were taught in school in the 50's, I can almost understand both. I now measure any thing above an inch in feet and inches and anything less in mm. (I cant be doing with 13/64" etc.) Alex Link to comment Share on other sites More sharing options...
the grinch Posted April 30, 2012 Report Share Posted April 30, 2012 (edited) no standard tube is lower grade (cheap shite!!) you would need to specify, easier to buy from someone like BES -bes link codes 8893 1/4" 8894 5/16" 8895 3/8" 8896 1/2" Edited April 30, 2012 by hamsterfan Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 30, 2012 Report Share Posted April 30, 2012 Hi I'm the last person to want to be pedantic, but why is imperial CORRECT for gas and metric isn't? Gas is even measured in cubic METRES! I can understand people with vintage boats wanting to maintain correctness but not us average boaters. How come the imperial pipe size is better ---- Oh I see ! - OK, yes you're right good old British Imperial is best Having spent a life time trying to forget what we were taught in school in the 50's, I can almost understand both. I now measure any thing above an inch in feet and inches and anything less in mm. (I cant be doing with 13/64" etc.) Alex Don't do any plumbing then. The pipe might be 15 mm but the taps are still 1/2" Link to comment Share on other sites More sharing options...
Biggles Posted April 30, 2012 Author Report Share Posted April 30, 2012 no standard tube is lower grade (cheap shite!!) you would need to specify, easier to buy from someone like BES Right thanks Link to comment Share on other sites More sharing options...
steelaway Posted April 30, 2012 Report Share Posted April 30, 2012 no standard tube is lower grade (cheap shite!!) you would need to specify, easier to buy from someone like BES Even though it is compressed air pipe that will happily handle 200psi? What's gas pressure - 8psi? Don't do any plumbing then. The pipe might be 15 mm but the taps are still 1/2" Are they really, never noticed. They all seem to fit metric tube. Alex Link to comment Share on other sites More sharing options...
the grinch Posted April 30, 2012 Report Share Posted April 30, 2012 Even though it is compressed air pipe that will happily handle 200psi? What's gas pressure - 8psi? its the hardness / wall thickness that varies Link to comment Share on other sites More sharing options...
