David Schweizer Posted December 1, 2011 Report Share Posted December 1, 2011 I am planning to replace the wooden board on our aluminium ladder gang plank with a long sheet of aluminium chequer plate, the only thing is that the plate comes in thicknesses between 1.5mm and 5mm, and I do not know what thickness I should order I have seen quite a few aluminium chequer plate/ladder gang planks around over the years, and wondered if anyone with one could measure theirs to give an idea of the thickness, I understand that the stock thickness is based upon the flat cross section and not the raised chequers. Link to comment Share on other sites More sharing options...
Ally Posted December 1, 2011 Report Share Posted December 1, 2011 The aluminium plank/ladder that Miracle leisure do has 2mm thick chequer plate. Any help? Link to comment Share on other sites More sharing options...
blackrose Posted December 1, 2011 Report Share Posted December 1, 2011 (edited) Aluminium checker plate (chequer plate) isn't actually that grippy in the wet. Is it the ideal material for a boarding plank? I guess it depends what sort of sole your shoes have. Edited December 1, 2011 by blackrose Link to comment Share on other sites More sharing options...
Taslim Posted December 1, 2011 Report Share Posted December 1, 2011 I am planning to replace the wooden board on our aluminium ladder gang plank with a long sheet of aluminium chequer plate, the only thing is that the plate comes in thicknesses between 1.5mm and 5mm, and I do not know what thickness I should order I have seen quite a few aluminium chequer plate/ladder gang planks around over the years, and wondered if anyone with one could measure theirs to give an idea of the thickness, I understand that the stock thickness is based upon the flat cross section and not the raised chequers. Yes, thickness measured on the plate. Assuming you have rung supports at about 30cm (12") intervals I would go for 3mm especially if you need to put motorbikes or guests over 12 stone on board on a regular basis. Link to comment Share on other sites More sharing options...
cereal tiller Posted December 1, 2011 Report Share Posted December 1, 2011 Aluminium checker plate (chequer plate) isn't actually that grippy in the wet. Is it the ideal material for a boarding plank? I guess it depends what sort of sole your shoes have. Agreed,chequer plate is slippery when wet. easiest way to make a gangplank is to use an aluminium ladder with timber "decking" planks screwed to it. Link to comment Share on other sites More sharing options...
David Schweizer Posted December 1, 2011 Author Report Share Posted December 1, 2011 (edited) Agreed,chequer plate is slippery when wet. easiest way to make a gangplank is to use an aluminium ladder with timber "decking" planks screwed to it. That is what we have got at the moment! It is so heavy, I cannot get it off the roof without straining myself, it is 8ft long and the timber is 7/8" thick pine coated with non slip paint. As it happens, I find that brown decking board with little hexagons on it is also slippery when wet, and it is very heavy. Edited December 1, 2011 by David Schweizer Link to comment Share on other sites More sharing options...
cereal tiller Posted December 1, 2011 Report Share Posted December 1, 2011 That is what we have got at the moment! It is so heavy, I cannot get it off the roof without straining myself, it is 8ft long and the timber is 7/8" thick pine coated with non slip paint. As it happens, I find that brown decking board with little hexagons on it is also slippery when wet, and it is very heavy. The decking is a fair bit lighter than the 7/8 pine. i suppose you could spend a spare hour or two drilling 3/4 holes in the boards,i fully intend to modify my plank using that method. Asoon as i get one of those round tuit thingys! Link to comment Share on other sites More sharing options...
WotEver Posted December 1, 2011 Report Share Posted December 1, 2011 Asoon as i get one of those round tuit thingys! If you find a supplier, would you drop me a PM please. Link to comment Share on other sites More sharing options...
Rebotco Posted December 1, 2011 Report Share Posted December 1, 2011 If you find a supplier, would you drop me a PM please. I had one of those - but I lost it about 20 years ago !! Brian Link to comment Share on other sites More sharing options...
David Schweizer Posted December 1, 2011 Author Report Share Posted December 1, 2011 (edited) The decking is a fair bit lighter than the 7/8 pine. i suppose you could spend a spare hour or two drilling 3/4 holes in the boards,i fully intend to modify my plank using that method. Asoon as i get one of those round tuit thingys! I would urge caution with that approach, as too many holes will compromise the board's integrity. The last thing you want is to loose Granny by putting her foot through it! Edited December 1, 2011 by David Schweizer Link to comment Share on other sites More sharing options...
14skipper Posted December 1, 2011 Report Share Posted December 1, 2011 When l made mine l used 3mm sheet,that l got from a caravan/mobile home step manufacturer. 14skipper Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 1, 2011 Report Share Posted December 1, 2011 Agreed,chequer plate is slippery when wet. easiest way to make a gangplank is to use an aluminium ladder with timber "decking" planks screwed to it. Maybe you should also consider this tape from Screwfix Link to comment Share on other sites More sharing options...
WJM Posted December 1, 2011 Report Share Posted December 1, 2011 Put a very short loop of rope on one end and you have a dual purpose device - an very effective man-over-board ladder to hook onto the mooring stud. Link to comment Share on other sites More sharing options...
Rebotco Posted December 1, 2011 Report Share Posted December 1, 2011 Maybe you should also consider this tape from Screwfix Had A look at this. The sales blurb doesn't say anything, but the "review" says its no good for outdoor use. Brian Link to comment Share on other sites More sharing options...
smileypete Posted December 1, 2011 Report Share Posted December 1, 2011 (edited) I am planning to replace the wooden board on our aluminium ladder gang plank with a long sheet of aluminium chequer plate, the only thing is that the plate comes in thicknesses between 1.5mm and 5mm, and I do not know what thickness I should order I have seen quite a few aluminium chequer plate/ladder gang planks around over the years, and wondered if anyone with one could measure theirs to give an idea of the thickness, I understand that the stock thickness is based upon the flat cross section and not the raised chequers. Try this Ebay seller, might be able to supply something suitable. Or if you can use the above, do a search for 'waffle boards' on Ebay/online. cheers, Pete. Edited December 1, 2011 by smileypete Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 1, 2011 Report Share Posted December 1, 2011 Had A look at this. The sales blurb doesn't say anything, but the "review" says its no good for outdoor use. Brian I bought a reel of similar stuff from Betterware about 2 years ago. I put a piece about an inch long on top of our wheelie bin that stands out in all weathers and there is still no way I can peel it off. I still have not used the rest and can't remember what I bought it for. True I have never tested Screwfix tape but I was assuming (bad thing to do) it would be the same. Link to comment Share on other sites More sharing options...
Rebotco Posted December 1, 2011 Report Share Posted December 1, 2011 I bought a reel of similar stuff from Betterware about 2 years ago. I put a piece about an inch long on top of our wheelie bin that stands out in all weathers and there is still no way I can peel it off. I still have not used the rest and can't remember what I bought it for. True I have never tested Screwfix tape but I was assuming (bad thing to do) it would be the same. Depends on the type of adhesive I expect. Must say Betterware stuff usually is pretty good. Brian Link to comment Share on other sites More sharing options...
The Pipe Posted December 1, 2011 Report Share Posted December 1, 2011 Or you could use expanded metal mesh. http://www.perforated-wire-mesh.com/expanded-metal-products.asp?sub=1 Link to comment Share on other sites More sharing options...
Biggles Posted December 1, 2011 Report Share Posted December 1, 2011 Try this Ebay seller, might be able to supply something suitable. Or if you can use the above, do a search for 'waffle boards' on Ebay/online. cheers, Pete. These people are quite near to me and I have been there to see the stuff. It is very grippy, all their stuff is. Link to comment Share on other sites More sharing options...
