2 cylinder semi diesel bolinder
Speedwheel
I'm pretty convinced that there is no pump based reversing:-
There is no lever to control the friction wedges,
There is no push rod from where the friction wedges would be to the
table attachment "bell crank",
There is no "pecker" on the "back pump" end of the injector bell crank
(at least on the outer pump anyway). Although all the components that
are there look to be standard i.e. as if it did have pump reversing.
It is difficult to tell but I dont think there is a "Table" for the back pump or
even a "Back Pump" itself - the pump main body casting is looks standard but
probably just has a bung in the threaded hole where the "back pump"
body and plunger would be.
springy
All of which is consistent with the engine having been built with pump reversing, but having that facility removed when the useage was changed.
I've tweaked the picture a bit to make the pump parts a bit more visible, & it seems pretty clear that some of the parts you list have been removed
I've got an old book with a couple of pages which describe the reversing mechanism quite well, I can scan and post them here if there's an appetite from those who haven't a clue what we're on about? It's probably out of copyright by now.
Tim
<snip> Is it true that semi-diesels can run on such weird fuels as creosote and old engine oil?
Mac
Bolinders were sold as a "Crude Oil Engine" and certainly the larger seagoing engines would
have had "Fuel Preheating" coils in the exhaust allowing them to run on "Heavy Fuel Oil" - often
known as Bunker Fuel - much longer chain fractions of crude oil and much thicker than Diesel.
AFAIK on the canals they were always run on "Gas Oil" (Diesel) which is usually just refered to as
Oil. Lubrication for engine is "Green Oil".
They probably would run on creosote and old engine oil but I'd be very wary particularly of the
effect on the injector pumps, but also on the spindle (adjustable injector).
springy
springy
I seem to remember reading somewhere that in Scandinavia 'Crude oil' has a particular meaning and is not just any old black stuff pumped out of the ground. Anyone know for certain?
Tim
Which book is it Tim?
'Marine Diesel Oil Engine Practice' by Sothern & Bowden
Tim
Edit - who's that slim, stylish handsome young man?
I'll try to find the reverse picture later :lol:
Tim
Edited by Timleech
<snip>
Tim
Yes please
Richard
Tim
I'd be interested too - I've just been looking at some pages in one of the manuals (downloaded from
internal fire) and it seems that the twins had "coordinated fuel pumps" a mechanism which ensured that
each pump operated the same number of times - if the front cylinder pump was a "miss" then the rear
cylinder pump would also be a "miss", and that if the front cylinder pump was a "hit" then the next
firing stroke would be the rear cylinder (though not necessarily the next stroke). These engines
had a separate "Back Pump" (or at least some of them did - it's not that clear). The photos in
the manual however seem to show a standard setup with back pump, table and pecker as per
the singles ?
springy
the singles ?
springy
That description sounds familiar, probably a similar manual to the one I have.
Here are links to the book pages:-
http://i559.photobucket.com/albums/ss38/Ti.../image0-4-1.jpg
http://i559.photobucket.com/albums/ss38/Ti...09/image1-2.jpg
and a couple of pics for Satellite:-
Not brilliant pics, but options are a bit limited from the bottom of the lock :lol:
Tim
Thanks Tim, I've never had hands on, or even close inspection of Bolinder semi-diesel workings. Hit and miss I've seen at shows often enough, but not Bolinders.
In that photo of the twin, the engine beds look to have holes in where a reversing lever might have once been (just a guess), and whilst there appears to be no rod from a reversing mechanism (also removed?), there looks to be an addition just left of the front pump rocker, in the form of a small hand lever in a quadrant. Throttle setting? Which might indicate a change from a direct reversing engine, to a pump engine with set throttle and no need for reversing - hence removed reversing tackle. (Though the holes could have been there from the start, without any reversing gear fitted from day one).
The valve on the side of the back cylinder does indeed look like and air valve for starting.
Would I be correct in thinking the twin had a 180° crankshaft throw? In which case I would suspect hand or foot starting would be somewhat difficult (though not impossible if your names Hercules!) as bouncing one piston on compression would be bouncing the other against crankcase pressure. Twice the effort needed, counting in the extra friction from moving parts.
Brilliant stuff. Looks like ex-tug engine turned pump engine, with a possible boat and location (all unconfirmed so far).
Which Tug were you standing on?
Trent, or Weaver - I've been on one not the other. Effluent says Trent.
Derek.
Edited by Derek R.
Empress, Cactus and... ?
Dory
Derek.
Kennet
Vale Royal Locks, R.Weaver
Tim
Edited by Timleech
<snip>
Derek.
There are two hand levers on quadrants - the lower one operates the air flap in the transfer
port - used to reduce the charge of air into the cylinder - this helps to keep the engine hot
enough when running light or just on tickover for long periods. The upper one (which I think
you are refering to) seems to be variously known as the pump rack or bracket rack. I have
A Bolinders Manual which refers to it as the "No Miss Handle" - it adjusts the Pump Stroke
and hence the amount of fuel fed into the engine on each firing stroke, - this is not adjustable
(usually) from the steering position & generally, as I understand it, it is usually set 5 - 8 notches
down & left there. It is of more use on seagoing vessels as you can "fine tune" the running
of the engine so that it hits every beat and so runs smoother & on the least amount of fuel
- useful if you are going to be on "full chat" for several hours. The engine speed is set using
the circular brass control with a handle, which is on top of the pump assembly - this increases
the pressure on the hit & miss governor spring & hence forces the pumps to strike more
often.
All the above are standard on all bolinders except the Pup (9HP) and smaller (I think)
which do not have the air flap in the transfer port.
springy
Thanks Tim.
Kennet - not jealous at all.
Built originally with a 3-cyl 2-stroke direct reversing Gardner. Full diesel, not semi-diesel though.
There's one the same model at Ellesmere Port, do you think anyone would notice if I 'borrowed' it :lol:
Tim
I very much doubt they would notice Tim.
Smoking competition below. 2 Bolinders, an Armstrong and an underworked Kelvin.
Back on topic - restoration project.
All joking aside is that egine liable to be up for grabs.... :lol: and nice passive smoking potential among those boats, wonderful
Edited by soldthehouse
Tim
That is a really nice boat - although I think the white smoke is more than likely unburnt oil - perhaps lubricating oil coming down the valve guides? Good image though - makes it look like a steamer!
