16 minutes ago, XLD said:
Can someone explain what the difference is if they both deliver the same litres per minute?
Bar is only the cut-out pressure, there should also be litres or gallons per minute in the specifications. That is what you want to look at for a comparison of delivery volume. So the same litres per minute give the same delivery volume. The difference is the 3 bar pump might require a new PRV on the calorifier or its cut out pressure adjusting downwards to 2 bar. Unless adjusted down, it could cause a plumbing leak. Running a tap into the bathroom hand basin is more likely to get you an embarrassing wet patch on your trousers (depending upon bowl design).
So the pressure in the pipework is higher and more suseptable to leakage?
To get the same flow rate (ie lts per minute) the 3 bar system must be using a smaller dimeter pipe than the 2 bar.
Its like water coming out of a hose, it runs out at a reasonable rate, but , the jet doesn't go very far.
Put your finger over the end to reduce the pipe size and you get the same flow rate but the jet goes further as it is at a higher pressure.
Its a bit like 'watts are fixed', but voltage and amps can vary, so
W=A x V
W = A/2 x 2V
etc
Flow rate in units of litres/minute is different from pressure in bar or psi. So you can buy a pump that produces the same flow rate at different pressures.
I changed my Parmax 25psi pump a couple of years ago to a Parmax 40psi pump in an attempt to get my instant gas water heater to work properly. Both pumps had exactly the same flow rate which from memory was 13 litres/min.
A few of the usual suspects here said what I was proposing wouldn't work because what I needed was a higher flow rate pump, not higher pressure. I fitted the pump anyway because I'd already bought it some months earlier it was too late to return it. The water heater worked perfectly!
When I mentioned the result on the forum one of them said "Well the higher pressure has resulted in a higher flow rate", completely contradicting what he'd said previously! 😂 There is a lot of expertise on the forum but despite a high level of certainty we don't know everything.
Only if your plumbing is cr@p.
  • Love 1
Or different volume pumping chambers, but I suspect the chambers are all the same size, and it is just the cut-out pressure that has been set higher with possibly a more powerful motor. I bet the flow rate is measured at the pump outlet into zero pressure.
Do you have a calorifier in your water system? If so, what is its maximum working pressure and what value pressure relief valve is fitted? The pump cut out pressure needs to be below the max working pressure and also slightly below the PRV pressure. The PRV, needless to say, also needs to be below the cauliflower safe working pressure.
Only if the pipework is really rubbish. In competently installed plumbing it will make no difference, but see cauliflower above. For comparison, typical mains pressure from the pipe coming in to most homes is around 6 bar and that only leaks if there is a problem.
When a tap is open, the pressure isn't 3 bar (or 2 bar), its just the pressure/head needed to get the water through the relevant length of pipework, around its bends, and up to the tap. Its going to be in the region of 0.1 bar. So, they'll both flow at their near maximum flowrate.
A higher flowrate pump needs more power (but it will be the same energy from the battery.........because the same amount of work is being done, its just quicker) so in theory thicker wires, etc so you can't just swap out a low flowrate pump for a super high one. But if you can, then I'd always recommend a higher flowrate - its just nicer to use, instead of waiting and waiting for water to flow eg into a bucket or basin.
Also the headline flow rate quoted by the manufacturer is flow with it not actually connected to any downstream plumbing. The resistance from the pipe, fittings, bends and so on reduce it considerably. For example, on my boat, I get 6l/min at the taps from a pump that is supposed to deliver 11l/min. Shorter distances, bigger diameter pipes, fewer fittings and bends would all improve the flow rate to closer to the official figure.
Analogy :
Remember when you were young and won all the 'highest peeing up the wall' competitions - that was a 3 bar pump
Now you are old  and having to take care you don't pee on your feet - that is a 2 bar pump
13 hours ago, Alan de Enfield said:
Analogy :
2 Bar?  2 Bar??
I can only dream of 2 Bar!
Right. I have a 2 bar pump on my hot water system and  a 2 bar pump on my coldwater system. (so if one packs in l dont lose the whole water supply).
What happens if l replace  one with a 3 bar pump. Thinking of the mixer shower.
Serious answers only please
The 3 bar will probably achieve a higher percentage of the nominal flowrate in its specification, all else being equal. So you'd need to make some kind of adjustment on the mixer shower, with the mixer control you already have.
But as stated before, it won't ACTUALLY be anywhere near 3 bar (or 2 bar) the pump is pressurising the water to, it will be in the order of 0.1-0.5 bar as determined by the pipework inner diameter, length, number of bends/fittings etc and how much open the tap/flow control lever of the shower is.
The 2 and 3 bar specifications are the peak pressures the pumps can generate pumping against a closed tap or capped pipe. So of no particular use or interest when assessing the likely performance of the pump through an open pipe or open tap. For this, you need to look up and compare the maximum flow rate the pumps can deliver.
The static pressure is something only marketing departments obsess over. No-one knows why.
If you have a calorifier the 2 bar pump is more appropriate as the PRV is probably 3 bar opening pressure, so you don't want the static pressure in the system rising that high, or anything even close.
Marketing departments love big numbers, the bigger the better!
They do this with diesel engines generators. They always quote kVA rather than kW.
Now a well matched diesel engined generator set will have a diesel engine that can only deliver enough mechanical power to turn an alternator at its rated output
So for a 1000kVA  generating set, rated at 0.8 power factor, it will deliver a maximum of 800kVA. Improve the power factor to unity and it will still only deliver 800kVA because that is the maximum power the engine can deliver (unless the generator set has been specified at a continuous or "sprint"rating in which case it can deliver a bit more than its rated power for a specified limited time).
However the bigger numbers look more impressive.
  • 2 months later...
In trying to work out which pump I need to provide a good shower, I had grasped the importance of the Calorifier's PRV.
Finding that PRVs of 44 psi and pumps rated at 40 psi were quite common, I thought that I was on the right track, until I found that my ATI Calorifier's PRV is rated at 116 psi (8 bar).
Therefore, presumably I need to consider what the maximum capability of my plumbing system is instead? 🤔
8 Bar? That's almost unheard of!
On household systems there is usually a T&PRV set to 6 or 8 Bar in addition to the 3 Bar PRV. It is as a backup if the PRV jams shut or fails to work. I'd doble check if I were you that is the correct PRV.
But for shower performance you should be more concerned with the flow rate of your pump than with the peak pressure pressure it switches off at.
Edited by MtB
Speeling.
Thanks.
Yes I did query it, thinking typo' for a 3, but the supplier confirmed 8 bar.
https://penguineng.com/content/ATI_calorifier_BTrange2.pdf
The system is usual push fit so I' m not thinking of going more than 45(?) psi anyway.
Yes I'm looking at flow rates, but higher ones often take psi well over 45 bearing in mind what the system can do.
I wondered about having a dedicated shower pump but haven't figured how.....plus I'm conscious of water usage vs storage capacity.
Are you aware that the cut-out pressure is usually adjustable, or in the rare instances of it being fixed, an external pressures which will allow you to adjust the cut in AND cut out pressures? Adjusting the cut-out pressure should not make much difference to the flow rate because that is often governed by the volume that can get out of the tap/shower in a given time.
This pump (they do a range) and there are other makers may be of interest
https://www.awardrv.com.au/shurflo-4048-12v-rv-high-flow-fresh-water-pump
Used in RVs Caravans etc it can deliver high flow of 18l/min at up to 3.8 Bar (adjustable pressure)   what flow you can actually achieve will  be limited by pipe dia.  length, bends etc rather than the pump itself.
Note it can will draw up to 10Amps power
Pendant alert!
This is technically incorrect, and saying such things may misinform others and open your wallet for picking by unscrupulous people you
 might employ by telling them you have gaps in your knowledge ready for exploiting.
Amps is a measurement of current, power is measured in Watts, so at a nominal 12V the pump's power rating in 120 Watts and its current rating is 10 amps, so 10 amps current.
