Annie cariad Posted March 29 Report Share Posted March 29 Smoke has started to sleep out of the secondary damper at the rear of the stove for no apparent reason when the ash pan door is open. It's in the closed position and rarely used. Has a seal gone inside or.....?? Link to comment Share on other sites More sharing options...
rusty69 Posted March 29 Report Share Posted March 29 (edited) If you mean the flap at the back (top left looking from the rear), I'm sure ours hasn't got a seal.It's just a round disk operated by a lever that covers/uncovers the hole in the rear of the stove and provides an airwash system for the glass. Are you sure your baffle plate/backboiler, flue and glass are clean? ETA. I spose its possible you have a hole/crack in the ducting (air conductor) that feeds the air to the glass that is venting smoke. Edited March 29 by rusty69 Edited to attach some pics. Link to comment Share on other sites More sharing options...
mrsmelly Posted March 29 Report Share Posted March 29 Is you flue partially blocked? Crud can easily and quickly build up on the flat throat plate for instance. I suggest let fire go out and remove it for a proper look. Blockages force smoke and fumes out anywhere possible. 1 Link to comment Share on other sites More sharing options...
David Mack Posted March 29 Report Share Posted March 29 Not enough draw from the, flue which is probably due to it being partially blocked. Give the pipe a good sweeping and check for any debris on the baffle plate. Link to comment Share on other sites More sharing options...
Arthur Marshall Posted March 29 Report Share Posted March 29 I never keep the baffle plate in place. It's fine for a house with a proper chimbley, but a trap for debris and gunk in a boat, as well as cutting the draw which is never enough on a boat anyway. Link to comment Share on other sites More sharing options...
beerbeerbeerbeerbeer Posted March 29 Report Share Posted March 29 19 minutes ago, Arthur Marshall said: I never keep the baffle plate in place. It's fine for a house with a proper chimbley, but a trap for debris and gunk in a boat, as well as cutting the draw which is never enough on a boat anyway. I’ll try taking mine out and see, Im convinced it draws better with the baffle, but willing to try, does it still keep the glass clean(ish)? I think the draft being drawn up in front of the glass is supposed to help keep it clean 🤷♀️ Link to comment Share on other sites More sharing options...
MtB Posted March 29 Report Share Posted March 29 (edited) 5 hours ago, rusty69 said: Baffling. I'm certain my ol' Squirrel didn't have anything like that inside when it fell to bits. Edited March 29 by MtB Link to comment Share on other sites More sharing options...
Tracy D'arth Posted March 29 Report Share Posted March 29 6 minutes ago, beerbeerbeerbeerbeer said: I’ll try taking mine out and see, Im convinced it draws better with the baffle, but willing to try, does it still keep the glass clean(ish)? I think the draft being drawn up in front of the glass is supposed to help keep it clean 🤷♀️ Its not the baffle on the upper door over the air inlet but the baffle under the flue in the top of the combustion chamber that needs to be removed. Link to comment Share on other sites More sharing options...
beerbeerbeerbeerbeer Posted March 29 Report Share Posted March 29 12 minutes ago, Tracy D'arth said: Its not the baffle on the upper door over the air inlet but the baffle under the flue in the top of the combustion chamber that needs to be removed. Yea I understand which baffle he’s on about, but with what you’ve said then Ive misunderstood how draft keeps the glass clean. I thought it was a combination of the two baffles working together Link to comment Share on other sites More sharing options...
Tracy D'arth Posted March 29 Report Share Posted March 29 The baffle on the door is supposed to keep the glass cleaner because it causes a down flow of cold air on the inside of the glass deflecting the smoke away from the glass surface. It only works to any extent if the top door vent is substantially open. Link to comment Share on other sites More sharing options...
beerbeerbeerbeerbeer Posted March 29 Report Share Posted March 29 28 minutes ago, Tracy D'arth said: The baffle on the door is supposed to keep the glass cleaner because it causes a down flow of cold air on the inside of the glass deflecting the smoke away from the glass surface. It only works to any extent if the top door vent is substantially open. Right ok, my vent is seized open, my problem is going to be replacing the fire brick inside, but that’s a question for another day. Link to comment Share on other sites More sharing options...
matty40s Posted April 1 Report Share Posted April 1 Anyhow, nowt to do with his stove, but I think @Annie cariad might feel better with a tot of this stuff... Link to comment Share on other sites More sharing options...
Annie cariad Posted April 1 Author Report Share Posted April 1 Bi Eck lad get me a big one in with a lemonade top ....... Link to comment Share on other sites More sharing options...
matty40s Posted April 2 Report Share Posted April 2 Link to comment Share on other sites More sharing options...
