christophert Posted February 14, 2021 Report Posted February 14, 2021 Evening to you all, My Shoreline fridge is playing up so I need to buy a new one. Due to the extortionate price I want to look at alternatives. Does anyone know what a CRX fridge is? Or what the CRX stands for? Regards, Chris
nicknorman Posted February 14, 2021 Report Posted February 14, 2021 (edited) As far as I know, CRX is a range of fridges made by Dometic. I don’t think CRX stands for anything in particular. Have a look on the Dometic website https://www.dometic.com/en-gb/uk/products/food-and-beverage/fridges/boat-fridges Their reputation seems to be quite good, but not cheap. Inlander is another manufacturer, but again not cheap https://inlanderlowvoltage.com Edited February 14, 2021 by nicknorman
christophert Posted February 14, 2021 Author Report Posted February 14, 2021 Thank you, I'll take a look. Fridges for narrow boats are so expensive
Richard10002 Posted February 14, 2021 Report Posted February 14, 2021 Whichever way you look at it, a small 12v fridge is the best part of give hundred quid. CRX is a Waeco/Dometic model. If you have space for a 240v fridge and an inverter that you can run 24/7, a 240v fridge could be an answer. Unfortunately I don't have space and had a crap inverter from Sterling when I bought a new fridge a couple of months ago.
nicknorman Posted February 14, 2021 Report Posted February 14, 2021 22 minutes ago, christophert said: Thank you, I'll take a look. Fridges for narrow boats are so expensive Yes, 12v ones are! Maybe you should look into getting yours repaired?
Alan de Enfield Posted February 14, 2021 Report Posted February 14, 2021 (edited) I have a Waeco CR80 fridge (the CRX is the more recent model) Excellent fridge and uses ~30Ah per day, it does not like low voltage so ensure your wiring is 'heavy enough' Not cheap but quality costs. Edited February 14, 2021 by Alan de Enfield
JamesWoolcock Posted February 14, 2021 Report Posted February 14, 2021 6 minutes ago, nicknorman said: Yes, 12v ones are! Maybe you should look into getting yours repaired? When my Shoreline failed when just a few years old, I rang Shoreline and they suggested I replaced the controller, a small black box on the back. About 60quid I think. They were very helpful and got one to the Crick Show the following day which was brought back by a friend and fitted in minutes. Hoping not to tempt providence, it's worked perfectly ever since, over 10 years. 1
christophert Posted February 14, 2021 Author Report Posted February 14, 2021 This could be the issue with mine. There's no leaks and interior light is working so it's getting power.
JamesWoolcock Posted February 14, 2021 Report Posted February 14, 2021 4 minutes ago, christophert said: This could be the issue with mine. There's no leaks and interior light is working so it's getting power. Well give 'em a ring. Just the cost of a call, and maybe a black box, but shed loads less than a new one. 1
LadyG Posted February 15, 2021 Report Posted February 15, 2021 Plus the £30 for disposal and in my case, the fridge, ancient , is fitted into the boat, so needs two strong guys to lift it out. I find it does surprisingly well in winter for storage, door keft ajar.
Tony Brooks Posted February 15, 2021 Report Posted February 15, 2021 (edited) Make sure its not simply cutting out (as its designed to do) on low voltage. It should produce a series of beeps or light flashes to help diagnose the fault. As Alan says undersized fridge wiring is very common on canal boats and the makes the fridge think the batters are flat - especially in such cold weather when battery performance will be depressed anyway. "Playing up" is not very descriptive of the symptoms. Edited February 15, 2021 by Tony Brooks 1
Naughty Cal Posted February 15, 2021 Report Posted February 15, 2021 9 hours ago, christophert said: Evening to you all, My Shoreline fridge is playing up so I need to buy a new one. Due to the extortionate price I want to look at alternatives. Does anyone know what a CRX fridge is? Or what the CRX stands for? Regards, Chris We have the CRX 50 on our boat. Not the cheapest fridge by any means but it uses very little power and is very quiet.
Alan de Enfield Posted February 15, 2021 Report Posted February 15, 2021 31 minutes ago, Naughty Cal said: We have the CRX 50 on our boat. Not the cheapest fridge by any means but it uses very little power and is very quiet. You have a boat ?
Naughty Cal Posted February 15, 2021 Report Posted February 15, 2021 3 minutes ago, Alan de Enfield said: You have a boat ? Until the 25th yes 1
christophert Posted February 15, 2021 Author Report Posted February 15, 2021 Yes, a narrow boat. Too true. The door is looking scabby but I'm sure I can tidy that up
christophert Posted February 17, 2021 Author Report Posted February 17, 2021 On 15/02/2021 at 07:15, Tony Brooks said: Make sure its not simply cutting out (as its designed to do) on low voltage. It should produce a series of beeps or light flashes to help diagnose the fault. As Alan says undersized fridge wiring is very common on canal boats and the makes the fridge think the batters are flat - especially in such cold weather when battery performance will be depressed anyway. "Playing up" is not very descriptive of the symptoms. No light flashes, it's just not freezing but it does have power going to it interior light is on. I have had the fridge several years now so I wouldn't put it down to undersized wiring as it's always been fine.
Alan de Enfield Posted February 17, 2021 Report Posted February 17, 2021 39 minutes ago, christophert said: No light flashes, it's just not freezing but it does have power going to it interior light is on. I have had the fridge several years now so I wouldn't put it down to undersized wiring as it's always been fine. My boat had a 12v fridge that 'worked fine' but was very thirsty (in leccy usage). I bought a new fridge and whilst plugged into the land line with the battery charger on everything was fine, go for a days cruise and everything was fine. By the next morning the freezer compartment was defrosted and everything in the fridge was 'wet'. Long story short. Voltage was high enough when on the battery charger, it was high enough when the engine was running but it was the case that the volt drop on the cable was being masked by the high charging voltages. When it was just drawing from the batteries the volt drop was such that even tho' the compressor was running continuously it would not cool the fridge. Changed the wiring for (from memory) 10mm2 and problem went away.
christophert Posted February 17, 2021 Author Report Posted February 17, 2021 2 minutes ago, Alan de Enfield said: My boat had a 12v fridge that 'worked fine' but was very thirsty (in leccy usage). I bought a new fridge and whilst plugged into the land line with the battery charger on everything was fine, go for a days cruise and everything was fine. By the next morning the freezer compartment was defrosted and everything in the fridge was 'wet'. Long story short. Voltage was high enough when on the battery charger, it was high enough when the engine was running but it was the case that the volt drop on the cable was being masked by the high charging voltages. When it was just drawing from the batteries the volt drop was such that even tho' the compressor was running continuously it would not cool the fridge. Changed the wiring for (from memory) 10mm2 and problem went away. I'm in a mariner but have taken on board your point. We have had some very cold weather which will affect any battery. It seems to be working again now, though I have it on its highest setting, the freezer box isn't brilliant. Not complaining too much, as at least now it's working ... sort of. 1
David Mack Posted February 18, 2021 Report Posted February 18, 2021 2 hours ago, christophert said: No light flashes, it's just not freezing but it does have power going to it interior light is on. I have had the fridge several years now so I wouldn't put it down to undersized wiring as it's always been fine. Maybe it needs regassing.
