Tuscan
Everything posted by Tuscan
  1. Unballasted was fun on a windy day. On the Nene exiting a lock in a storm with very little way on we were blown round completely. Now converted and ballasted its no longer a problem
  2. Looks like a deliberate petulant (and dangerous) act to me.
  3. Can you not get a tradesman to buy from Howdens on your behalf, that’s what a colleague did.
  4. this is definitely the case in my recent experience
  5. We looked at Wigrams but chose Nearby Calcutt, inner marina spaced out more, one boat per pontoon. Engineers and workshop in situ. Cons difficult entrance (70’) , wifi signal non existent. Only EE on mobile , 3 and Vodafone sporadic.
  6. What a suprise , we have occasionally seen one walking down the flight to the cafe for his lunch
  7. Reckon £200 for blacking liftout and also every 6 months if being stored on land, assume you will winterise.
  8. I would say it’s not really feasible, perhaps if you buy an ex hireboat you might get enough beds but no storage. However you would no doubt be constantly filling up with water, emptying the loo etc . Assuming your husband could find somewhere to work you would need to do a good power audit to ensure you were not running the engine constantly.
  9. I passed this today, we rocked on the bottom passing close to the bank. What was surprising was the upper ‘flying bridge’ structure was steel so could not be taken down. I imagine it will struggle with some of the bridges as he moves down the Oxford to the GU
  10. To give an idea of the scale of the problem from CRTs perspective , this is from a meeting held in early 2015 prior to CRT introducing their guidance (which became miles not kilometres. I thought this figures were high at the time but if true then CRTs change of policy has achieved what it set out to do with the vast majority of boats exceeding a range of 20 miles. • the current information relating to boaters without a home mooring are: 16 % of c.5,400 CC-ers were recorded cruising within a range of <5 kms, and 66% in a range of <20 kms. X stated these were top line figures that were still being verified – they include some boats licensed later in the year - but they were likely to be a reasonable indication of the numbers with a very limited range of movement.
  11. Well I’m sure Nick got the reaction he was seeking. We acknowledge the helms of most boats as we cross. Most acknowledge some don’t. We’ve met some ignorant or unfriendly owners of old boats , private boats and hire boats. That’s life and it’s too short so I prefer to get on with living it.
  12. Passed Sickle today new paintwork looks very nice
  13. Probably the same one we met in Bugbrooke narrows, took a while to get past as he had little control but did go into the bushes so I could creep past.. No name or index number, CRT spotter was just arriving.
  14. It was the fear of abuse of ‘ghost’ moorings (although when challenged CRT were unable to quantify the scale of the problem) that was behind CRTs decision to alter their terms and conditions in an attempt to require boats with a home mooring to cruise as if they did not have one.
  15. A lot of good boat builders were building boats with more than 2’ draft until very recently Hudson comes to mind , so enough room in the centre of the channel for two to cross, not the case when passing a 12’ wide wide beam. This could be alleviated if CRT were to dredge to the bank side rather to the current curve. Yes I know that’s not going to happen. Every time that someone says a particular vessel is suitable for a canal just because of the published dimensionsis one sandwich short of a pick nick and should go away and have a good long think.
  16. Annoyed we can’t be there again but family comes first
  17. Many large companies including CRT have terms and conditions some of which are unenforceable. They rely on the fact that it’s highly unlikely that there customers will have the inclination or finances to challenge them. As I understand it CRT are not allowed to levy financial penalties (save in a couple of specific bylaws) they are however able to charge for services. hence the £25 is described as an extended stay charge (although some earlier signs I believe used the word penalty). If there is no mechanism to pre pay or pay the charge should you wish to stay, it is pretty obvious it’s meant to be a penalty. One assumes a court might take the same view should it arise but I don’t know.
  18. Unfortunately there is a lot of rubbish around in your price range, so it would pay you to factor in the cost of a hull survey unless you know what you are looking at. If it looks good for the price it probably is. Good luck
  19. Julie Sharman on a itv tweet Canal & River trust: "A full redesign and reconstruction is anticipated" Engineers need to view the damage to the wall before a decision will then be able to be made with regards to people re-entering #WhaleyBridge
  20. Richard Parry stated on Newsnight that CRT were not short of funds for reservoir works so there should be no problem.............
  21. We are an all electric boat and have an eye level combination neff microwave/oven and a separate hob.
  22. We have always had a positive experience at Watford but not at Foxton. Earlier this month we arrived at 12 (2 hours after the flight opened) were seventh in the queue. We did not go down although the 6 in front did. When I asked one VLK why were not letdown to the crossover point mid at I was told it as nothing to do with him and the guy at the bottom letting the boats up was in charge. fortunately we were only going to Debdale but what irked as soon as the flight was locked a paddle as lifted to run water down to the leaky bottom pound. So no water conservation and no reason for the restriction on movement.
  23. So annoying last Tuesday we arrived at the top lock at 1155 and we were seventh in the queue, they let six down andbythe timethe six came up it was too late. They didn’t let us down to the cross over point which would have made sense. they locked the flight at 4 then wound the paddle up to run the water down and it was only put down at 9am. Even the volunteers were confused as to why they couldn’t run boats down. i now see there is a stoppage south of Kilby bridge next week to help sort out the leaking lock. What a waste of water and lack of transparency
  24. Doesn’t coal boat Alton transit the flight on a regular basis ?
  25. It’s moored up just the other side of the tunnel - or was around 1200 when we went past.
