Kez Posted January 23, 2010 Report Posted January 23, 2010 (edited) Title says it all. A contact number would be useful, shes wanted for a Project. Having said that; if we cant get Meteor, any butty will do. Any ideas? Edited January 23, 2010 by Kez
sarahavfc Posted January 23, 2010 Report Posted January 23, 2010 Hiya, I'm not 100% sure, but there's Little Woolwich Butty in the Grove at Norton Canes, it has no name on it, but it looks like it could be Meteor. She was based at Aldridge Marina on the Daw End Branch for quite a while and had a weird conversion. Butty in the Grove on the Cannock Extension Meteor at Aldridge Marina
stagedamager Posted January 23, 2010 Report Posted January 23, 2010 Hiya, I'm not 100% sure, but there's Little Woolwich Butty in the Grove at Norton Canes, it has no name on it, but it looks like it could be Meteor. She was based at Aldridge Marina on the Daw End Branch for quite a while and had a weird conversion. Butty in the Grove on the Cannock Extension Meteor at Aldridge Marina it looks like Meteor, if it has metal gunnels, extended cabin and a metal elum it should be!!!!
springy Posted January 23, 2010 Report Posted January 23, 2010 (edited) It is Meteor, having had the conversion removed during a recent sojurn on the bank, you may remember the thread on her "disappearance", meteor thread, I met the new owner when she was being craned in and IIRC he intended to pair her with his motor and use her for carrying, though unfortunately I can't remember any more details. springy edited to add that I think she must have had a new elum Edited January 23, 2010 by springy
stagedamager Posted January 23, 2010 Report Posted January 23, 2010 It is Meteor, having had the conversion removed during a recent sojurn on the bank,you may remember the thread on her "disappearance", meteor thread, I met the new owner when she was being craned in and IIRC he intended to pair her with his motor and use her for carrying, though unfortunately I can't remember any more details. springy edited to add that I think she must have had a new elum It looks like the same elum, or if not a direct copy, we had the metal one made in about '96 when the wooden one gave way, but it wasn't an original small woolwich one, so it will look out of proportion to the hull. I hope it will be used for carrying, and not converted, too many ex working boats go that way. It looks better already, just by getting rid of that "conversion"!
springy Posted January 23, 2010 Report Posted January 23, 2010 It looks like the same elum, or if not a direct copy, we had the metal one made in about '96 when the wooden one gave way, but it wasn't an original small woolwich one, so it will look out of proportion to the hull. I hope it will be used for carrying, and not converted, too many ex working boats go that way. It looks better already, just by getting rid of that "conversion"! I'll have a proper look at the elum tomorrow, I agree about looking better without the conversion. springy
stagedamager Posted January 23, 2010 Report Posted January 23, 2010 I'll have a proper look at the elum tomorrow, I agree about looking better without the conversion. springy Do you know what it is potentionally going to be paired with?
springy Posted January 23, 2010 Report Posted January 23, 2010 Don't recall any name being mentioned, but I will see if anyone else in the basin remembers. springy
MICHEAL WITTMAN Posted January 23, 2010 Report Posted January 23, 2010 I heard there were three josha butties sunk still in a old arm, you could get one of them
Speedwheel Posted January 24, 2010 Report Posted January 24, 2010 I heard there were three josher butties sunk still in an old arm, you could get one of those Please do tell us more.
MICHEAL WITTMAN Posted January 24, 2010 Report Posted January 24, 2010 Please do tell us more. Its private water so better not, overheard the conversation. I was told ones a brathwate buit in west bromwich tho.
Derek R. Posted January 24, 2010 Report Posted January 24, 2010 Its private water so better not, overheard the conversation. I was told ones a brathwate buit in west bromwich tho. And most likely built for FMC. One of 24, and we know which ones it won't be!
Speedwheel Posted January 24, 2010 Report Posted January 24, 2010 (edited) No secrets on here ay Derek! Ok first guess - Kingsdown (argue about its original name amongst yourselves) on the bank at Otherton up the old Lichfield at Hatherton Arm. Edited January 24, 2010 by Satellite
springy Posted January 24, 2010 Report Posted January 24, 2010 It looks like the same elum, or if not a direct copy, we had the metal one made in about '96 when the wooden one gave way, but it wasn't an original small woolwich one, so it will look out of proportion to the hull. I hope it will be used for carrying, and not converted, too many ex working boats go that way. It looks better already, just by getting rid of that "conversion"! Yes it is the same elum - closer inspection shows that what I took as the lines of the edges of the planks in the blade are actually lines of weld! springy
MICHEAL WITTMAN Posted January 24, 2010 Report Posted January 24, 2010 Please do tell us more. enuff said!
stagedamager Posted January 24, 2010 Report Posted January 24, 2010 Yes it is the same elum - closer inspection shows that what I took as the lines of the edges of the planks in theblade are actually lines of weld! springy Nice to see it surviving well, and it's good to know that from a distance the lines work a treat!!!!
carlt Posted January 24, 2010 Report Posted January 24, 2010 Troy cut As you say....No secrets on here: Clicky
Laurence Hogg Posted January 25, 2010 Report Posted January 25, 2010 As you say....No secrets on here: Clicky Most of the boats in the Troy arm are visible on Google earth. Progress is definatly there.
Liam Posted January 25, 2010 Report Posted January 25, 2010 enuff said! I'm sure I've seen this pic before, on here possibly?
MICHEAL WITTMAN Posted January 25, 2010 Report Posted January 25, 2010 As you say....No secrets on here: Clicky They are not in the Troy arm. Bit compromised on this.
springy Posted March 2, 2010 Report Posted March 2, 2010 Do you know what it is potentionally going to be paired with? Aldridge. Dont know much more, domestic fuel on BCN, privately owned carrying Canal Transport Services colours. springy
stagedamager Posted June 19, 2010 Report Posted June 19, 2010 Hi all, Does anyone know how Meteor is getting on and where she is these days, purely intrigued to see how the old girl is going! Regards Dan
