8 minutes ago, MartynG said:
Thats a very special knob.
Is it off an AVO meter ?
Nope. A Windsor model 77A. Price £16.0.0 when new.
10 minutes ago, Chewbacka said:
So about £5000 in today’s money ?
Yeah... the sales bumph proudly proclaimed that it was 20,000 ohms per volt on DC, so it was well posh.
Ohms per volt was an indication of how accurate the meter was. A lower ohms per volt (aka input impedance) shunted more current through the meter thus distorting accurate reading.
When I was learning my trade, valve voltmeters were the dogs danglies for accurate voltage measurement, along with oscilloscopes.
The introduction of digital voltmeters changed all that because they have a naturally high input impedance.
Oh I know all about OPV. When I was working on flight sims there were big signs all over the place that AVO 7s must not be used on any digital equipment. The 500 OPV of a 7 (a whole 1k with the x2 button pressed) wouldn’t only give misleading readings by loading it down but could actually burn out some early driver circuitry. We had a few DMMs around but they were all bulky mains jobs.
So AVO 8s were the order of the day.
Would an AVO model 7 have any value ?  I have  one to sell on which seems complete with probes , a leather case and instruction book.
50 quid if it’s in good condition. Lovely item.
Yup. Must be in full working order though. Check the internal battery is good and hasn’t corroded.
8 hours ago, harrybsmith said:
If you did want a new knob 3d printed (sadly not in bakelite) then I'd happily do it for you as I've got access to a couple of industrial spec machines
Thanks for the offer Harry. If I completely screw this one up (haven’t had the time to look at it yet) I’ll look into how long it would take me to try to model it in CAD. It’s actually quite a complex shape. Great offer though, thanks :)
Can you slice it through at the knob section so keeping the edge and face then graft that onto a new shaft and thin head made of something more substantial, maybe even turned aluminium
Yeah, that’s kind of what I described in post #20, except I’ll be using a plastic shaft.
6 minutes ago, croftie said:
May be worth a PM to Bod
He did end up saying " Any one interested in one for spare/repair, I can't fathom out how it works. "
That’s the one I’m attempting to fix :D
I was suggesting removing not only the shaft but a thin sliver of the knob, if the new shaft was made from metal the disk on the top could be very thin to bond the remains of the knob on. A bit like a metal mushroom
Ahh, gotcha. That would require a lathe... something I don’t have. I’ll try the plastic-shaft-glued-into-a-hole first because I do have a pillar drill, and a plastic shaft, and araldite ;)
