Bobbybass Posted November 4, 2018 Report Share Posted November 4, 2018 (edited) Sorry...double posted Edited November 4, 2018 by Bobbybass Accidental double post Link to comment Share on other sites More sharing options...
dor Posted November 4, 2018 Report Share Posted November 4, 2018 How far between the batteries and the inverter? Link to comment Share on other sites More sharing options...
rusty69 Posted November 4, 2018 Report Share Posted November 4, 2018 Is this thread duplicate. Im sure WotEver replied to this earlier Link to comment Share on other sites More sharing options...
Bobbybass Posted November 4, 2018 Author Report Share Posted November 4, 2018 Thanks for your reply. About 2.5 metres. Link to comment Share on other sites More sharing options...
Sea Dog Posted November 4, 2018 Report Share Posted November 4, 2018 Yep - now he's gonna need 2 sets of cable which will cost twice as much. Expensive schoolboy error! I'd go with 70mm. 1 Link to comment Share on other sites More sharing options...
rusty69 Posted November 4, 2018 Report Share Posted November 4, 2018 1 minute ago, Sea Dog said: Yep - now he's gonna need 2 sets of cable which will cost twice as much. Expensive schoolboy error! I'd go with 70mm. Long or csa? Link to comment Share on other sites More sharing options...
Sea Dog Posted November 4, 2018 Report Share Posted November 4, 2018 1 minute ago, rusty69 said: Long or csa? Ha! You little tinker! Link to comment Share on other sites More sharing options...
Bobbybass Posted November 4, 2018 Author Report Share Posted November 4, 2018 Hi all... Really sorry I screwed up submitting the post twice because of my silly old iPad thing. 2.5 meter run from the batteries. 1500w continuous..3000w peak. 12 volt. Link to comment Share on other sites More sharing options...
Boater Sam Posted November 4, 2018 Report Share Posted November 4, 2018 Biggest that you can get into the terminals. Spend the money on the fattest, do it only once. Link to comment Share on other sites More sharing options...
Bobbybass Posted November 4, 2018 Author Report Share Posted November 4, 2018 4 minutes ago, Boater Sam said: Biggest that you can get into the terminals. Spend the money on the fattest, do it only once. Thank you. Can I ask.....I am home over winter and was going to buy this on eBay and do the terminals myself. I find the specifications confusing as the cables are specified by various numbers etc. How can I tell what is a fat inner core and match it to the corresponding terminal . Link to comment Share on other sites More sharing options...
Richard10002 Posted November 4, 2018 Report Share Posted November 4, 2018 5 minutes ago, Boater Sam said: Biggest that you can get into the terminals. Spend the money on the fattest, do it only once. Surely, if you size them correctly in the first place, you only ever do it once? I have 95mm2 for my 2500W with a 4.5m distance, but there is no sense in getting 95mm2 when 50mm2 will do, or is there? Link to comment Share on other sites More sharing options...
WotEver Posted November 4, 2018 Report Share Posted November 4, 2018 Just now, Bobbybass said: Thank you. Can I ask.....I am home over winter and was going to buy this on eBay and do the terminals myself. I find the specifications confusing as the cables are specified by various numbers etc. How can I tell what is a fat inner core and match it to the corresponding terminal . You’re looking for 70mm2, probably most easily obtained from a welding supplies company. 1 minute ago, Richard10002 said: Surely, if you size them correctly in the first place, you only ever do it once? I have 95mm2 for my 2500W with a 4.5m distance, but there is no sense in getting 95mm2 when 50mm2 will do, or is there? Fractionally smaller voltage drop with everything working well within its design parameters. Nothing wrong with over-engineering high current cabling. Link to comment Share on other sites More sharing options...
rusty69 Posted November 4, 2018 Report Share Posted November 4, 2018 1 minute ago, Bobbybass said: Thank you. Can I ask.....I am home over winter and was going to buy this on eBay and do the terminals myself. I find the specifications confusing as the cables are specified by various numbers etc. How can I tell what is a fat inner core and match it to the corresponding terminal . Its usually specified as standard sized cross sectional area with corresponding terminals to suit. I bought mine from a welding supplier online , a cheap crimper and some glue lined heat shrink sleeving. Link to comment Share on other sites More sharing options...
cuthound Posted November 4, 2018 Report Share Posted November 4, 2018 You can use reducing lugs to connect large cables to smaller terminals,. https://www.etscablecomponents.com/ets-copper-pin-terminals-dsp.html Link to comment Share on other sites More sharing options...
