bmp
Dolly Question
Morning all ...
I have searched through the old posts but can't find the answer to this..... apologies if I haven't looked properly.
Why do some dollies have a nut or a stud on the top and some dont?   I have 2 on the back of my boat and one has a nut or a stud on the top and one doesnt. What is the stud bit for?
Sorry if that is a stupid question !!
Not important - just wondering what it was for.
Thanks.
BMP
Share this post
You will probably find that the one with the 'nut' on top is actually a vent for the fuel tank and will contain a gauze to stop fire flash-back.
Does the stud / nut like this ?
Image result for narrowboat mooring bollard with fuel vent
Edited by Alan de Enfield
Share this post
Beat me to it! Yes, one of ours has such a protuberance, and it is a diesel-tank breather.
Share this post
Glad I asked now - I would never have worked that out !!
Thanks both for the quick replies.
Share this post
No problem - every day is a school-day.
The day you stop learning is the day you die.
Share this post
No mine just looks like a nut on the top and can't see any holes or vents.  I will have to look closer when I go back at the weekend.
Edited by bmp
typo ...
Share this post
Just checked a photo and yes mine does have a hole / vent in it.  I hadn't noticed that.
Thanks for your help.
Share this post
They often have two holes at 60 degrees to each other. It is good practice to ensure both holes are located (pointing forwards) in such a way that it will be more difficult for  water leaking through lock gates to get into the tank. If that is not possible then carry something like a cut off detergent bottle with no bottom that you can pop over the dolly when such water ingress is likely. (Tip given to me by a member of BCF).
Share this post
Looks like mine is pointing backwards. Can it be turned around?  If not I will take your advice on the detergent bottle.
Share this post
You could possibly take it out, put in a spacer (washer) the thickness of 1/2 a turn and put it back in and see if it them 'points' forward.
Try it and see - nothing lost (unless you drop it overboard)
Share this post
Some, but not yours, come with a lock nut. They are easy. Undo half a turn and tighten lock nut. I would see if I could find a soft sump plug washer to fit as per Alaan's post if mine were like yours.
Share this post
Will try that next weekend and see if I can turn it around.
Thanks again for the help and advice.
Share this post
Most flame arrestors in dollies seem to have a 1/2" BSP thread. This needs a washer 21mm across the inside diameter and 0.9 mm thick to turn it half a turn (0.825" major diameter and 14 threads per inch). https://www.connect-consumables.co.uk/product/36808 are 22mm ID and 1.5mm thick, but copper and should crush down to give half a turn of thickness. A friendly garage might give you one if you ask nicely.
Jen
Share this post
I see your vent is painted. Need to be careful not to block the gauze when repainting.
Share this post
No - it is just the photo not showing it up very well. It is still silver and not painted.  But good advice for the future. I am sure I would have just painted over it !
Share this post
And watch out for spiders nesting in the gauze, they can block the vent which can in turn cause a lack of air into the tank, as you use fuel in the engine. This can make an engine stop.
Share this post
Jen
Thanks Jen for the detailed reply 👍🏻
I am am glad I asked the “stupid” question now.
Share this post
I have often covered deck fillers in leaky locks as a precaution  but never even given the vent a thought. Top tip that..
Share this post
Not a big fan of spiders !! Will gladly evict any I find in there !
Share this post
Is there a way of fixing the beast in position immovably once pointing the right way, blob of weld, perhaps? If not, buying a locking filler cap is a waste of money...
Share this post
Tis a very small diameter 'hole', no-way would you get even a small hose pipe-down there (microbore window screen washer pipe - maybe)
You could pour sugar or water down there if you were so inclined but it would be a slow job.
Share this post
It will be about a 19mm hole, big enough for a 8-10mm hose.
Edited by Robbo
Share this post
As the breathers are usually brass and the dolly steel or cast iron not really. You could try Locktite.
Share this post
