stokin'
Length of boats
19 minutes ago, billybobbooth said:
Ive got a laser guided missile will that help get the length accurate?
Won't that reduce the length?
Share this post
2 methods
1 helicopter 2 laser sights. Fly boat up to anticipated length of boat. Make right angles with lasers stern and bow varying height til you get perfect equalateral triangle, with the boat as the base. Read altmeter. This will tell you absolutely nothing, but it got you going, failing that an isosceles triangle wont help either.
Method 2. Blue tack bit of string to join where stem post meets bottom un ravel string length of boat cut string at tip of rudder blade.
measure string
take a gas axe. Cut the stem post verticaly upwards at right angles to the ground. You now have a boat the length of the string.
use spare blue tack to fill in the ‘bit of a hole
if you buy a fender measure and add to string length.
if you insist you can measure the bit youve cut off  and add to the total  to get the initial length just measure the widest bit and use simple maths or if you are under 40 an iphone app.
most boats are not improved by welding the section back on and if you do that,  because it may be a bit wibbly the initial length will be lost. Id stick with the blue tack especially for wide boats on deep water.
Share this post
Sometimes you can wind a bigger boat than the hole, it just depends how far up the bank you can ram the bow.
Share this post
Two pieces of wood (slightly longer than the beam of the boat)
Two pieces of string longer than the boat.
Tie one of the pieces of string onto one end of a piece of wood, and the other piece of string to the other end of the piece of wood. Hold, wedge or clamp wood against the bow.
Run string down each side of the boat and tie off onto the ends of the other piece of wood held tight against the stern.
Measure both lengths of string, add together and divide by two.
That's the length of the boat (to within a fairly close tolerance)
Quicker to do than to describe.
Share this post
Find a 62 ft lock. Put boat in. Close gates. If boat fits..<62ft. If not >62ft. Measure lock with laser thingy (not with an infrequent red thermometer) if unsure of lock length.
Share this post
Or just cruise around trying every lock until you find one that you just 'touch both ends', check with C&RT what their stated dimensions are and Dr Bob's your Uncle
Edit - you may need to firstly explain to C&RT what a lock is.
Share this post
Well that's going to involve a lot of faffing around!:D
Share this post
Done this but now i have 2 holes in my boat! Any one have any wet straw to plug the hole?
Edited by billybobbooth
  • Haha 2
Share this post
How tight did you pull the string?!
Share this post
He told me to use 2 long bits of wood and clamp to the bow and sturn so i took a couple of planks out and nailed to bow and sturn,
Share this post
I'd recommend holding or wedging next time, after you fix the holes.
Edited by TheBiscuits
Share this post
I can lend you some bluetack
Share this post
1 minute ago, Dr Bob said:
I think its gone green.
Squishy and green? Mmmm you're sure its bluetack.
Share this post
That's how the condition was named.  A doctor from Newcastle said exactly those words. - Wa'hey man! I think it's gangrene.
Share this post
I can only use the white stuff, last time i hit the blue stuff with a hammer it just squashed it took me ages go turn it into a nail shape.
Share this post
He was the same chap who on different patient said - "We've got a gonner 'ere".
Share this post
Getting back to these holes, my green looking bluetack will work if you can measure how big the hole is. Have you got one of those laser guided laser measurement thingies? You know, the ones that are good for measuring how long a boat is.
Share this post
I'm not sure that CEP* will help with determining  a boat length.
*circular error probable not the mushroom!
Share this post
To measure my boat length is easy, hook tape measure over stern walk, through galley and saloon then through cross head into cabin and out front doors to bow, now pull tape tight and that's the length. Width involves the addition of 2 spirit levels.
Neil.
Share this post
Neil.
Your boat is wider than it is long? :giggles:
Share this post
