MtB Posted April 26 Report Share Posted April 26 2 hours ago, 1stArthur said: I think you’re right it’s a JD . any idea where to get spare hoses. Any parts? You really do need to sort out which you have. The Beta BD3 is a completely engine from the Beta JD3 which superseded it, even though the two engines look superficially similar and do the same job. Link to comment Share on other sites More sharing options...
BoatinglifeupNorth Posted April 26 Report Share Posted April 26 1 hour ago, Alan de Enfield said: I think he is asking about hoses ! Yes😂 but you can get flexible high temp silicon that will replace pre-formed hoses at alot less price Link to comment Share on other sites More sharing options...
john.k Posted April 27 Report Share Posted April 27 The small bore hoses on the oil cooler need to be correct ......I found any kind of flex hoses would develop a kink and shut off coolant flow. Link to comment Share on other sites More sharing options...
1stArthur Posted April 27 Report Share Posted April 27 5 hours ago, john.k said: The small bore hoses on the oil cooler need to be correct ......I found any kind of flex hoses would develop a kink and shut off coolant flow. I’m not sure I think now it’s a JD 3 it has a ford block . So far it’s ok but what concerns me is the hoses ether end of the heat exchanger and the reduction hoses from the engine. Link to comment Share on other sites More sharing options...
Tony Brooks Posted April 27 Report Share Posted April 27 As a routine test of coolant hoses (not exhaust hoses or spiral reinforced hoses) check the ends where they extend beyond the clips. This is where perishing often first becomes visible. Then squeeze the hose somewhere away from the ends. It should just squeeze in a bit with no or little resistance. if it crunches then it tells you that the inner layer(s) have perished, so the hose will need changing very soon. To get the "feel" try it on sevearl hoses. Link to comment Share on other sites More sharing options...
Tonka Posted April 27 Report Share Posted April 27 1 hour ago, 1stArthur said: I’m not sure I think now it’s a JD 3 it has a ford block . So far it’s ok but what concerns me is the hoses ether end of the heat exchanger and the reduction hoses from the engine. That looks like a BD3 to me as it is similar to mine except mine has the handstand. If it has Ford on the castings that would also point to it being the BD3. Can you post a photo of the engine and the manual that you said you have Link to comment Share on other sites More sharing options...
dmr Posted April 27 Report Share Posted April 27 1 hour ago, 1stArthur said: I’m not sure I think now it’s a JD 3 it has a ford block . So far it’s ok but what concerns me is the hoses ether end of the heat exchanger and the reduction hoses from the engine. That don't look like a JD3 to me so I assume a BD3 but hopefully somebody will confirm this. I suspect that hose/elbow is a Beta special. BD3 is now a very old engine so can't really expect Beta to have all the parts. Link to comment Share on other sites More sharing options...
MtB Posted April 27 Report Share Posted April 27 5 minutes ago, dmr said: That don't look like a JD3 to me so I assume a BD3 but hopefully somebody will confirm this. I suspect that hose/elbow is a Beta special. BD3 is now a very old engine so can't really expect Beta to have all the parts. Nor does it look to me like the BD3 I used to own. In particular I don't remember it having that nice brass gauge in the corner of the photo. Maybe 1stArthur could post a photo of the whole engine, and get a consensus view on what it is. Link to comment Share on other sites More sharing options...
1stArthur Posted April 27 Report Share Posted April 27 8 minutes ago, MtB said: Nor does it look to me like the BD3 I used to own. In particular I don't remember it having that nice brass gauge in the corner of the photo. Maybe 1stArthur could post a photo of the whole engine, and get a consensus view on what it is. Just now, 1stArthur said: I can take more pictures if you like it would be good to clear up what the engine is , ether a BD3 or a JD 3 . As for the manual is was forwarded to me by a kind gentleman on this forum so may or may not be correct for this engine. I will post a pic of it . 5 minutes ago, 1stArthur said: I can take more pictures if you like it would be good to clear up what the engine is , ether a BD3 or a JD 3 . As for the manual is was forwarded to me by a kind gentleman on this forum so may or may not be correct for this engine. I will post a pic of it . I think that should read DB David Brown. Link to comment Share on other sites More sharing options...
MtB Posted April 27 Report Share Posted April 27 38 minutes ago, 1stArthur said: I can take more pictures if you like it would be good to clear up what the engine is , ether a BD3 or a JD 3 . As for the manual is was forwarded to me by a kind gentleman on this forum so may or may not be correct for this engine. I will post a pic of it . I think that should read DB David Brown. Definitely a BD3. Link to comment Share on other sites More sharing options...
Tonka Posted April 27 Report Share Posted April 27 2 hours ago, MtB said: Nor does it look to me like the BD3 I used to own. In particular I don't remember it having that nice brass gauge in the corner of the photo. Maybe 1stArthur could post a photo of the whole engine, and get a consensus view on what it is. I have observed that the Beta BD3 had no standard build. On some the brass oil guage was on the other side of that support where @1stArthur is shown. Some had different air filters fitted. But that is definitely a BD3 version. Sleeman & Hawken may be able to supply hoses if the same hose was fitted to the Lister Classic CRK3 Link to comment Share on other sites More sharing options...
1stArthur Posted April 27 Report Share Posted April 27 5 minutes ago, Tonka said: I have observed that the Beta BD3 had no standard build. On some the brass oil guage was on the other side of that support where @1stArthur is shown. Some had different air filters fitted. But that is definitely a BD3 version. Sleeman & Hawken may be able to supply hoses if the same hose was fitted to the Lister Classic CRK3 Thank you very much I’m glad I now know what it is a BD 3. 4 hours ago, Tony Brooks said: As a routine test of coolant hoses (not exhaust hoses or spiral reinforced hoses) check the ends where they extend beyond the clips. This is where perishing often first becomes visible. Then squeeze the hose somewhere away from the ends. It should just squeeze in a bit with no or little resistance. if it crunches then it tells you that the inner layer(s) have perished, so the hose will need changing very soon. To get the "feel" try it on sevearl hoses. Thank you I will try that . Link to comment Share on other sites More sharing options...
1stArthur Posted April 27 Report Share Posted April 27 22 hours ago, ditchcrawler said: I'm lost, is it a john Deere or a Ford Lister we are talking about? As far as I’ve been told especially after posting pictures the engine is a BD 3 . As for the hoses I think after looking on line I can have them made up. It’s not that I need the immediately but I like to carry spares. Link to comment Share on other sites More sharing options...
Richard T Posted April 27 Report Share Posted April 27 Parkers Motor Factors of Leicester are good for odd hoses especially their Syston branch. Link to comment Share on other sites More sharing options...
1stArthur Posted April 27 Report Share Posted April 27 12 minutes ago, Richard T said: Parkers Motor Factors of Leicester are good for odd hoses especially their Syston branch. Thank you I will have a look at them . Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 27 Report Share Posted April 27 9 hours ago, Tonka said: That looks like a BD3 to me as it is similar to mine except mine has the handstand. If it has Ford on the castings that would also point to it being the BD3. Can you post a photo of the engine and the manual that you said you have I agree with that, the bent hose from the water pump and the brass oil pressure gauge looks BD3 6 hours ago, Tonka said: . Sleeman & Hawken may be able to supply hoses if the same hose was fitted to the Lister Classic CRK3 Just looking at the Lister CRK3 book and it doesnt have that bent pipe having a radiator Link to comment Share on other sites More sharing options...
