Emily Posted August 19, 2009 Report Share Posted August 19, 2009 Hi, not sure if I'm doing this right- I know nothing about computers and less than nothing about boats. I'm interested in buying a 56' 1973 Mildon Marine cruiser stern. The owner wants 19,950 for it, it's in generally good nick though a bit shabby, but the safety cert doesn't cover the ancient diesel boiler, which needs replacing. The shower doesn't work, and the cooker isn't covered by cert either.. Survey in 07 said the hull's ok, but there is significant wear to the stern tube bearing, which needs replacing. There are a few other bits and bobs to do too. I've been looking at various boats for a while now and this one is the most expensive and the one that needs the most work to be liveable. Can anyone tell me if it's just wishful thinking, or is this a bit pricey? Link to comment Share on other sites More sharing options...
Naughty Cal Posted August 19, 2009 Report Share Posted August 19, 2009 Get a survey done. It will save you money in the long run. Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 Get a survey done. It will save you money in the long run. How much will it cost to get a survey? How do I go about it? Link to comment Share on other sites More sharing options...
Proper Job Posted August 19, 2009 Report Share Posted August 19, 2009 If the safety cert doesn't cover the boiler or the cooker (any mention of a gas system?), it virtually worthless. The installation could be substandard and is probably the highest risk appliances on the boat. Stern tube repair is an out of the water/dry dock job. "generally good nick though a bit shabby" - does this mean: ' on the verge of a major refurb'? "this one is the most expensive and the one that needs the most work to be liveable" - Why aren't you going for a cheaper one that needs less work doing to it then? As Phylis says - get a survey of your own done if your really that interested in the boat. Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 (edited) I prob will go for a cheaper one, to be honest, but i LIKE this one! Can you tell me how to go about getting a survey done? P.S Got the price wrong, sorry- it was 19,500 Edited August 19, 2009 by Emily Link to comment Share on other sites More sharing options...
Guest User Posted August 19, 2009 Report Share Posted August 19, 2009 .... just to add; if you really like the boat then when you arrange the survey, ask the surveyor to value the boat in its present condition and provide cost estimates for repair of the basics that you mentioned .... you can use it to help you figure out the economics and to negotiate on price with the seller/broker. Link to comment Share on other sites More sharing options...
Naughty Cal Posted August 19, 2009 Report Share Posted August 19, 2009 Ask the vendor if you can have it surveyed, ring a surveyor, ring a yard to lift the boat, book it, survey done, you get a report which should tell you all you need to know including a valuation. They are not cheap but then again neither is finding out you have bought a lemon. Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 By "Not cheap"... How much, ish? Link to comment Share on other sites More sharing options...
mayalld Posted August 19, 2009 Report Share Posted August 19, 2009 Hi, not sure if I'm doing this right- I know nothing about computers and less than nothing about boats. I'm interested in buying a 56' 1973 Mildon Marine cruiser stern. The owner wants 19,950 for it, it's in generally good nick though a bit shabby, but the safety cert doesn't cover the ancient diesel boiler, which needs replacing. The shower doesn't work, and the cooker isn't covered by cert either.. Survey in 07 said the hull's ok, but there is significant wear to the stern tube bearing, which needs replacing. There are a few other bits and bobs to do too. I've been looking at various boats for a while now and this one is the most expensive and the one that needs the most work to be liveable. Can anyone tell me if it's just wishful thinking, or is this a bit pricey? My first gut reaction is that this is pricey! Unless the owner is prepared to come down on price to somewhere between 12 and 15 thousand, you are probably throwing good money after bad paying for a survey. Link to comment Share on other sites More sharing options...
Naughty Cal Posted August 19, 2009 Report Share Posted August 19, 2009 By "Not cheap"... How much, ish? Dont know for a NB but ours was £400 for the survey plus £100 to lift the boat. Bear in mind this was for a 25ft cruiser that was slipped on a trailer and has few domestic systems. A NB, i suspect will be more. Link to comment Share on other sites More sharing options...
Chris Pink Posted August 19, 2009 Report Share Posted August 19, 2009 (edited) Hi, not sure if I'm doing this right- I know nothing about computers and less than nothing about boats. I'm interested in buying a 56' 1973 Mildon Marine cruiser stern. The owner wants 19,950 for it, it's in generally good nick though a bit shabby, but the safety cert doesn't cover the ancient diesel boiler, which needs replacing. The shower doesn't work, and the cooker isn't covered by cert either.. Survey in 07 said the hull's ok, but there is significant wear to the stern tube bearing, which needs replacing. There are a few other bits and bobs to do too. I've been looking at various boats for a while now and this one is the most expensive and the one that needs the most work to be liveable. Can anyone tell me if it's just wishful thinking, or is this a bit pricey? It is quite pricey for an early 70's boat. One point of note about the earlier survey; if it was done for the previous owner before buying the boat then it will have a critical slant, my first boat's survey picked up on lots of things that weren't really necessary but were included as bargaining points. if the survey was for insurance it will be more honest. I assume it doesn't have a current safety certificate? does it have a failure sheet? The stern tube could well be done in the water but if it hasn't been out the water for a long time then it might as well be docked anyway. For a 56' boat, between £19K and, say. £25K there is a lot of choice at the moment and for a 1970s boat you should be looking for a lot of more recent equipment and fit-out. if you don't know and expert friend then you need a survey, depending on where it is (ie how much to get it out the water) this could be up to £800 but as the mighty Phylis says, this is a lot cheaper than fixing something major. What engine and what condition is a major question. Where is the boat? Edited August 19, 2009 by Chris Pink Link to comment Share on other sites More sharing options...
RLWP Posted August 19, 2009 Report Share Posted August 19, 2009 A boiler and a cooker will cost quite a bit of money, and also time from a specialist to install. Richard Link to comment Share on other sites More sharing options...
Yoda Posted August 19, 2009 Report Share Posted August 19, 2009 Hi, not sure if I'm doing this right- I know nothing about computers and less than nothing about boats. I'm interested in buying a 56' 1973 Mildon Marine cruiser stern. The owner wants 19,950 for it, it's in generally good nick though a bit shabby, but the safety cert doesn't cover the ancient diesel boiler, which needs replacing. The shower doesn't work, and the cooker isn't covered by cert either.. Survey in 07 said the hull's ok, but there is significant wear to the stern tube bearing, which needs replacing. There are a few other bits and bobs to do too. I've been looking at various boats for a while now and this one is the most expensive and the one that needs the most work to be liveable. Can anyone tell me if it's just wishful thinking, or is this a bit pricey? Interesting that you know of this problem but don't know anything about a survey. Link to comment Share on other sites More sharing options...
Naughty Cal Posted August 19, 2009 Report Share Posted August 19, 2009 but as the mighty Phylis says, Why mighty Link to comment Share on other sites More sharing options...
Brummage Posted August 19, 2009 Report Share Posted August 19, 2009 Emily? Can I ask, have you ever spent any time at all on a narrowboat? I'm just curious. Link to comment Share on other sites More sharing options...
stewey Posted August 19, 2009 Report Share Posted August 19, 2009 Emily, is it this boat (unfortunately no pics): http://narrowboats.apolloduck.co.uk/display.phtml?aid=121365 Stewey Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 Interesting that you know of this problem but don't know anything about a survey The boat was surveyed in 07 Interesting that you know of this problem but don't know anything about a survey the survey i'm quoting from was done in 07 Link to comment Share on other sites More sharing options...
magpie patrick Posted August 19, 2009 Report Share Posted August 19, 2009 Interesting that you know of this problem but don't know anything about a survey the survey i'm quoting from was done in 07 If this problem existed in 2007 and it still hasn't been repaired, I would walk away now. It isn't just this fault, it reflects a very high level of neglect for at least the last two years. On top of which it's way to expensive for a 1970's build BOAT Bring Out Another Thousand So don't spend too many thousands now, you'll need them later Link to comment Share on other sites More sharing options...
Christine Posted August 19, 2009 Report Share Posted August 19, 2009 (edited) edited - 'cos it was stupid Edited August 19, 2009 by Christine Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 Sorry, i'm having a bit of trouble working out how to use this computer. Thank you all for your help! I'll try to answer some of the questions -it's got a Lister sr3 engine, which appears to be sound. No, as you can probably tell, i have bugger-all experience of boats. It does have a safety cert, but the cooker and boiler aren't covered by it. Because, presumably, they'd probably fail. Yes, it is that boat. It had a survey in 2007, which said about the bearing etc- is a 2-year old survey still viable? Link to comment Share on other sites More sharing options...
sueb Posted August 19, 2009 Report Share Posted August 19, 2009 Have you a mooring and are you planning on living on it? Sue Link to comment Share on other sites More sharing options...
Liam Posted August 19, 2009 Report Share Posted August 19, 2009 Well made boat by reputable builder If it's a well known, reputable builder then why haven't they named them? Suspicious as always... Link to comment Share on other sites More sharing options...
Emily Posted August 19, 2009 Author Report Share Posted August 19, 2009 If it's a well known, reputable builder then why haven't they named them? Suspicious as always... Mindon marine- I thought he did name them in the ad Have you a mooring and are you planning on living on it?Sue No and yes Link to comment Share on other sites More sharing options...
Liam Posted August 19, 2009 Report Share Posted August 19, 2009 Mindon marine- I thought he did name them in the ad No and yes I take that back.... should open eyes before engaging fingers! Link to comment Share on other sites More sharing options...
alan_fincher Posted August 19, 2009 Report Share Posted August 19, 2009 Walk away, unless that price is highly negotiable. £20K is far too much for a 1973 boat needing as much sorted out as is already admitted to, yet alone everything else that will doubtless come up later. In the current market, there must be much better deals than this one. Link to comment Share on other sites More sharing options...
