Thanks everyone, I have the engine running, but I'm not sure I really understand what the problem was!
1 hour ago, Tony Brooks said:
Without hearing the attempt to start, it sounds to me like lack of fuel. Try loosening the big pipe nuts on the injectors a turn or two, and then crank the engine. You should get a little spit or drip of fuel from each loose nut. If you do tighten up and try to start again, possibly with a blowlamp in the METAL air intake.
I loosened the big nuts on the injectors and cranked, and lo and behold drips of diesel started leaking. I removed the air filter to expose the metal air intake pipe, and tried again (in case it was some kind of blockage) but that made no difference. For future reference, when you say a blowlamp in the air intake, do you mean blow a flame into it with a blowlamp? Directly in or just near, to warm the air?
How did you connect the domestic battery?
I just connected a thick positive cable from the "domestic" side of the split charge relay to the other "starter" side, essentially bypassing the split charge relay which usually separates the two positives. When I measured the voltage of the starter battery at its terminals, it was only 6V. Then I realised that there was a battery isolator switch that appears to isolate the starter battery by disconnecting the negative linkage between them (not sure the point of this). This isolator was off! When I turned the isolator on, the voltage showed my domestic battery voltage. So clearly the problem was I was trying to turn over the engine at 6V!! I'm amazed it did anything at all really.
So the problem seems to be a dead starter battery. I might just get rid of it and use the domestics only. The make is supposedly a "hybrid" that is happy to act as a starter battery.
No or a few wisps of "smoke" from the exhaust while cranking indicates a lack of fuel. Plenty of smoke indicates a low cranking speed, failed  glow plugs or a low compression
Once I solved the voltage issue and I was getting a proper crank out of the starter, the engine would crank and every now and then give a little cough as if it was about to start. Lots of white smoke. It took about 3 or 4 attempts of 30second cranking (the longest I'd dared to do) before it came to life. When it did, the note was a bit more of a deeper grumble rumble than I'm used to.
I'm letting the engine run for 30 mins or so (at idle and with the alternator disconnected so as not to apply load) to get it up to full temperature as suggested.
I fear that my once bombproof beta might not start as easily as it used to anymore though
At a guess you have an air leak in the fuel line somewhere, Betas are pretty much  self bleeding so should start if cranked long enough.
Lots of modern engines are self bleeding so you need a good battery to crank them over , your white smoke would indicate what was happening. We kept our barge in Belgium and laterally France where it stayed for the winter months which one time went down to -15. The engine was changed from a 2 stroke GM which needed a lot of turning to fire up after which the mooring and part of the village was covered in smoke for some time to a Perkins 130hp which after checking oil and water levels started as soon as the heater light went out absolutely brilliant.  The narrow boat PD2 didn’t like to start but had decompression levers and as a last resort hand start. The lister HB2 in our last narrow boat didn’t seem to ever have a problem starting . Originally 1970s we used HD30 oil in summer and HD20 in winter but of course now it’s 15-40 multi grade.
Possible problem with lift pump. My mum had a 1995 Beta BV1505 (35hp) in her narrow boat and one day she had someone in to do some work and he obviously stepped on the lift pump as after that there were some problems starting. I had a look and it turned out there was a tiny crack in one of the pipes. New lift pump ordered and fitted problem solved.
It was rather a tinny little lift pump easy to damage .
Like this. Cracked where the pipe meets the body as it is all one piece of ally.
Edited by magnetman
1. A bit confused, I thought you originally said that you stooped trying to start when the voltage showed 11 volts.
2. The blowlamp flame straight into the metal air intake (so you don't set fire to a plastic air filter enclosure or the paper element).
3. The deeper noise may be diesel knock caused by lots of fuel in the cylinders.
4. Once it is running and the oil has circulated, why are you warming the engine up without a load, that way leads to potently more wear.   It is up to you, but I would run at whatever speed gave maximum charge to maximise the load and give the fastest warm up. probably 1200 to 1500 RPM.
5. If the engine battery was at 6v then I doubt there is any question of it becoming unreliable.
I'm also confused. I am not sure how the voltage dropped at all when cranking when the starter battery earth was isolated from the domestics. I think maybe there is incorrect wiring connecting the negatives even when isolated - perhaps not thick enough to start the engine, but thick enough that the voltage didn't drop? For now I have removed the starter and just start from my domestic battery.
Wow! Ok if I struggle with a cold engine in the future I'll give this a try!
Yes, that's normally what I do if I am running to charge my batteries, but I understood from this thread above that it's frowned upon to increase the revs under no load. So I just let the engine idle and disconnected the alternator to let it get up to speed.
That may well be necessary on a vintage, very slow revving engine with a high alternator pull ratio because at idle with flat batteries it is not unknown for the alternator to stall the engine a sit comes on load, but I can't see why this should be necessary on the vast majority of engines.
It is the amount of load on an engine that determines how much fuel is burned and thus the amount of heat produced, so the higher the load the more heat and the faster the warm-up. I am not sure how much practical difference this makes in real life, but the faster you warm up, the sooner the pistons & rings expand to better seal to the cylinder, so it lessens the blow by with what that can do to the oil. Doing this will certainly give you a faster calorifier warm up.
A good rule of thumb is diesels like to be loaded so one might a swell do what you can to do so.
Except for putting it in gear while tied to the bank. This is not acceptable although people do still do it.
There are many reasons why to not do this.
It damages canal banks.
You could get some debris in the prop and not be quick enough to disengage drive = damaged driveline, bent propshaft etc.
Dangerous if a person or animal were to fall in close to the back of your boat. They could get draw in to the propeller with nobody at the controls to disengage drive.
People do this but it is not acceptable to have propeller turning with nobody at the helm.
Please quote the whole post and the rest of the topic instead of cherry-picking to suit your position.  No one has suggested running in gear while tied up on canals, but it would not matter on most river navigations - the next flood would fill any holes that were dug in the bank.
The whole point is to use the alternator to load the engine to the maximum degree possible. That is all, nothing about running in gear while tied up. In any case, the alternator, even on twin alternator engines, can't be so loaded much more than normal cruising.
FWIW  even a 200 amp alternator at full output is only going to load the engine by less than 3.5 hp plus friction and pumping losses, which is better than just friction and pumping losses.
One thought 😱
Was it very cold (below freezing) on the day you tried but failed to start the engine?
If it was it could be waxy diesel especially as the diesel that's there will be Sumner diesel without the winter additives
1 minute ago, Loddon said:
One thought 😱
Good thought, but I never suffered it, even when the boat was frozen solid into the marina.
I was not having a go at you at all and I don't have a 'position'. People do run their engines in gear and may think it is okay.
Your words were ' diesels like to be loaded so one might a swell do what you can to do so. '
My intention was simply to advise against turning the propeller with nobody at the helm. I know you did not directly advocate doing this but it could be read into your post that it was acceptable. You have to remember that you are a well respected and knowledgeable person when it comes to boats and their engines so it is worth being a bit careful I think.
Running engine in gear while tied up to the bank on a river can still cause damage to the driveline in the event of a propeller foul and does have the hazard of drawing animals or people into the propeller.
It isn't safe to do this. I suspect the safety aspect is often overlooked.
There are people all over the place on paddle boards, inflatable kayaks and even swimmers who would be likely to assume a moored craft will have no propellers turning.
Edited by magnetman
I struggling to understand why you would think it's a good idea to disconnect an alternator from a running or even non running engine. Seems a bit unnecessary to me, if not dangerous to the alternator. General wisdom is disconnecting an alternator when running is a way to ruin them.
I appreciate you may disconnecting then starting the engine... but why ?
Eta  Cross posted so I think the reasoning was something to do with load. Tony has fully explained that.
Edited by jonathanA
X post
Its only a little Beta Jap Kubota for heavens sake. What is all the messing about disconnecting, oiling, bleeding, tick over etc?  Just start the damn thing and go boating.
I think I explained that if he has a very slow revving engine and thus a large alternator with a very high pulley ratio. Some simply will not rev or may stall as the alternator comes on load. However, as Peter Morrison has not given further information, we don't know if this is the case or if it is a personal thing.
Usually when starting the engine I'll engage neutral and put it into say 50% throttle (I don't have a rev counter but say about halfway between tickover and flat out). Alternator (obviously) usually running. I let the engine warm up for 10-20 mins (depending on how cold it is) before I either a) kick it into gear and go boating, or b) dial it back to about 25% which seems to be the sweet spot for alternator output, then let it charge my batteries and heat my water for an hour or two. I always assumed it was best to let the engine warm up for a bit before doing anything with it, but I am gathering from the above that it's not really necessary?
Is that the case even when they are just starting up cold?
Good reminder. I would never do this. The only time I have ever tried leaving the boat in gear while not steering is to hold it against a lock (it was someone else's technique that I was giving a go). I didn't like it, made me very nervous to leave the boat in gear.
6 hours ago, Loddon said:
One thought 😱
Yes it was, but i did get clear liquid diesel out of the injectors when I loosened them so I think not.
Well it was just because here am I, cranking an engine for minutes on end while it's busy trying to drive an alternator. I figured the more load, the harder it would be to start. Was that a bad move for some reason? I disconnected it to give the engine an easier job, that's all. I didn't disconnect it while it was running. I let the engine warm up (at idle and without any load) to about 50 degrees (as measured by my calorifier temperature) and then switched off, reconnected the alternator, and since then the engine seems to be starting fine off of the domestic battery.
1. With no ammeter, that seems an eminently reasonable approach.
2. No, just let it idle for a few seconds to ensure oil gets to where it needs to be. Then rev t.
3.
4. I agree.
5. Think about it. The alternator has to reach a certain speed before it energises and that is usually above cranking speed so the alternator can't energise, so any extra load on the engine will be marginal and the stater motors is specified to deal with that. Don't buy an air cooled Lister with their hydraulic gearbox because they spin the prop and shaft while cranking and dthey still start properly.
Ah ok, so the alternator isn't really providing resistance unless it's spinning fast enough to energise. Thanks that makes sense. Was just struggling to start so was trying to make it as easy as possible. In retrospect that didn't give me any benefit.
Great, the more knowledge the better.
^^^ This ^^^
The engine will be fine. If it isn't, you find out soon enough after about 10,000 hours more run time.
  • 1 year later...
A year on im in the same boat so to speak.
Trying to start up my beta 38 again, and this time no dice. I think the problem is fuel. When I loosen the nuts on top of the injectors, i dont get any bleed.
Working my way through the fuel line while pumping the lift pump, and the blockage seems to be at this "distributor" (photo) - if I disconnect that brass pipe that leads from the filter, i get fuel out the end of that. Close up again. Then, where I have disconnected on the first pipe out of the "distributor" (not sure if that is what it is called) no fuel.
When I disconnect the large nut / union that has a male thread into the distributor, there is a pool of fuel which forms in there and spurts if I pump. I did notice a bit of gunk at the bottom of the pool but that could have been a flake of paint from when i undid it.
I can only really get the first nut off because they are so closely spaced, And it was tight and covered in blue paint so doesn't seem like it's meant to be messed with.
After putting it back together, i get a little bit of bleed from the top of the first and second injector when i loosen the nuts, but the third and fourth are still dry.
So, my thinking is I need to get this distributor right off and give it a right good clean.
Is that something I should attempt or is the problem somewhere else?
If I should attempt this any tips?
TIA
Its not a distributor. Its the injection pump.
Do not remove it or dismantle it in any way, its a precision unit that you cannot do anything with.
How are you bleeding the injector feed pipes?
The Beta is a self bleeding engine. If it has a supply of fuel and a fully charged battery, with the speed control  set to full and turned over for no more than 1 minute at a time it should fire up.
Yes, don't do it. That is the injector pump that really needs specialist attention, adjusting and setting up.
I can't see any pump bleed screw in the photo, which is where I would start looking for fuel.
You won't get any fuel out of the LARGE injector unions unless the engine is spinning, and ideally for this start the throttle is fully open. The injector pump rack or the stop control may be stuck in the no fuel position.
Have i done it some mischief by disassembling the output pipe as shown in the photo? I removed the first union between the injection pump and the nut of the output pipe to the first cylinder. There was a little spring in the union. in the pool of fuel in the hole the union came out of, there was a little bit of dirt.
Loosening the nuts on the top of the cylinders, where the fuel pipes enter. Then cranking the little thumb pump on the fuel lift pump under the fuel filter. I normally do this when servicing the engine and replacing the fuel filter. I was attempting this now to try to understand what is keeping the engine from starting - and it seems like fuel is not reaching the cylinders because I cant get it to bleed from the 3rd and 4th cylinders.
Battery is full, cranking for 1 minute - have tried 20 or 30 times with a mains charger / boost charger attached. Speed is set to full, but i think there might be something off with where it is connected to the pump. I'll take a photo shortly.
Is this a screw on the injector pump (which I called the distributor)
Fuel dripped out of the hole where I removed the injector union, and when I pumped the thumb pump fuel did spurt out.
