MHS Posted June 21, 2021 Report Posted June 21, 2021 We have been experiencing tiller shake recently which increases with larger steering inputs. There is no play in the swan neck/rudder stock and there is no weed/rubbish hanging off the leading edge of the rudder. I can’t find any nicks or evidence of a bent prop, though this is only through the weed hatch. Any ideas as to what may be causing it please?
Jen-in-Wellies Posted June 21, 2021 Report Posted June 21, 2021 Are you on an unusually shallow canal at the moment, compared with where you usually cruise? That can bring it on with my boat.
Tony Brooks Posted June 21, 2021 Report Posted June 21, 2021 Just now, Jen-in-Wellies said: Are you on an unusually shallow canal at the moment, compared with where you usually cruise? That can bring it on with my boat. As can trying to go faster than the canal depth and width allows for your boat.
Jen-in-Wellies Posted June 21, 2021 Report Posted June 21, 2021 Just now, Tony Brooks said: As can trying to go faster than the canal depth and width allows for your boat. Yes. I take it as a sign to ease off on the power.
Tony Brooks Posted June 21, 2021 Report Posted June 21, 2021 1 minute ago, Jen-in-Wellies said: Yes. I take it as a sign to ease off on the power. So did I. Then often as not the stern rose and the boat accelerated a little.
Bee Posted June 21, 2021 Report Posted June 21, 2021 (edited) Possibly the bottom bearing / cup below the rudder is worn, this is usually just a plain steel fitting, possibly a loose joint where the shaft above the rudder is bolted to the shaft through the counter if you have that arrangement. Possibly bent prop although you would feel that through your teeth as well as the tiller. Maybe an anode on the rudder falling off if you have one or two? Edited June 21, 2021 by Bee added a bit
MHS Posted June 21, 2021 Author Report Posted June 21, 2021 2 hours ago, Jen-in-Wellies said: Are you on an unusually shallow canal at the moment, compared with where you usually cruise? That can bring it on with my boat. Sadly not, it’s been doing it on the river Severn too. It is a little worse on a shallow canal too. 2 hours ago, Tony Brooks said: As can trying to go faster than the canal depth and width allows for your boat. It all does it when winding, or when manoeuvring a tight bend and going dead slow.
MHS Posted June 21, 2021 Author Report Posted June 21, 2021 2 hours ago, Bee said: Possibly the bottom bearing / cup below the rudder is worn, this is usually just a plain steel fitting, possibly a loose joint where the shaft above the rudder is bolted to the shaft through the counter if you have that arrangement. Possibly bent prop although you would feel that through your teeth as well as the tiller. Maybe an anode on the rudder falling off if you have one or two? We wondered about the bottom cup too. We have a 7 year old Mike Christian shell and would hope this wouldn’t cause a problem yet. There’s not any movement when giving the swan neck a really good tug. I suppose we may have given the rudder a knock at some time to loosen it though. We are due for blacking soon, but hoped to cure it in the meantime. Thank you for all the suggestions so far.
ditchcrawler Posted June 21, 2021 Report Posted June 21, 2021 10 hours ago, Bee said: Possibly the bottom bearing / cup below the rudder is worn, this is usually just a plain steel fitting, possibly a loose joint where the shaft above the rudder is bolted to the shaft through the counter if you have that arrangement. Possibly bent prop although you would feel that through your teeth as well as the tiller. Maybe an anode on the rudder falling off if you have one or two? There is a company marketing a bottom bearing the other way up. A pin on the skeg and a socket on the rudder, the argument being you wont get grit and sediment in there to accelerate wear
Guest Posted June 21, 2021 Report Posted June 21, 2021 (edited) No body has mentioned the easiest thing to check. Ie something on the prop. Though I see the OP says he's looked through the weed hatch. Edited June 21, 2021 by The Happy Nomad
Peter Thornton Posted June 23, 2021 Report Posted June 23, 2021 Does the top bearing have a grease nipple? In which case, pump some grease in. if not (assuming it’s a metal bearing) think about fitting one?
ditchcrawler Posted June 23, 2021 Report Posted June 23, 2021 3 hours ago, Peter Thornton said: Does the top bearing have a grease nipple? In which case, pump some grease in. if not (assuming it’s a metal bearing) think about fitting one? You will be lucky if a grease nipple in the casting lines up with any grease gallery in the bearing, most bearings are now ZZ and sealed for life. They don't say how long the life is.
Tony Brooks Posted June 23, 2021 Report Posted June 23, 2021 Anyway, a lack of grease is unlikely to cause tiller shake, vibration and noise yes, but not actual shaking about. As many narrowboats have the rudder stock set at an angle to the vertical, the grease nipple is unlikely to align with the small groove around a modern bearing unless it sticks out to one side. In the front the groove will be too high and at the back too low.
ditchcrawler Posted June 23, 2021 Report Posted June 23, 2021 (edited) 11 minutes ago, Tony Brooks said: As many narrowboats have the rudder stock set at an angle to the vertical, the grease nipple is unlikely to align with the small groove around a modern bearing unless it sticks out to one side. In the front the groove will be too high and at the back too low. I am not sure then if it actually feeds into the ball race or just lubricates the self aligning bit. Edited June 23, 2021 by ditchcrawler spilling
Tony Brooks Posted June 23, 2021 Report Posted June 23, 2021 10 minutes ago, ditchcrawler said: I am not sure then if it actually feeds into the ball race or just lubricates the self aligning bit. When I did mine about three years ago I think I saw a small hole and thought that it would not allow much grease into the bearing. Pity it seems impossible to get a rubber/plastic ball version with the same mounting size and centres.
MHS Posted June 23, 2021 Author Report Posted June 23, 2021 We haven’t got a grease nipple, the Mike Christian shell has a sealed bearing. I have on a couple of occasions poured oil down as felt it couldn’t do any harm.
Sea Dog Posted June 23, 2021 Report Posted June 23, 2021 49 minutes ago, MHS said: I have on a couple of occasions poured oil down as felt it couldn’t do any harm. Not til it came back out of the bottom anyway...
MHS Posted June 23, 2021 Author Report Posted June 23, 2021 21 minutes ago, Sea Dog said: Not til it came back out of the bottom anyway... None so far!!
Slim Posted June 23, 2021 Report Posted June 23, 2021 When I get home later today I will come back with my experience of this actual problem.
Tracy D'arth Posted June 23, 2021 Report Posted June 23, 2021 I think that those bearings are nylon as if not used for a while the plastic swells a bit and they tighten up. There will be the same one on the bottom, neither being greaseable. Cold water may make the rudder shudder, it does me when I get in.
Sea Dog Posted June 23, 2021 Report Posted June 23, 2021 2 hours ago, MHS said: None so far!! Surely you've not been underwater to look? That's taking environmental awareness to a new level! Greta will be proud of you...
MHS Posted June 23, 2021 Author Report Posted June 23, 2021 2 hours ago, Sea Dog said: Surely you've not been underwater to look? That's taking environmental awareness to a new level! Greta will be proud of you... I think you will find oil usually floats on top of water, so it would be very obvious. Greta can sleep soundly!
ditchcrawler Posted June 23, 2021 Report Posted June 23, 2021 53 minutes ago, MHS said: I think you will find oil usually floats on top of water, so it would be very obvious. Greta can sleep soundly! As the bottom of the rudder tube is below the water level any oil floating on top will stay there until there is sufficient turbulence to drag it out or you put enough in that the weight of it displaces the water
MHS Posted June 24, 2021 Author Report Posted June 24, 2021 9 hours ago, ditchcrawler said: As the bottom of the rudder tube is below the water level any oil floating on top will stay there until there is sufficient turbulence to drag it out or you put enough in that the weight of it displaces the water I‘ve never added a lot, but will keep an eye out, just in case.
Slim Posted June 24, 2021 Report Posted June 24, 2021 (edited) 19 hours ago, Slim said: When I get home later today I will come back with my experience of this actual problem. I experienced tiller shake for a number of years and tried to cure it without success. New flexible mounts, R & D coupling replaced with a Sigma Drive coupling, new bottom cup, new top bearing, prop balanced by Crowthers, apparent very very slight bow in rudder blade corrected and I'm sure several other things which slip my mind. Any number of people, expert and lay, gave their opinions but no one could cure the issue. Everyone agreed that there was very little if any wear in the stern tube/prop shaft. Over time the stern gland started to drip more and need more frequent repacking. Two years ago the leak increased rapidly and I aborted a local cruise. On the slip I stripped the stern gear down and found that the 1.5" prop shaft had worn down to under 1.2" in the area of the seal. Once out of the boat it was obvious that there was a fair amount of wear between the shaft and the tube. This wear was not evident with the parts in situ. Since then (Sept 19) all my trips have been on the South Oxford (shallow) but so far as I can see the shake problem has been resolved. Should add that I've had the hull from new (self fitout) and that the stern gear and engine beds were installed by the builder (Eastward Engineering) before delivery. Edited June 24, 2021 by Slim additional info
