Hi Clive,
Shall be interested to see how you get on with the ladder on the counter. I attempted to get a (slightly drunk) and chubby chap out of the Trent not many weeks ago using one-he couldnt manage it even with me pulling him.
Cracking spot you are on-one off my fave moorings to stop at - never tried swimming there though!
Think if memory serves me correctly (Tommy will confirm) that if you send a quasi off to Sterling for repair they will replace the innards with a Sinewave board. Or something like that ☺
Maybe not-if its a combi and therefore a battery charger it is allowed to be wired direct (fuse fitted so all good) and not via the isolator.
But I know you already know that..
No.That 'leak' is only cascading from the top few inches of the gate-its not bad maintenance-its a gap- there isnt anything there to stop it leaking!
And I only know that because I was sat there watching it as I was waiting for the lock to fill a week or so ago ?
My system is exactly like that luggsy. I used a 22mm gate valve because I happened to have a shiny new one sitting unused. The gate valve is also fitted with a blanking cap (just in case)- I remove this and replace with suitable compression fitting and hose to an old 3/4 inch shower drain pump when I need to drain the system. Saves alot of faffing about when needing to do anything to cooling system.
You could try-
Streatham Dry dock (Lazy Otter) -they have a pullout and shed for hire which could be ideal
Wyton (next to Hartford Marina-used to be Daylock) Marina
Westview Marina,Earith
These spring to mind as are very much 'working' boatyards so more likely to accomodate you.
Lumisid-once you have got the hang of handling your boat you will find its actually great fun messing about with a fatty. I recently came across the L&L,Trent,Soar(in a 12.8) and some of that isnt as wide as the GU is in alot of places-thoroughly enjoyed myself (when I wasnt aground)☺
In the real world you wont come across so many antis.I had some great laughs and banter with fellow (cheerful) boaters while we were busy dodging each other..
Gbclive- I left Bill Fen at lunchtime and finally got through Ashline lock about 8.30 tonight. It was bloody hard going I have to say. Currently moored on top lock landing (gasp) as visitor moorings are a tad full at the mo..?
I pulled a very sheepish and naked (apart from a very short vest) drunk man out of the Trent at Newark a couple of weeks ago.? The embankment walls near the Barge are about 6ft above the river and he was struggling to get out. His friends helpfully threw his clothes in too after him which promptly sank so having failed to pull him onto the boat ,I towed him with a rope to the nearest ladder. The lady sitting quietly in her narrowboat next to the escape ladder got a bit of a shock as he emerged out the river past her bows..?
I did donate him a towel..
Having recently retrimmed my boat (due to alterations made) I trimmed with a full water tank -because I wanted the gas locker drains to be just on the waterline but with the fuel tank nearly empty. Uxter plate is just touching the water at this point. Adding fuel pulls the back end into the water more and gives me marginally more on the gas locker drain.This isnt ideal on the roof drain but not bad enough to worry about (Evans shell)
