RAP
Everything posted by RAP
OB1 or CT1. CT1 is marginally better, but of course both products are excellent.
Grants lock cottage for sale, again. https://auctions.savills.co.uk/auctions/8--9-may-2024-149/grants-lock-twyford-banbury-ox17-3jw-9835
Interesting? Any pics of your inclined intstalls?
- 18 replies
- heating
- plumbing wesbasto
(and 2 more)
Tagged with:
This is the sort of screw you need. Available in different lengths. https://www.toolstation.com/techfast-heavy-duty-self-drilling-torx-roof-screw/p96795?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dc&pcrid=&pkw=&pmt=&gclid=EAIaIQobChMInsP71sL7gAMVTeBRCh0c5AjnEAQYGSABEgJ37PD_BwE&gclsrc=aw.ds
Great stuff. When will you be posting the video?
The video featuring Parry was not produced today. It was made in spring 2023. Today was a gloriously sunny day in London with reasonably high temperatures. Look at the people in the background wearing warm clothing and the spring leaves on the trees.
I use Screwfix yacht varnish. Two coats, first coat thinned with white spirits, about 70% varnish and 30% white spirits, and the second coat neat varnish. This is applied to the backs and edges of all ply wood floor boards and plywood cabin sides.
This part is clearly shown in the engine manual. It is described as ‘Cylinder head washer for tubular stud’. The part number is 27-795. Have a look at pages 72 for the diagram, and page 73 for the description and part number. My manual is a different version to the one you are viewing. I believe Stationary Engine Parts, Sleeman and Hawken, Marine Power Services or Tony Redshaws should have the part. Alternatively, Dobsons Gaskets can help, but they’ll need a sample/template. It takes a dedicated person to find this stuff, but of course, once you’ve stripped and rebuilt one of these fine pieces of engineering, you know what to look for.
This part is clearly shown in the engine manual - page 64 of mine where it shows the cylinder heads and covers. It is described as ‘Cylinder head washer for tubular stud’. The part number is 27-795.
Grand Union lock cottage: https://auctions.savills.co.uk/auctions/june-2023-115/canal-cottage-lock-78-gade-bank-croxley-green-rickmansworth-wd3-3gd-6837
I use Shiny Sinks, then Brasso to remove the tarnish leaving a gleaming result; effective and efficient!
Brass dome nuts to adorn vintage engines.
Snaygill Boats: https://uk.businessesforsale.com/uk/boat-yard-with-moorings-and-facilities-yorkshire-for-sale-1.aspx
Thanks. That should have been made clearer in the update.
According to the latest Boater’s Update it is not a legal requirement but it is a requirement under the licence terms and conditions. I have pasted the paragraph below from the Boaters’ Update. The British Waterways Act 1971 requires a boat’s name and index to be displayed ‘conspicuously’ and the boat licence terms and conditions specify the details are displayed on both sides of the boats, easily visible. We are starting a new process to address non-displaying boats on the waterway, which could result in enforcement action, so please make sure you’re displaying your boat details correctly and speak to fellow boaters that might not be.
Was it delivered to Kildwick?
Why don’t you walk or cruise up to Kildwick and take a look, it’s not far from the Silsden Woodend moorings. The winding hole is very close to the swing bridge, about 300 metres before the bridge. As others have said, including me, it’s a good place for vehicular access and deliveries. The road is decent albeit narrow, two cars can pass.
There is a winding hole at Kildwick where there is also vehicular access next to the canal by Warehouse swing bridge.
Do not use white spirits to thin the paint, this in itself can contribute to streaking. Too much Owatrol will also do the same - DAMHIK! If using Craftmaster paints then you really should use their thinning agent, especially if you want to maintain a wet edge during application.
I use Owatrol. If you don’t want brush marks then this is the product to use (see pic below). About 10% is usually sufficient. It is also an excellent rust inhibitor when used neat on cleaned up / wire brushed rust.
What to do if you breakdown in Saltersford Tunnel
RAP replied to Alway Swilby's topic in General Boating
Of course! CRT have tested all mobile providers and all provide excellent signal coverage within the tunnel - NOT! -
Just emptied my rather full cassette after a period of six months. Yes, I know I should have emptied it when it was full. No odour in the past six months when visiting the boat, and it emptied easily, in a liquified state. Quite impressed. Oh, and I use Elsan Blue.
I had something similar on my JP3. Eventually, traced the source of the problem to the OEM twin fuel filter assembly. It was leaking air into the fuel system. I bypassed the OEM fuel filter with a modern day fuel filter and the problem disappeared. Of course, any assembly or fuel pipe joint can leak air into the system over time. Hope this helps and provides some things for you to check.
