Naughty Cal Posted November 22, 2013 Report Share Posted November 22, 2013 Ok i admit this isnt on the boat its on the XR4i. The insurance renewal has just been paid which has started a bit of a flurry of activity to get it back on the road again after a break of nearly two years. It had a new Varta starter battery installed just before it was put to sleep last time but as you would expect this has gone flat whilst the car has been stood. We know we should have charged it in the meantime but hindsight is a wonderful thing. So we have took it off the car and left in on a trickle charge for a couple of days. Last night the charger insisted that the battery couldnt take any more charge so we turned it off and are going to leave it standing over the weekend. So the question is just what is the chance of this battery surviving its ordeal? Are we just clutching at straws? Should we try it on the car next week or turn the charger on again and give it another charge? Link to comment Share on other sites More sharing options...
Beaker Posted November 22, 2013 Report Share Posted November 22, 2013 I dare bet it's knackered after two years, especially if it's gradually discharged over that time (clock etc.) Link to comment Share on other sites More sharing options...
Ray T Posted November 22, 2013 Report Share Posted November 22, 2013 I believe perceived wisdom when a boat is winterised is to keep the batteries fully charged, so would a car battery be different? We bought a "spare" battery for the boat and didn't use it for 18 months, when we did try to use it, it was knacked. My track day toy doesn't get much day to day use and a new battery only lasted a year because it was not regularly charged. That's my experience with batteries. 1 Link to comment Share on other sites More sharing options...
alan_fincher Posted November 22, 2013 Report Share Posted November 22, 2013 You may get away with it, you may not. When I was ill we certainly did nothing with the boat for well over a year, with no attempt made to charge the batteries, and they all went on to give quite a bit more service. Has the car been outside, or in a garage? I don't think you will achieve much by trying further charging on it though - if it doesn't work reliably enough after the charger thinks it has done its best now, I would probably say it isn't worth trying a whole heap more. Of course to some extent it depends how serious it is to you if the car will not start without bother. Generally I need a car to start if I need it, without question, but if you for example only use this one for "playing" you might be less bothered if it started letting you down, perhaps? Link to comment Share on other sites More sharing options...
pete.i Posted November 22, 2013 Report Share Posted November 22, 2013 Ok i admit this isnt on the boat its on the XR4i. The insurance renewal has just been paid which has started a bit of a flurry of activity to get it back on the road again after a break of nearly two years. It had a new Varta starter battery installed just before it was put to sleep last time but as you would expect this has gone flat whilst the car has been stood. We know we should have charged it in the meantime but hindsight is a wonderful thing. So we have took it off the car and left in on a trickle charge for a couple of days. Last night the charger insisted that the battery couldnt take any more charge so we turned it off and are going to leave it standing over the weekend. So the question is just what is the chance of this battery surviving its ordeal? Are we just clutching at straws? Should we try it on the car next week or turn the charger on again and give it another charge? Surely it's all a bit of a non-question. Charge it, try it. If it works good on you you saved the price of a new battery. If it doesn't work then buy a new one. I know that everyone is going to say that "well it could fail at a critical time blaah blah blah" but so (and they do) could a new one fail. Pete Link to comment Share on other sites More sharing options...
Tony Brooks Posted November 22, 2013 Report Share Posted November 22, 2013 Surely it's all a bit of a non-question. Charge it, try it. If it works good on you you saved the price of a new battery. If it doesn't work then buy a new one. I know that everyone is going to say that "well it could fail at a critical time blaah blah blah" but so (and they do) could a new one fail. Pete Yes, but its unlikely to. The number of cycles it has been subjected to will be low so any problem is far more likely to be sulphation. As long as the sulphation does not rub through the separators it should last, be it at a reduced capacity. As long a sit works keep using it. Link to comment Share on other sites More sharing options...
matty40s Posted November 22, 2013 Report Share Posted November 22, 2013 Scrap it, you can get quite a bit for them. oh, and the battery too, thats another tenner. Link to comment Share on other sites More sharing options...
bottle Posted November 22, 2013 Report Share Posted November 22, 2013 I would be more worried about the engine, if not set up for that long a term of non use. Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 You may get away with it, you may not. When I was ill we certainly did nothing with the boat for well over a year, with no attempt made to charge the batteries, and they all went on to give quite a bit more service. Has the car been outside, or in a garage? I don't think you will achieve much by trying further charging on it though - if it doesn't work reliably enough after the charger thinks it has done its best now, I would probably say it isn't worth trying a whole heap more. Of course to some extent it depends how serious it is to you if the car will not start without bother. Generally I need a car to start if I need it, without question, but if you for example only use this one for "playing" you might be less bothered if it started letting you down, perhaps? The car has been sat in the garage. Battery flattened by misc items such as clock, stereo and alarm. It isn't the end of the world if the car doesn't start whilst we are at home but it would be nice to think that if we take it out it will get us home again! Will give it a go on the car next week see if it works or not. The one positive is that the car always fires first turn of the key. If it starts it's off to the petrol station to fill it up and jet wash it. Looks like a barn find at the minute covered in dust! Then MOT time! I would be more worried about the engine, if not set up for that long a term of non use. The engine will be fine. It was freshly serviced before it was driven into the garage. We will spin it over a few times to get the oil round it before firing it up. It always fires first turn of the key, well when the battery is charged! Scrap it, you can get quite a bit for them. oh, and the battery too, thats another tenner. It's worth a bit more as a car then scrap value......... Link to comment Share on other sites More sharing options...
MtB Posted November 22, 2013 Report Share Posted November 22, 2013 The car has been sat in the garage. Battery flattened by misc items such as clock, stereo and alarm. These items will flatten the battery in my hobby Scooby in about two weeks. Consequently I had a battery isolator switch fitted so there is no drain on it when the car is parked up. Works well provided I remember to turn it OFF. If I forget, then jump starting the car after three months (say) seems to work fine and the battery recovers despite being drained utterly flat. MtB . Link to comment Share on other sites More sharing options...
harve90 Posted November 22, 2013 Report Share Posted November 22, 2013 Use it or loose it, that is the way with batteries. Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 These items will flatten the battery in my hobby Scooby in about two weeks. Consequently I had a battery isolator switch fitted so there is no drain on it when the car is parked up. Works well provided I remember to turn it OFF. If I forget, then jump starting the car after three months (say) seems to work fine and the battery recovers despite being drained utterly flat. MtB . Now that's not a bad idea. Link to comment Share on other sites More sharing options...
Beaker Posted November 22, 2013 Report Share Posted November 22, 2013 I would be more worried about the engine, if not set up for that long a term of non use. I would check the tyres are OK too, if it's been stood in one position for that long. Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 I would check the tyres are OK too, if it's been stood in one position for that long. Hopefully they are as it had four brand new yokohama's fitted just before it was put to bed! Link to comment Share on other sites More sharing options...
Ex- Member Posted November 22, 2013 Report Share Posted November 22, 2013 You can revive lead acid batteries, I've done a few now, the first one I did was for our forklift truck, it's still going now must be 2 years on and originally wouldn't hold a charge. You need to check each cell first, if any cell is dead sling it, it's unlikely it can be restored. If cells are ok though there a pretty simple process to restore them, Epsom Salts are used to de-sulphate and a couple of slow charges. There's lots of u tube tutorials, the one I used was really good but can't find it, but many other tutorials are the same. http://www.youtube.com/watch?v=LlSJ-g_xftY Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 It's a sealed battery! Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2013 Report Share Posted November 22, 2013 We had this once when we laid up a Renault Clio for over a year. We charged it up when we brought it out of hibernation and it was actually fine for many weeks afterwards until we traded it in. You might be lucky. Link to comment Share on other sites More sharing options...
Ex- Member Posted November 22, 2013 Report Share Posted November 22, 2013 It's a sealed battery! It can be done with many sealed as well, but it's a lot more difficult as you'll need to prise open the casing, Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2013 Report Share Posted November 22, 2013 Hopefully they are as it had four brand new yokohama's fitted just before it was put to bed! it's an interesting point raised by Beaker as ideally a car so stored should ideally be off it's wheels on axle stands. We noticed our Clio had a very slight but noticeable 'wobble' to the ride after it had been stored for so long. On taking it to a local tyre dealer who we trust not to rip us off they advised changing all four. Luckily they were well worn anyway so it was no real hardship, it is worth checking though. Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 Will check them as well as the brakes which were also new! Link to comment Share on other sites More sharing options...
smileypete Posted November 22, 2013 Report Share Posted November 22, 2013 (edited) Don't you have a friend in the trade who can give you a good deal on a new one? I doubt the 'smart' charger you have will do a lot of good, but you never know. Some careful EQ from a basic charger worked for me with a car unused over a year, but only in a limited way; started fine the first time but then struggled and wouldn't start after that, so something inside the batt must have gone pear shaped. So if it does start try waiting overnight then starting again just in case. cheers, Pete. ~smpt~ Edited November 22, 2013 by smileypete Link to comment Share on other sites More sharing options...
Paul's Nulife4-2 Posted November 22, 2013 Report Share Posted November 22, 2013 We'll,as it had already been suggested try it,& let us know. Good luck, See you down Halfords !. Link to comment Share on other sites More sharing options...
Naughty Cal Posted November 22, 2013 Author Report Share Posted November 22, 2013 Don't you have a friend in the trade who can give you a good deal on a new one? I doubt the 'smart' charger you have will do a lot of good, but you never know. Some careful EQ from a basic charger worked for me with a car unused over a year, but only in a limited way; started fine the first time but then struggled and wouldn't start after that, so something inside the batt must have gone pear shaped. So if it does start try waiting overnight then starting again just in case. cheers, Pete. ~smpt~ We do indeed have a friend in the trade which is where this battery came from in the first instance. Want to give it a go at charging though before we go cap in hand for a new one We'll,as it had already been suggested try it,& let us know. Good luck, See you down Halfords !. We never go to Halfrauds Link to comment Share on other sites More sharing options...
Paul's Nulife4-2 Posted November 22, 2013 Report Share Posted November 22, 2013 We do indeed have a friend in the trade which is where this battery came from in the first instance. Want to give it a go at charging though before we go cap in hand for a new one:lol: We never go to Halfrauds Actually,,yours IS a much better name I think.. I suppose its like anything,you pay for convenience. Link to comment Share on other sites More sharing options...
Higgs Posted November 22, 2013 Report Share Posted November 22, 2013 Will check them as well as the brakes which were also new! With the weight of the car, the tyres can develope a 'flat spot' if not rolled into a different position occasionally when not used. Link to comment Share on other sites More sharing options...
