Nine of Hearts Posted June 13, 2012 Report Share Posted June 13, 2012 The glass in my stove cracked earlier this year (I suspect because I had foolishly used an oven cleaner on it - another one chalked up to Mr Experience. I can now tell Jimi, "yes, I am") so I got a replacement, looked at the four philips screws holding the old glass in place and thought, "this should be quite simple...". Ha ha ha ha. Things tried so far: Brute force. Mole grips. Copious amounts of WD40 (I must get some penetrating oil). A few "gentle" taps with a hammer. I have access to an impact driver, but I'm thinking impact driver + iron casting, perhaps not a good combination. Also thought blowtorch on door? Any tips from the forum before I have to drill the ****ers out? Link to comment Share on other sites More sharing options...
stagedamager Posted June 13, 2012 Report Share Posted June 13, 2012 Heat is good but gently father than fiercely!!!! Dan Link to comment Share on other sites More sharing options...
Justme Posted June 13, 2012 Report Share Posted June 13, 2012 Shear them off with brute force (or grind them off)& then drill & tap a new hole. Link to comment Share on other sites More sharing options...
Chris Pink Posted June 13, 2012 Report Share Posted June 13, 2012 The metal will be likely fused. Get a 5mm drill in a pillar drill (important) and drill the centre of the screw with everything clamped solid. You will then either have a coil of screw thread that will come out or a 5mm hole to re- tap. Be very careful though, there's at least 6 ways you could die if you take this advice. Link to comment Share on other sites More sharing options...
lemontoes Posted June 13, 2012 Report Share Posted June 13, 2012 On mine (squirrel), I gave up trying to loosen the screws. As long as the clips still move you should be able to slide the glass in. Link to comment Share on other sites More sharing options...
Nine of Hearts Posted June 13, 2012 Author Report Share Posted June 13, 2012 The metal will be likely fused. Get a 5mm drill in a pillar drill (important) and drill the centre of the screw with everything clamped solid. You will then either have a coil of screw thread that will come out or a 5mm hole to re- tap. Be very careful though, there's at least 6 ways you could die if you take this advice. This is a very nice idea, but it would (I presume) involve taking the door off. The door is held on by four phillips screws, and guess what? Link to comment Share on other sites More sharing options...
RobinJ Posted June 13, 2012 Report Share Posted June 13, 2012 The glass in my stove cracked earlier this year (I suspect because I had foolishly used an oven cleaner on it - another one chalked up to Mr Experience. I can now tell Jimi, "yes, I am") so I got a replacement, looked at the four philips screws holding the old glass in place and thought, "this should be quite simple...". ... I have access to an impact driver, but I'm thinking impact driver + iron casting, perhaps not a good combination. Also thought blowtorch on door? Any tips from the forum before I have to drill the ****ers out? Presumably (like mine) we are talking about the door which lifts off, so can be placed on a solid surface and clobbered with an impact driver! [i got three of the four out and drilled the last one!] I concluded (after trying to figure out where the rope went) that it cracked because of direct contact with the metal due to severe degredation of the fibregalss! When reinserting the new glass I folded the flat rope around the edge of the glass and placed the clamp so that the glass was sandwiched, applying copper slip to the screws in the hope (if I had to) it would be easier to remove! (sshh - don't want to say that after 8 years its still there!) Link to comment Share on other sites More sharing options...
bizzard Posted June 13, 2012 Report Share Posted June 13, 2012 Be careful drilling out the screws,centre punch the bit of screw first cos if the drill bit slips off onto the cast iron it will gouge it badly as cast iron drills easily as a powder,better to drill fresh holes alongside. Link to comment Share on other sites More sharing options...
Nine of Hearts Posted June 13, 2012 Author Report Share Posted June 13, 2012 If I do resort to drilling these out, re-tapping and using new screws, using steel screws into cast iron just seems to me like asking for the things to seize. Would brass screws be a no-no because of the lower melting point? Link to comment Share on other sites More sharing options...
RLWP Posted June 13, 2012 Report Share Posted June 13, 2012 If I do resort to drilling these out, re-tapping and using new screws, using steel screws into cast iron just seems to me like asking for the things to seize. Would brass screws be a no-no because of the lower melting point? That would be a sensible solution. Unless your door glows a nice, bright yellow/gold when in use you are way off the melting point of brass Richard Link to comment Share on other sites More sharing options...
Grace and Favour Posted June 13, 2012 Report Share Posted June 13, 2012 Have you tried 'tightening the screws a tad, before you try to loosen then - it can just break the 'hold' sometimes. Link to comment Share on other sites More sharing options...
zenataomm Posted June 13, 2012 Report Share Posted June 13, 2012 In these situations I always swear loudly, throw my tools around and inflict as much collateral damage as is possible. It's not called Destroy It Yourself for nothing. The job doesn't go any easier however I end up feeling like a victim and not so guilty for having caused the problem in the first place Link to comment Share on other sites More sharing options...
Nine of Hearts Posted June 13, 2012 Author Report Share Posted June 13, 2012 In these situations I always swear loudly, throw my tools around and inflict as much collateral damage as is possible. It's not called Destroy It Yourself for nothing. Yes, I should have included that in my "things I have tried" list. I resorted to words that would startle a hardy sailor, and the obstinate threads still remained tightly locked. Link to comment Share on other sites More sharing options...
Barry Posted June 13, 2012 Report Share Posted June 13, 2012 You're not holding your tongue right between your teeth Try the other side and twisting it a bit Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2012 Report Share Posted June 13, 2012 Presumably (like mine) we are talking about the door which lifts off, so can be placed on a solid surface and clobbered with an impact driver! [i got three of the four out and drilled the last one!] I concluded (after trying to figure out where the rope went) that it cracked because of direct contact with the metal due to severe degredation of the fibregalss! When reinserting the new glass I folded the flat rope around the edge of the glass and placed the clamp so that the glass was sandwiched, applying copper slip to the screws in the hope (if I had to) it would be easier to remove! (sshh - don't want to say that after 8 years its still there!) Unfortunately we are not see above. What this thread has taught me though is I'm defo. going to lift ours off (ours does) and bring it home to attack fix it, I've noticed our Morso glass is cracked and the rope needs replacing..... Link to comment Share on other sites More sharing options...
ditchcrawler Posted June 13, 2012 Report Share Posted June 13, 2012 Try a soaking with "Proper" penetrating oil first, it may work. WD40 is not that good for that sort of thing. Link to comment Share on other sites More sharing options...
DustyDave Posted June 13, 2012 Report Share Posted June 13, 2012 I drilled mine out with a proper Bosch metal drill bit. Of course I messed this up so ended up putting larger screws in. A little copper slip when putting the new screws in should have meant I could remove them again. I sold the stove so never found out. All this was based on advice from local stove centre. Dave Link to comment Share on other sites More sharing options...
simon&jan Posted June 13, 2012 Report Share Posted June 13, 2012 Dont do them too tight , you might need to get them out again ! Link to comment Share on other sites More sharing options...
sharpness Posted June 13, 2012 Report Share Posted June 13, 2012 I had a similar problem once but not on a stove. Liberal heat then penetrating oil, the oil appeared to be drawn in to the thread as it cooled down, then came out easy peasy. Worth a try? Steve Link to comment Share on other sites More sharing options...
smileypete Posted June 13, 2012 Report Share Posted June 13, 2012 I have access to an impact driver, but I'm thinking impact driver + iron casting, perhaps not a good combination. Also thought blowtorch on door? Any tips from the forum before I have to drill the ****ers out? Decent screwdriver bit (think Wera) in a T-bar. Chisel the screw a bit from the side WD40, heat, more WD40, more heat, cursing etc etc. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Barry Posted June 13, 2012 Report Share Posted June 13, 2012 Why WD40? - it is designed as a water displacement medium for electrics Why not a specific penetrating oil? Link to comment Share on other sites More sharing options...
smileypete Posted June 14, 2012 Report Share Posted June 14, 2012 Why WD40? - it is designed as a water displacement medium for electrics Why not a specific penetrating oil? Sure, if it's around, otherwise I'd try heat + WD40. Heat will thin down oil, diesel might do it though a bit pongy. Still could do with a decent screwdriver bit and a small T-bar, and a bit of chiselling from the side to help break any 'seal'. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
bizzard Posted June 14, 2012 Report Share Posted June 14, 2012 Paraffin is a better penetrative than WD40. Proper penetrating oil has a very distinktive smell unlike any other oil,and is available at proper engineers stores, Rocal is one make that do a specialized range of oils,inhibitors and so on. Castrol used to make an excellent penetrating oil called ''Looseol''it had a little Graphite in it also. Some '3 in one' light oils are quite good too. Link to comment Share on other sites More sharing options...
ditchcrawler Posted June 14, 2012 Report Share Posted June 14, 2012 Paraffin is a better penetrative than WD40. Proper penetrating oil has a very distinktive smell unlike any other oil,and is available at proper engineers stores, Rocal is one make that do a specialized range of oils,inhibitors and so on. Castrol used to make an excellent penetrating oil called ''Looseol''it had a little Graphite in it also. Some '3 in one' light oils are quite good too. When we were in dry dock at Braunston I wanted some and couldn't believe the problems I had getting it. A trip to Daventry in the end for it. I seems a lot of people now think WD 40 is penetrating oil for some reason. Link to comment Share on other sites More sharing options...
RLWP Posted June 14, 2012 Report Share Posted June 14, 2012 How odd. Plusgas still seems to be widely available Richard Link to comment Share on other sites More sharing options...
