Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 This is an error of judgement as the law place the onus on the boater. MtB I've seen that mentioned a few times, could you please link me to something that proves it? (I'm not questioning it I just want to see it for myself) Link to comment Share on other sites More sharing options...
cotswoldsman Posted October 6, 2014 Report Share Posted October 6, 2014 I've seen that mentioned a few times, could you please link me to something that proves it? (I'm not questioning it I just want to see it for myself)It says "satisfy" not "prove" as indicated by MtP Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 It says "satisfy" not "prove" as indicated by MtP Thanks, but that is nothing to do with the question I asked... Link to comment Share on other sites More sharing options...
MtB Posted October 6, 2014 Report Share Posted October 6, 2014 I've seen that mentioned a few times, could you please link me to something that proves it? (I'm not questioning it I just want to see it for myself) British Waterways Act 1995: 17 © (ii)the applicant for the relevant consent satisfies the Board that the vessel to which the application relates will be used bona fide for navigation throughout the period for which the consent is valid without remaining continuously in any one place for more than 14 days or such longer period as is reasonable in the circumstances. My emphasis. To me this reads as though the onus is on the applicant to satisfy the board, not that the board must conduct it's own enquiries in order to satisfy itself. MtB Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 (edited) British Waterways Act 1995: 17 © (ii)the applicant for the relevant consent satisfies the Board that the vessel to which the application relates will be used bona fide for navigation throughout the period for which the consent is valid without remaining continuously in any one place for more than 14 days or such longer period as is reasonable in the circumstances. My emphasis. To me this reads as though the onus is on the applicant to satisfy the board, not that the board must conduct it's own enquiries in order to satisfy itself. MtB Thanks ETA: I'm not sure I interpret it the same way you do, the word "will" not "has" seems to make a difference. "the applicant for the relevant consent satisfies the Board that the vessel to which the application relates will be used bona fide for navigation Edited October 6, 2014 by Delta9 Link to comment Share on other sites More sharing options...
Jerra Posted October 6, 2014 Report Share Posted October 6, 2014 It says "satisfy" not "prove" as indicated by MtP Surely if you can "prove" it has to "satisfy" the board. Anything less may not satisfy. At least that is how I see it. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2014 Report Share Posted October 6, 2014 I've seen that mentioned a few times, could you please link me to something that proves it? (I'm not questioning it I just want to see it for myself) From C&RT T&Cs Boater’s Responsibility The law requires the boater to satisfy the Trust that the bona fide navigation requirement is and will be met. It is not for the Trust to prove that the requirement has not been met. This is best done by keeping a cruising log, though this is not a compulsory requirement. If however, the Trust has a clear impression that there has been limited movement insufficient to meet the legal requirements, it can ask for more information to be satisfied in accordance with the law. Failure or inability to provide that information may result in further action being taken, but only after fair warning 7 . Link to comment Share on other sites More sharing options...
cotswoldsman Posted October 6, 2014 Report Share Posted October 6, 2014 Surely if you can "prove" it has to "satisfy" the board. Anything less may not satisfy. At least that is how I see it.Being a Johnie Foreigner I can not answer that was just pointing out the different languages used in the Act Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2014 Report Share Posted October 6, 2014 Surely if you can "prove" it has to "satisfy" the board. Anything less may not satisfy. At least that is how I see it. You can PROVE you have moved, but the movement may not be sufficient to SATISFY the board Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 So you are basically guilty until you prove (or satisfy those concerned) that you are innocent? That doesn't seem right. Link to comment Share on other sites More sharing options...
kris88 Posted October 6, 2014 Report Share Posted October 6, 2014 It would be interesting to know exactly what the actual number of overstayers is. I really can't see that it's as big a problem as it's made out to be. To my mind a much bigger problem is the backlog of essential maintenance. Regards kris Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2014 Report Share Posted October 6, 2014 So you are basically guilty until you prove (or satisfy those concerned) that you are innocent? That doesn't seem right. Yes - that seems to be pretty much the way C&RT is operating. If any questions are raised : You need to satisfy them you are meeting the CC conditions (Boston) You need to satisfy them that your home moring is 'real' (Tony Dunkerly) You need to satisfy them you are not overstaying (Cotswoldman) You need to satisfy them your mooring does not require the boat to be licenced (Nigel Moore) In all cases - guilty until YOU prove your innocence Link to comment Share on other sites More sharing options...
MtB Posted October 6, 2014 Report Share Posted October 6, 2014 (edited) Yes - that seems to be pretty much the way C&RT is operating. If any questions are raised : You need to satisfy them you are meeting the CC conditions (Boston) You need to satisfy them that your home moring is 'real' (Tony Dunkerly) You need to satisfy them you are not overstaying (Cotswoldman) You need to satisfy them your mooring does not require the boat to be licenced (Nigel Moore) In all cases - guilty until YOU prove your innocence No, not guilty as in the emotive sense of being found guilty in a court of law of committing a crime. Unless and until you satisfy the board etc etc you simply don't qualify to hold a boat licence. In a similar way, you can't get a driving license unless you prove to the govt you've passed your driving test. No-one sees this as a 'guilty until proved innocent' issue do they? MtB Edited October 6, 2014 by Mike the Boilerman Link to comment Share on other sites More sharing options...
mark99 Posted October 6, 2014 Report Share Posted October 6, 2014 (edited) No, not guilty as in the emotive sense of being found guilty in a court of law of committing a crime. Unless and until you satisfy the board etc etc you simply don't qualify to hold a boat licence. In a similar way, you can't get a driving license unless you prove to the govt you've passed your driving test. No-one sees this as a 'guilty until proved innocent' issue do they? MtB Indeed - paying to join and then moaning about the rules. Here-in is a small window into a deeply held attitude problem. "It's my right". No it's not - you exchange money for a privilidge. If you don't like it don't join and keep ya money. Edited October 6, 2014 by mark99 Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 In a similar way, you can't get a driving license unless you prove to the govt you've passed your driving test. I don't think that is a good comparison. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2014 Report Share Posted October 6, 2014 In a similar way, you can't get a driving license unless you prove to the govt you've passed your driving test. No-one sees this as a 'guilty until proved innocent' issue do they? MtB With a boat licence, it is granted to you (if you met the relevant criteria), and then 'taken away' if you have commited (in the eyes of C&RT) a 'crime', without any evidence being shown - it is your responsibilty to show evidence that you have not commited the crime. Your driving licence is issued to you (if you meet the relevant criteria) You are accused of commiting a crime (speeding at 120mph) but your licence is not taken away from you until the 'authorities' have provided evidence that you commited the crime. It is very hard to prove you have not done something 1 Link to comment Share on other sites More sharing options...
John V Posted October 6, 2014 Report Share Posted October 6, 2014 It would be interesting to know exactly what the actual number of overstayers is. I really can't see that it's as big a problem as it's made out to be. To my mind a much bigger problem is the backlog of essential maintenance. Regards kris according to Cotswoldman's post (another thread?) C&RT reckoned about 2,000 a few years ago.......that number of mooring fees would pay for a heck of a lot of maintenance! Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 Indeed - paying to join and then moaning about the rules. Here-in is a small window into a deeply held attitude problem. "It's my right". No it's not - you exchange money for a privilidge. If you don't like it don't join and keep ya money. It's not that it is a right, I think people just want to be left alone to live their lives peacefully. If they are complying with the rules why should they have to keep proving that? It sounds like a stupid rule. "if you don't like it don't join" is like "if you don't like it move", it is a logical fallacy used to dismiss the argument without explanation. Why should people not question the rules if they seem unfair? according to Cotswoldman's post (another thread?) C&RT reckoned about 2,000 a few years ago.......that number of mooring fees would pay for a heck of a lot of maintenance! If they spent what they already get less wastefully they wouldn't need more. Link to comment Share on other sites More sharing options...
John V Posted October 6, 2014 Report Share Posted October 6, 2014 It's not that it is a right, I think people just want to be left alone to live their lives peacefully. If they are complying with the rules why should they have to keep proving that? It sounds like a stupid rule. "if you don't like it don't join" is like "if you don't like it move", it is a logical fallacy used to dismiss the argument without explanation. Why should people not question the rules if they seem unfair? If they spent what they already get less wastefully they wouldn't need more. Hmmmmm! you obviously don't run a business and have to deal with the VAT man Link to comment Share on other sites More sharing options...
cotswoldsman Posted October 6, 2014 Report Share Posted October 6, 2014 according to Cotswoldman's post (another thread?) C&RT reckoned about 2,000 a few years ago.......that number of mooring fees would pay for a heck of a lot of maintenance! I did not say I agree with that figure but more importantly that was not for overstayers it was for boats that move less than 10 miles a year don't remember anyone saying they stayed more than 14 days and if memory serves me right it was a 10 mile area so they might well be moving 100 miles a year but not leaving that small are. Just for the sake of clarity even I with my sympathetic mind would tell a boat just travelling in that small area they need to get real Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 Hmmmmm! you obviously don't run a business and have to deal with the VAT man So because the VAT man does it it's OK for all others to do it? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted October 6, 2014 Report Share Posted October 6, 2014 (edited) Delta9, on 06 Oct 2014 - 8:58 PM, said:Delta9, on 06 Oct 2014 - 8:58 PM, said: "if you don't like it don't join" is like "if you don't like it move", it is a logical fallacy used to dismiss the argument without explanation. Why should people not question the rules if they seem unfair? When you apply for, (or renew) your licence to sign to say "I have read and agree with the T&Cs" - if you dont agee with them dont sign to say you do, if you do sign to say you accept them - dont complain about them later. Edit to add - I don't have a problem with C&RT's rules - only when they try and introduce new ones that I have not 'signed up to', make new interpretations of 'old' rules, or try and insert new laws into the previous Waterways Acts Edited October 6, 2014 by Alan de Enfield Link to comment Share on other sites More sharing options...
Delta9 Posted October 6, 2014 Report Share Posted October 6, 2014 When you apply for, (or renew) your licence to sign to say "I have read and agree with the T&Cs" - if you dont agee with them dont sign to say you do, if you do sign to say you accept them - dont complain about them later. I disagree, because CRT have a monopoly on the license. Link to comment Share on other sites More sharing options...
John V Posted October 6, 2014 Report Share Posted October 6, 2014 I disagree, because CRT have a monopoly on the license. NOT correct .......there are other waterways Link to comment Share on other sites More sharing options...
ditchcrawler Posted October 6, 2014 Report Share Posted October 6, 2014 I disagree, because CRT have a monopoly on the license. You don't have to go boating on the canals, its not compulsory. Link to comment Share on other sites More sharing options...
