bizzard Posted July 30, 2011 Report Share Posted July 30, 2011 Obtain a jam or any glass jar with screw lid. Half fill with old turps,old diesel,para,ect,''not petrol or the more volatile spirits''. Chop nice dry sticks,length of jar,pickle for at least two days. To use;-Ignite a stick,chuck onto grate,add kindling,add coal. Result heat. bizzard Link to comment Share on other sites More sharing options...
twbm Posted July 30, 2011 Report Share Posted July 30, 2011 It's a good way to get rid of white spirit after you've cleaned the brushes. Link to comment Share on other sites More sharing options...
bizzard Posted July 30, 2011 Author Report Share Posted July 30, 2011 It's a good way to get rid of white spirit after you've cleaned the brushes. Yes also old dirty diesel fuel bizzard Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2011 Report Share Posted July 30, 2011 (edited) Obtain a jam or any glass jar with screw lid. Half fill with old turps,old diesel,para,ect,''not petrol or the more volatile spirits''. Chop nice dry sticks,length of jar,pickle for at least two days. To use;-Ignite a stick,chuck onto grate,add kindling,add coal. Result heat. bizzard I used to do that when showing a local scout group how to light a camp fire. They thoguht I was using dry sticks, and were very impressed at the speed I could light a fire. Works a treat It's a good way to get rid of white spirit after you've cleaned the brushes. Or let it stand and it will be like new again, leaving the residue at the bottom of the container We do this at work all the time and the same gallon has been around for ages. IIRC cellulose thinner added and the effect is speeded up (might not be celly but certainly one other type of thinner is added.) Edited July 30, 2011 by Guest Link to comment Share on other sites More sharing options...
Bobbybass Posted August 12, 2011 Report Share Posted August 12, 2011 Is old engine oil...with sticks soaked in... any good ?? bob Link to comment Share on other sites More sharing options...
bizzard Posted August 12, 2011 Author Report Share Posted August 12, 2011 Is old engine oil...with sticks soaked in... any good ?? bob I don't see why not,might be more difficult to light though and a bit dirty. bizzard Link to comment Share on other sites More sharing options...
onionbargee Posted August 12, 2011 Report Share Posted August 12, 2011 Mix your old engine oil with a shot of diesel or old paint brush cleaner,and sawdust from your chainsaw, get a big pickle jar with a spoon...... Link to comment Share on other sites More sharing options...
bizzard Posted August 12, 2011 Author Report Share Posted August 12, 2011 Mix your old engine oil with a shot of diesel or old paint brush cleaner,and sawdust from your chainsaw, get a big pickle jar with a spoon...... A Regge regge chutney. bizzard Link to comment Share on other sites More sharing options...
Chertsey Posted August 15, 2011 Report Share Posted August 15, 2011 I have a can of stuff called MFS, which stands for Mysterious Flammable Substance. It's anything from engine oil, via diesel and dirty paraffin, up to white spirit (but nothing more volatile than that). I soak a bit of rag in it to light the fire, or at a pinch kitchen roll or even newspaper - anything to spread it. Then sticks and coal in the conventional manner. Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2011 Report Share Posted August 15, 2011 Not for lighting the BBQ though eh folks???.. Link to comment Share on other sites More sharing options...
Chertsey Posted August 15, 2011 Report Share Posted August 15, 2011 Not for lighting the BBQ though eh folks???.. Why's that? It'll all be burnt off long before it's hot enough to start cooking. Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2011 Report Share Posted August 15, 2011 Why's that? It'll all be burnt off long before it's hot enough to start cooking. Any thing with diesel on it taints the finished product in my experience... Link to comment Share on other sites More sharing options...
bizzard Posted August 15, 2011 Author Report Share Posted August 15, 2011 I have a can of stuff called MFS, which stands for Mysterious Flammable Substance. It's anything from engine oil, via diesel and dirty paraffin, up to white spirit (but nothing more volatile than that). I soak a bit of rag in it to light the fire, or at a pinch kitchen roll or even newspaper - anything to spread it. Then sticks and coal in the conventional manner. Thats the favorite way of lighting up a railway steam locomotive. A heap of old paraffiny rags on a shovel light it and into the firebox and then sticks ect. bizzard Link to comment Share on other sites More sharing options...
ditchcrawler Posted August 15, 2011 Report Share Posted August 15, 2011 Thats the favorite way of lighting up a railway steam locomotive. A heap of old paraffiny rags on a shovel light it and into the firebox and then sticks ect. bizzard I thought that was how you started old diesels, set fire to an oily/paraffin rag and shove it in the air intake. Link to comment Share on other sites More sharing options...
bizzard Posted August 15, 2011 Author Report Share Posted August 15, 2011 I thought that was how you started old diesels, set fire to an oily/paraffin rag and shove it in the air intake. Yes your dead right in the 1960's on old knackered lorry diesel engines and even lit fires under sumps to get em going 'warm the oil'.Had an old 5 ton Bedford with a Perkins P6 in one day,which i caught the starter wrong and these engines could run in reverse and this one did.terrifying,roared ungoverned with exhaust emitting from the air intake,induction air sucking in at the exhaust pipe,I burned the clutch out stalling it up against a wall. bizzard And of course all the gears were reversed 'Forward gears reverse and reverse forward.I nearly crashed it in panic. Link to comment Share on other sites More sharing options...
madcat Posted August 16, 2011 Report Share Posted August 16, 2011 Burning rag tied tightly to a stick with wire,don't risk getting it sucked into the air intake.[learned the hard way by a Board of trade aquaintance and well remembered by me] Link to comment Share on other sites More sharing options...
sebrof Posted August 22, 2011 Report Share Posted August 22, 2011 Obtain a jam or any glass jar with screw lid. Half fill with old turps,old diesel,para,ect,''not petrol or the more volatile spirits''. Chop nice dry sticks,length of jar,pickle for at least two days. To use;-Ignite a stick,chuck onto grate,add kindling,add coal. Result heat. bizzard You're the biz, Biz.! Keep 'em coming. Link to comment Share on other sites More sharing options...
PeteS Posted August 22, 2011 Report Share Posted August 22, 2011 Old lap panel fencing which has been previously had years of creosoting are brilliant. Simply break them up into usable pieces and keep dry. A few pieces are all that is required. Link to comment Share on other sites More sharing options...
bizzard Posted August 22, 2011 Author Report Share Posted August 22, 2011 Old lap panel fencing which has been previously had years of creosoting are brilliant. Simply break them up into usable pieces and keep dry. A few pieces are all that is required. Yes thats the idea,with a little effort,all free gratis'. bizzard. You're the biz, Biz.! Keep 'em coming. Will do,thanks.I've hardly started yet,just softening em all up for the big stuff,which is yet to come. bizzard Link to comment Share on other sites More sharing options...
Titan Posted October 18, 2011 Report Share Posted October 18, 2011 Whilst cleaning angelwood, a gent moored alongside for engine repairs and kindly made me a brew, upon handing said wonderfull mug of t over he plopped t bags on a plate to dry in sunshine, i enquired ooh he sais your a newbie, i dry spent t bags, then soak in diesel n store in a jar , they make fantastic firelighters !!! noted in my newbie book of great ideas Link to comment Share on other sites More sharing options...
cereal tiller Posted October 18, 2011 Report Share Posted October 18, 2011 Yes your dead right in the 1960's on old knackered lorry diesel engines and even lit fires under sumps to get em going 'warm the oil'.Had an old 5 ton Bedford with a Perkins P6 in one day,which i caught the starter wrong and these engines could run in reverse and this one did.terrifying,roared ungoverned with exhaust emitting from the air intake,induction air sucking in at the exhaust pipe,I burned the clutch out stalling it up against a wall. bizzard And of course all the gears were reversed 'Forward gears reverse and reverse forward.I nearly crashed it in panic. dear bizzard your post mentions a PERKINS P6,surely you meant to say a PERKINS TS3? Link to comment Share on other sites More sharing options...
bizzard Posted October 18, 2011 Author Report Share Posted October 18, 2011 dear bizzard your post mentions a PERKINS P6,surely you meant to say a PERKINS TS3? Yes a Perkins P6 Straight 6,four stroke OHV. The TS3 was a Commer, flat 3 cyl Two- stroke Boxer. Lister of course did a TS 3 too. Link to comment Share on other sites More sharing options...
onionbargee Posted October 18, 2011 Report Share Posted October 18, 2011 A Regge regge chutney. bizzard No, it tastes better than Regge Regge sauce Link to comment Share on other sites More sharing options...
alan_fincher Posted October 18, 2011 Report Share Posted October 18, 2011 It's a good way to get rid of white spirit after you've cleaned the brushes. Is it possible to clean paint brushes then ? Link to comment Share on other sites More sharing options...
bizzard Posted October 18, 2011 Author Report Share Posted October 18, 2011 Cellulose thinners will clean paint brushes in a flash especially if you happen to be smoking at the same time. Not sure about synthetic bristles though,probably dissolve before your very eyes. Link to comment Share on other sites More sharing options...
