Bones Posted June 19, 2009 Report Share Posted June 19, 2009 I need some new front doors. The hole is 31.5inches side and 55 inches. I would like metal ones I think, and stable doors. Has anyone replaced their front doors and what sort of cost would I be looking at, and are they hard to get made/fit? Link to comment Share on other sites More sharing options...
RLWP Posted June 19, 2009 Report Share Posted June 19, 2009 (edited) I need some new front doors. The hole is 31.5inches side and 55 inches. I would like metal ones I think, and stable doors. Has anyone replaced their front doors and what sort of cost would I be looking at, and are they hard to get made/fit? Ask the person who supplied your side hatch. Richard Edited June 19, 2009 by RLWP Link to comment Share on other sites More sharing options...
Bones Posted June 19, 2009 Author Report Share Posted June 19, 2009 Ask the person who supplied your side hatch. Richard Genius! Have done. Link to comment Share on other sites More sharing options...
bag 'o' bones Posted June 19, 2009 Report Share Posted June 19, 2009 Personally I think I would go down the get an expert in to measure up make them off site and then fit them for you. However if I were to make new front doors for my boat this is how I would go about making them. Measure the door frame properly as in make sure it not out of wind and is actually square then make a plywood template and 'test it for fit' next transfer the ply template to steel and get a local enginnering shop to chop it out of 4mm steel test fit the steel just to make sure. next weld on or bolt on hinges? Personally I would go for weld on hinges. Set the door within the frame and pack out until there is equal space all round. Temporary bracing might be useful here. mount weld on hinges temporarily. A big welders magnet comes in handy! Tack weld the hinges on. remove bracing packing etc and check operation. Once happy weld up properly. Link to comment Share on other sites More sharing options...
nb Innisfree Posted June 19, 2009 Report Share Posted June 19, 2009 Personally I would go for small coach bolts, square off holes in hinges and drill slightly larger ones in the hull to allow for adjustment, but then I always prefer bolting to welding where practical so that I can remove things easily. Link to comment Share on other sites More sharing options...
bag 'o' bones Posted June 19, 2009 Report Share Posted June 19, 2009 Personally I would go for small coach bolts, square off holes in hinges and drill slightly larger ones in the hull to allow for adjustment, but then I always prefer bolting to welding where practical so that I can remove things easily. Thats fair enough except bolt on platework is just another place for rust to take hold. Both methods have their pros and cons. Link to comment Share on other sites More sharing options...
Phoenix_V Posted June 19, 2009 Report Share Posted June 19, 2009 Personally I think I would go down the get an expert in to measure up make them off site and then fit them for you. However if I were to make new front doors for my boat this is how I would go about making them. Measure the door frame properly as in make sure it not out of wind and is actually square then make a plywood template and 'test it for fit' next transfer the ply template to steel and get a local enginnering shop to chop it out of 4mm steel test fit the steel just to make sure. next weld on or bolt on hinges? Personally I would go for weld on hinges. Set the door within the frame and pack out until there is equal space all round. Temporary bracing might be useful here. mount weld on hinges temporarily. A big welders magnet comes in handy! Tack weld the hinges on. remove bracing packing etc and check operation. Once happy weld up properly. The doors will be stronger if you get the metal working shop to fold the edges for you from memory when we had 2 doors made it was about £100 if they will do them in pickled and oiled steel it will be easier to prepare for painting but will depend what they stock Link to comment Share on other sites More sharing options...
nb Innisfree Posted June 19, 2009 Report Share Posted June 19, 2009 Thats fair enough except bolt on platework is just another place for rust to take hold. Both methods have their pros and cons. Mind you a lot of shells have their hinges stitch welded on (mine included) which don't offer any advantages at all. Link to comment Share on other sites More sharing options...
casper ghost Posted June 19, 2009 Report Share Posted June 19, 2009 We make our doors from 3mm steel so they're not too heavy. Weld 20mm flat around inside to frame them and to fit wood inside of. 40mm flat welded to one door to form the overlap outside. Flap (square) hinges welded on. Works ok for us and are cheap to produce. Link to comment Share on other sites More sharing options...
Bones Posted December 21, 2009 Author Report Share Posted December 21, 2009 I had some new front doors from kedian (and back doors) They are exceptionally easy to fit and I am delighted with them! Link to comment Share on other sites More sharing options...
Martin Kedian Posted December 21, 2009 Report Share Posted December 21, 2009 I had some new front doors from kedian (and back doors) They are exceptionally easy to fit and I am delighted with them! Thank your for your kind comments it was a pleasure to do this work for you ps great bacon sarnies regards Martin Link to comment Share on other sites More sharing options...
Keeping Up Posted December 21, 2009 Report Share Posted December 21, 2009 I'll add my comment, having seen the doors last month, they are really splendid! Link to comment Share on other sites More sharing options...
Martin Kedian Posted December 21, 2009 Report Share Posted December 21, 2009 I'll add my comment, having seen the doors last month, they are really splendid! Glad you think so they are an easy solution for fitted boats and old wodden doors that are past their sell by date Martin Link to comment Share on other sites More sharing options...
Giggetty Posted December 21, 2009 Report Share Posted December 21, 2009 (edited) I had some new front doors from kedian (and back doors) They are exceptionally easy to fit and I am delighted with them! I'd plan for a good cylinder lock and security bolting top and bottom at the same time-? welded mounts too. Edited December 21, 2009 by Giggetty Link to comment Share on other sites More sharing options...
Martin Kedian Posted December 21, 2009 Report Share Posted December 21, 2009 I'd plan for a good cylinder lock and security bolting top and bottom at the same time-? welded mounts too. Dead right they come as part of the package wit ours Martin Link to comment Share on other sites More sharing options...
wrigglefingers Posted December 21, 2009 Report Share Posted December 21, 2009 (edited) Ellen would like to say that they are a substantial improvement compared to the doors on Surprise as they fitted well, with no draught, and she should know as she slept only a foot away from them after the November banter! Edited December 21, 2009 by wrigglefingers Link to comment Share on other sites More sharing options...
David Schweizer Posted December 22, 2009 Report Share Posted December 22, 2009 (edited) A somewhat belated observation about front fitting doors, but here goes. A couple of months ago Mr Finch (or an imposter) broke into several boats on our moorings, each one was accesed through the front doors breaking the lock between the wooden doors, or a single door and the wooden frame. He left both our boat and the boat next to us intact, and the only difference was that we both have a 2" heavy single mahogany front door, mortice locked into a steel frame. From this somewhat unscientific analysis, at would appear that greater securiity is poviided if the door frame is of steel rather than timber. Our door also opens inwards rather than outwards, which means that there is a mahogany draught plate surrounding the frame, making it impossible to insert any implement to force the door. I was seriously considering replacing the single inwards opening front door with a pair of outwards opening doors , but, based upon this recent experience, have decided to refurbish the existing single door instead. Edited December 22, 2009 by David Schweizer Link to comment Share on other sites More sharing options...
Martin Kedian Posted December 22, 2009 Report Share Posted December 22, 2009 A somewhat belated observation about front fitting doors, but here goes. A couple of months ago Mr Finch (or an imposter) broke into several boats on our moorings, each one was accesed through the front doors breaking the lock between the wooden doors, or a single door and the wooden frame. He left both our boat and the boat next to us intact, and the only difference was that we both have a 2" heavy single mahogany front door, mortice locked into a steel frame. From this somewhat unscientific analysis, at would appear that greater securiity is poviided if the door frame is of steel rather than timber. Our door also opens inwards rather than outwards, which means that there is a mahogany draught plate surrounding the frame, making it impossible to insert any implement to force the door. I was seriously considering replacing the single inwards opening front door with a pair of outwards opening doors , but, based upon this recent experience, have decided to refurbish the existing single door instead. Any chance of a few pics Mortimer I cant do it not good at computer savey Thanks Martin Link to comment Share on other sites More sharing options...
Richard Cracknell Posted December 22, 2009 Report Share Posted December 22, 2009 i had stable doors fitted to my boat and retrospectively i could easily live without them, it's an appealling idea but mine don't actually get much use Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 22, 2009 Report Share Posted December 22, 2009 i had stable doors fitted to my boat and retrospectively i could easily live without them, it's an appealling idea but mine don't actually get much use Handy if you want to keep a dog or kids in but still get good ventilation in hot weather Link to comment Share on other sites More sharing options...
Keeping Up Posted December 22, 2009 Report Share Posted December 22, 2009 Handy if you want to keep a dog or kids in but still get good ventilation in hot weather We've got stable doors. I wouldn't be without them (for these same reasons) Link to comment Share on other sites More sharing options...
Martin Kedian Posted December 23, 2009 Report Share Posted December 23, 2009 (edited) We've got stable doors. I wouldn't be without them (for these same reasons) Stable doors are a good means of letting air in yet still afording some secuity and a measure of privacy I can make either Bones had solid steel doors and hers were made in the workshop before instalation on her boat it took about two hours to fit the doors and solve her security isues and water ingress problems delivery time is about 7/10 days please feel free to contact me by pm if you want any info best wishes for Christmass and the New year Martin Edited December 23, 2009 by Martin Kedian Link to comment Share on other sites More sharing options...
