Widebeam from Blackthorn Lakes to Hartford Marina: Possible or crane-out?
I believe 60x10 is the maximum for a widebeam at Whittlesea , or 72x7 for a narrowboat, so you should be OK.  The locks are 11'6", from memory.
You should talk to the lockkeeper at Salters Lode, to check whether you need to go through on the level (it's a short lock) or can use it in normal mode. I think you should be OK....  Check the ML leaflet
https://middlelevel.wpenginepowered.com/wp-content/uploads/2023/05/Navigation-Notes-2023-web-version-3.pdf
More stuff here.
https://goba.org.uk/a-guide-for-visitors-to-the-east/
Agree with everything Scholar Gypsy says plus
On the Great Ouse the only lock that might give you a problem is St Ives which is quoted at 10' 11" on this link:
https://www.gov.uk/guidance/river-great-ouse-bridge-heights-locks-and-facilities#river-great-ouse-locks
The downstream approach to the gates is "kinked" which happened when they put strengthening sheet piling in some years ago.
You are probably short enough to be able to wriggle thru!
Chris
Chris
St Ives not a problem. We're 60 X10 and pass through regularly. Go on a summer weekend and the volunteers will do the work for you.
Edited by pearley
Chris
Ive been through St Ives on a 60 x 10 several times and it isnt a problem.
@SprayfoamMakesMeHappy One of the local 60 x 10 widebeams has been through the Middle Level no problems both directions
You legends! I’m blown away by the promptness and level of detail. Thank you so much. A kinky lock too…could be a wild ride
1 hour ago, booke23 said:
Canal plan says it's possible. 4 or 5 days cruising depending where you are on the Nene.
Yeah I saw that too, but I couldn’t figure out how to generate a result for my boat’s spec. Sounds like you did tho…?
Yes, once you've planned the route go to preferences at the top of the page, then the planning tab. There it will let you put in the dimensions of your boat and it will plan the route accordingly.
Edited by booke23
The kinky Lock is only a problem if there is a stream running as the EA tend to open the Sluice gate nearest the Lock so pushing you around as you enter.
On 22/01/2024 at 20:23, GUMPY said:
Should I mention airdraft at Upwell🤔
Absolutely.  On the second photo, I have reported this in September to Norfolk County Council, as I don't think it is a good sign if you can see the metal bars in a reinforced concrete bridge. They were going to inspect it but I don't know if anything more is happening. Quite apart from bits of concrete landing on you (or even worse your solar panels) there's quite a bit of heavy lorry traffic over this bridge!
3 minutes ago, SprayfoamMakesMeHappy said:
Yiiiiiikes
That's not going to end well, is it.
Maybe go direct to the council's legal team if you don't get a timely response...?
I would move my boat first if I was you. They may just close it until they can get round to fixing it
Loddon would go under there with 50mm to spare and it's not a particularly tall boat. It would have been more if I had removed the 4g antenna.
1 hour ago, Scholar Gypsy said:
Be careful what you wish for! The concrete cover to the reinforcement is clearly inadequate. The appropriate repair will involve removing any loose concrete, cleaning the reinforcement, replacing any areas which have significantly lost cross section, then covering with a sprayed concrete layer thick enough to protect the reinforcement. That would result in a reduction in the available headroom of 20-50 mm, and possibly more.
I checked the ticket on the Council's website, and it says the following, a few months ago (sorry I should have checked this earlier!):
"No action has been taken at this time but we will continue to monitor the problem -We have assessed that the defect does not currently meet our intervention criteria. We will continue to monitor as part of normal scheduled inspections."
