Gavlar1980 Posted September 9, 2023 Report Share Posted September 9, 2023 Good morning all. we are currently on a riverside mooring with no shore power. we have been experiencing large air bubbles releasing from underneath the hull. We are moored on top of a fair amount of weed as pictured. Although the noise does make up jump through the night I’m more concerned about if this might have a long term affect on the hull and baseplate. any advice would be appreciated. I am hoping to put my mind at rest regarding corrosion. Many thanks Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 9, 2023 Report Share Posted September 9, 2023 It might be the weed re;easing oxygen IF it is in sunlight, but more likely rotting vegetation releasing methane. However, the rotting vegetation is common on canals, but not so on rivers where there is flow and floods during the winter to wash it away. I don't think it is anything to worry about. Link to comment Share on other sites More sharing options...
Gavlar1980 Posted September 9, 2023 Author Report Share Posted September 9, 2023 Thanks Tony Im hoping so. It was playing on my mind so I thought I would ask the question. It is extremely loud sometimes. Much appreciated Link to comment Share on other sites More sharing options...
plato Posted September 9, 2023 Report Share Posted September 9, 2023 Hi Gavlar youve absolutely nothing to worry about. It’s just the weed breaking down and releasing methane as it rots . It’ll be particularly prevalent in the hot weather we’re having at the moment. Link to comment Share on other sites More sharing options...
BWM Posted September 9, 2023 Report Share Posted September 9, 2023 We get this occasionally on our silty canal mooring, whilst some is certainly down to a release of gas, a lot is caused by fish moving around the hull. Link to comment Share on other sites More sharing options...
Midnight Posted September 9, 2023 Report Share Posted September 9, 2023 We were at Ripon for 7 years where we had similar with marsh gas bubbling up. When we got onto the boat it would be released so suspect it collected under the baseplate until we stood on the side. When I went into a dry dock that enabled me to see underneath I was horrifies to see the baseplate covered in dome shaped pits, some 4mm deep. I spot welded them sandblasted and two-packed the plate. If you intend to stay there I suggest you black the baseplate next time you dry dock the boat. Link to comment Share on other sites More sharing options...
Gavlar1980 Posted September 9, 2023 Author Report Share Posted September 9, 2023 Hiya thanks for your reply. We were recently blacked and the baseplate was protected too. Link to comment Share on other sites More sharing options...
Stroudwater1 Posted September 9, 2023 Report Share Posted September 9, 2023 Yes the bubbles coming from under the boat around Birmingham is an interesting odour. I’m sure it’s from old rotten vegetation etc from years ago in the mud. Link to comment Share on other sites More sharing options...
blackrose Posted September 9, 2023 Report Share Posted September 9, 2023 (edited) 10 hours ago, Midnight said: If you intend to stay there I suggest you black the baseplate next time you dry dock the boat. I've had a couple of moorings over the years where gas collects under the baseplate and is then released as the boat moves. It's a widebeam so it collects more gas than a narrowboat. My baseplate is unpainted and has never had a problem with pitting 10 hours ago, Midnight said: Edited September 9, 2023 by blackrose Link to comment Share on other sites More sharing options...
matty40s Posted September 9, 2023 Report Share Posted September 9, 2023 The worst bubbles ever are below Tottenham Lock on the Lea in late April and Summer when the temps get silly. Link to comment Share on other sites More sharing options...
Midnight Posted September 10, 2023 Report Share Posted September 10, 2023 13 hours ago, blackrose said: I've had a couple of moorings over the years where gas collects under the baseplate and is then released as the boat moves. It's a widebeam so it collects more gas than a narrowboat. My baseplate is unpainted and has never had a problem with pitting Lucky you! Probably good steel. There was a Norton Canes boat near mine at Ripon. 30 years old and stretched in the middle sometime after build. The original steel was 'as new' the 10ft extension needed spot welding and painting. Link to comment Share on other sites More sharing options...
