GUMPY Posted December 11, 2022 Report Share Posted December 11, 2022 5 minutes ago, ditchcrawler said: It shouldn't go down if filled to the CORRECT level unless you have a leak The correct level is not full when cold. Link to comment Share on other sites More sharing options...
LadyG Posted December 11, 2022 Report Share Posted December 11, 2022 (edited) 1 hour ago, ditchcrawler said: It shouldn't go down if filled to the CORRECT level unless you have a leak We are talking about four months since I put any in. Ideally I would remove a litre but I don't have any way of doing this at the moment. Edited December 11, 2022 by LadyG Link to comment Share on other sites More sharing options...
Tony Brooks Posted December 11, 2022 Report Share Posted December 11, 2022 1 hour ago, LadyG said: We are talking about four months since I put any in. Ideally I would remove a litre but I don't have any way of doing this at the moment. I would try with a length of soft clear plastic hose about 6mm bore and use it to establish a siphon into (say) a milk carton. Being clear hose you should be able to suck liquid into the hose without getting any in your mouth. 1 Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 11, 2022 Report Share Posted December 11, 2022 2 hours ago, LadyG said: We are talking about four months since I put any in. Ideally I would remove a litre but I don't have any way of doing this at the moment. Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 11, 2022 Report Share Posted December 11, 2022 1 minute ago, ditchcrawler said: I think you can get these (once used) at the IVF clinics - saves £7.99. Link to comment Share on other sites More sharing options...
Tony Brooks Posted December 11, 2022 Report Share Posted December 11, 2022 20 minutes ago, ditchcrawler said: I suspect that she may have to try to work whatever she uses into the redundant heat exchager space if she wants to get a liter out. Link to comment Share on other sites More sharing options...
LadyG Posted December 11, 2022 Report Share Posted December 11, 2022 (edited) 29 minutes ago, ditchcrawler said: Yep, I thought about a turkey baster, but not available today. Anyway I've added 700ml so far and not yet up to the mark on my gauge, aka wooden stick . I've not been topping up the level for months, to leave room for antifreeze/coolant as it does lose a bit over time. I thought I'd have to drain the lot as I'm not absolutely sure what was previously used. , then I discovered this universal, thanks to forum, again! I've added 700ml and I reckon it will take another 300 tomorrow. Edited December 11, 2022 by LadyG Link to comment Share on other sites More sharing options...
GUMPY Posted December 11, 2022 Report Share Posted December 11, 2022 If you add neat antifreeze it doesn't mix with the contents 🥱 Link to comment Share on other sites More sharing options...
LadyG Posted December 11, 2022 Report Share Posted December 11, 2022 1 minute ago, Loddon said: If you add neat antifreeze it doesn't mix with the contents 🥱 It's the ready-mix, I think it will be ok, I've run the engine for thirty minutes, hopefully this will set up some sort of thermal circulation. I should be able to tell, it's a fairly luminous yellow., Link to comment Share on other sites More sharing options...
Tony Brooks Posted December 11, 2022 Report Share Posted December 11, 2022 46 minutes ago, Loddon said: If you add neat antifreeze it doesn't mix with the contents 🥱 In an engine with a calorifier given some time running it will. In fact even without a calorifier the bypass post for the water pump should also ensure it eventually gets mixed. It is central heating systems that must have the antifreeze premixed. 1 Link to comment Share on other sites More sharing options...
