According to the latest email from CRT, Locks 1-5 on the Coventry Canal are to be closed from 12 August. Since they are the top 5 locks of the Atherstone flight, why is the rest of the flight remaining open, and how will they be supplied with water?
Notice I got is a restriction and not stoppage...
From Date: 12/08/2022 15:30
To Date: On-going
Type: Navigation Restriction
Reason: Water resources
Is the towpath closed? No
Location
Closest waterway: Coventry Canal
Starts at: Lock 1, Atherstone Top Lock
Ends at: Lock 5
Upstream winding hole: Atherstone Top Lock
Downstream winding hole: Bridge 48
Description
To conserve our water resources in this continuing hot and dry weather, restrictions on lock opening times will need to be in place.
The opening times will be 6:30 - 15:30. The last boat through will be 15:30 and the lock will be closed at 17:00
Boaters wanting to pass through the five locks are advised to leave plenty of time to navigate through the flight before 17:00.
After a relatively dry late spring and summer, levels in reservoirs are lower than normal for the time of year. In order to maximise the available water the Trust is taking the sensible precaution of locking targeted locks up overnight.
This measure is intended to reduce the potential for water losses overnight. We will continue to monitor our reservoir storage and canal opening hours with a view to keeping disruption to a minimum whilst balancing a need to save water.
Thank you for your patience.
Water resources update for boaters
The following canals are temporarily closing to navigation, or have restricted operating times until water levels recover:
  • Coventry Canal – closed from Locks 1 – 5 from 12 August
It appears to be an email inaccuracy that’s somewhat surprising for crt (🤣🤣) in the email they sent out to everyone they have one for.  Someone senior you would think would have sense checked such an important message?
The stoppage notice on crt website posted  above show Atherstone are open but for relatively restricted times, similarly Hillmorton are restricted now. I’m sure that’s the correct plan.
Isn’t Hillmorton from 12th August?
CRT issued an updated notice advising Atherstone Locks 1-5 are operating on restricted hours from 12th August rather than being closed.
Notice Alert
Coventry Canal
Starts At: Lock 1, Atherstone Top Lock
Ends At: Lock 5
Up Stream Winding Hole: Atherstone Top Lock
Down Stream Winding Hole: Bridge 48
Friday 12 August 2022 15:30 until further notice
Update on 06/08/2022:
We'd like to confirm that Atherstone Locks will remain open for navigation after 12th August.  This is just a restriction on navigation times, and not a closure, as mistakenly listed in our  water resources email sent on Friday 5th August.
We apologise for this error and any confusion caused,  Thank you for your patience and help in managing our water resources, which is making a big difference in keeping most of our network open.
Original message:
You can view this notice and its map online here:
https://canalrivertrust.org.uk/notice/22942/atherstone-lock-1-and-5-coventry-canal
You can find all notices at the url below:
https://canalrivertrust.org.uk/notices
Notice Alert
Coventry Canal
Ends At: Lock 5
Original message:
As per the thread,
  • 3 weeks later...
Anyone know what the water situation is on the Aysbury Arm and general area pleas. As they say, asking for a friend, because I am miles away,
Last time I was in Aylesbury the bottom end was pretty  low.  To the point where CRT are actually going to do bank protection and leak stopping on the pound between locks 14 and 15, as well as some work on the gates, starting on 5 Sep.  There is a CRT notice for this, but I dont think navigation is stopped.
Typically there is  water everywhere  from the staircase down to Wilstone but after Jem Bates place  (where the wooden boats  soak up lots of water) there a numerous leaks which have been reported time and again.  The water then struggles to reach the end of the long pound at Broughton lock.
Nobody reported problems over Tring, down through the fields to Leighton or up the Wendover Arm.
N
