The BCN abbreviation appears on various items. This seems to be a guard rail for the canal, but why it was placed there needs investigation.
The BCN owned several narrow gauge tramway, but such use would have removed the letters through use of the waggons passing over the rail. But they had iron guard rails at certain parts of the navigation. On some canals earlier plate rails, from the construction of Devizes Lock, can be seen still used in structures on the Kennet & Avon Canal. There was once a policy to reuse redundant material such as rails and stone blocks. The Great Western Railway took old broad gauge rails and  used them as fence posts.
And were still doing this when they built the Castle Cary cut off in 1906 ish.  Several  boundary markers of bridge rail are still in  place.
Goliath' s rail appears to me to have been rolled specially as a guard iron.  The embossed BCN appears to be on the running surface which would give a rough ride and not  be conducive to easy railway operations.  It would work as a check rail, but in that case why have BCN lettering when it was rolled?
Edited by BEngo
There were quite a few wharves above lock 10 including this one. But which side of the canal was the image taken?
Photo was taken towpath side
The rail coming from what was the entrance to the basin to the lock.
There are no mooring bollards and I was able to use the rail as a tread against the basin bridge. Which is why I noticed the BCN and the odd profile.
I’ll take a better photo next time
Edited by Goliath
48 minutes ago, David Mack said:
What is the cross section of the 'rail' you photographed? Indeed what makes you think it is (was) a railway rail?
I don’t know if it were ever a rail for the railway. It don’t look like it would have been.
But it is being used as a guard rail, keeping the boat off the bricks.
Which is odd because it has an edge rather than any rounded, curved or flat surface.
I should look again properly but I thought it looked (and assumed) it to be a ‘T’ on its side. So the ‘T’ at a Right angle to the brick work.
My fault for not providing the detail, but when you’re locking on your own the photos are a quick secondary thing that’s going on.
I thought someone else would have seen them for sure.
Edited by Goliath
7 hours ago, Heartland said:
Now another location where might this be?
My guess is that it's the BCN house at Goscote, Walsall, which was torched within a few hours of it becoming vacant in the 1980's.
It is a BCN canal cottage, but not at Goscote.
Many years ago I took a party of RCHS members along this waterway and the cottage was then lived in. After that resident left, I gather, the local troglodytes got their boxes of matches out.
Yes I was about to suggest the clue young dog needs experience. but cottage near the aqueduct on the New Main Line is the right answer.
I will let others work out this bridge with what looks like a former GWR weight limit sign.
Cottage 124 near the Aqueduct and of course the bridge plate in your picture was used on the Oxford Canal as well which may help some perhaps.
3 hours ago, Goliath said:
While we wait for Heartland to come back on the above, here’s somewhere to keep going with:
by the sounds of it, there we quite a few road accidents here before the road was straightened and the bridge replaced.
Not BCN, but not far away either.
If it's Cov canal, is it Griff Lane Bridge No17 ?
Yeah
Gipsy Lane Bridge
Is
is Griff Lane Bridge also Gipsy Lane Bridge?
8 minutes ago, Goliath said:
Yeah
Gipsy Lane Bridge
Is
I’m now thinking they are the same
11 minutes ago, Goliath said:
Yeah
Gipsy Lane Bridge
Is
Yes, it's the same bridge. I remember it being rebuilt in the early 1970's !! It's a very busy little lane that's a cut-through on the south side of Nuneaton. In fact the road is so busy they had to build the new bridge alongside the old one to avoid closing the road, and a short section of the old road still survives.
Edited by John Brightley
It looks like there’s a lot of building to go on in that area.
Gipsy Lane is going to be shut for awhile, they’ll be building access to a new estate.
..time roles on.
Edited by Goliath
