Shaun85 Posted January 24, 2021 Report Posted January 24, 2021 Curious to best practice in regards to Bilge pumps, will have mine accessible via a hatch under the cabin stairs as no run holes through bulk head. Could this bilge's pump out go through the bulk head into the engine bay then out via the engine bilge pump? OR Would a decent cabin bilge be able to pump water upwards and out via side hole in hull above water line? Any advice would be appreciated. Cheers.
Alan de Enfield Posted January 24, 2021 Report Posted January 24, 2021 (edited) Any bilge pump should be able to pump a couple of metres (head) above the water line. Ideally any Hull fittings/openings (exhaust, drains, bilge pump, etc) should be a minimum of 10" above the waterline. This is to avoid any water getting syphoned back into the boat. From the BSS (Boat Safety Scheme guidance) To reduce the risk of your boat sinking if it keels over or is excessively weighed down, it's a good idea for privately owned boats to only have openings which are at a height of at least 250mm (10ins) above the waterline. Where openings are necessary below this level this risk can be reduced by ensuring that these openings are permanently and securely connected to ducts or pipes, which are watertight up to that level. Self-draining cockpits may not be able to meet the 250mm (10ins) recommendation but, for privately owned boats, it's a good idea to stop water getting into other parts of the hull by incorporating non-return valves in the drains and/or having bulkheads or cills up to a height of 150mm (6ins). A weed hatch, if not properly secured, can allow water into the bilges of a boat, which could ultimately cause it to sink. It's advisable for privately owned boats to have a secure and watertight weed hatch which reaches to at least 150mm (6ins) above the waterline, when the boat is loaded up as normal. [10.3] Edited January 24, 2021 by Alan de Enfield
David Mack Posted January 24, 2021 Report Posted January 24, 2021 Do you need bilge pump in the cabin? Provided there is a bit of ventilation for the underfloor space, most cabin bilges are bone dry.
Shaun85 Posted January 24, 2021 Author Report Posted January 24, 2021 You think the inspection hatch and a manual pump for emergency would be sufficient for the cabin. Then just have the auto one for the engine bay?
dor Posted January 25, 2021 Report Posted January 25, 2021 You can have an access hole under the rear steps. Then have a bilge pump for on the end of a piece of wood which you can drop into the hole. A long enough length of hose to pump out through the rear doors, either over the side or into the engine ‘ole bilge. Long enough cable with crock clips to reach a battery. it does not need to be permanently installed with float switch.
Shaun85 Posted January 25, 2021 Author Report Posted January 25, 2021 This is what i was thinking, I'm a continuous cruiser so will never be away from the boat for long periods of time, and like all mechanical things clean, so will always be having my head in the engine bay. That and the hatch under the stairs i think i could manage, with one manual pump and then one electrical one i can like you said throw onto the battery direct and use it when needed, plus got a decent sponge and bucket!!!! ha!
BEngo Posted January 25, 2021 Report Posted January 25, 2021 A wet and dry vac is handy for unwanted bilge water. Gets it drier than any pump and you can do other things with it. Only any use if you have enough inverter capacity though. N
Jen-in-Wellies Posted January 25, 2021 Report Posted January 25, 2021 A bilge pump needs a minimum amount of water before it can pick up anyway. If there is that much water sitting in the cabin bilge it is not a good thing. A cabin bilge in a modern design and newish boat shouldn't be getting wet anyway. An inspection hole and some sort of pump for emergencies is all that's needed. The only time I've had need of it was when a water pump started leaking, but wasn't noticed for several days as it wasn't triggering the pump to run. Ended up having to pump a couple of inches out from the inspection hole and had a portable pump that could be connected to the batteries to throw it overboard. Jen
Shaun85 Posted January 25, 2021 Author Report Posted January 25, 2021 Again Thank you very much Jen. Appreciate your reply
cuthound Posted January 27, 2021 Report Posted January 27, 2021 On 25/01/2021 at 10:17, BEngo said: A wet and dry vac is handy for unwanted bilge water. Gets it drier than any pump and you can do other things with it. Only any use if you have enough inverter capacity though. N I agree, bilge pumps always leave a few mm of water behind. I use one of these in the lowest point of the cabin bilge and by the hot and cold water pumps, then use a wet vac to remove any water if they sound. https://www.amazon.co.uk/Basement-Overflow-Battery-powered-Detector-Security/dp/B075D77FYD/ref=asc_df_B075D77FYD/?tag=googshopuk-21&linkCode=df0&hvadid=218062062196&hvpos=&hvnetw=g&hvrand=17879000640032921732&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=1007147&hvtargid=pla-613456477112&psc=1
Benny Posted June 20, 2021 Report Posted June 20, 2021 On 25/01/2021 at 10:17, BEngo said: A wet and dry vac is handy for unwanted bilge water. Gets it drier than any pump and you can do other things with it. Only any use if you have enough inverter capacity though. N What other things might they be? ? We have to break out the generator to run the wet and dry , big hassle for a bit of cabin water. Been using a hand pump oil extractor thing for years. Do it about once a week in the winter, probably get a gallon out each time. Think it's a lot to do with shit insulation (condensation) and maybe an undetected window leak. I'll redo the windows this summer but I imagine I'll still get plenty of cabin water in the winter. I was wondering if there is a shallow water bilge pump? Something than can start drawing at a cm of water or so? Or some kind of electric water pump?
blackrose Posted June 25, 2021 Report Posted June 25, 2021 (edited) On 20/06/2021 at 20:33, Benny said: I was wondering if there is a shallow water bilge pump? Something than can start drawing at a cm of water or so? Or some kind of electric water pump? I've got an old whale gulper connected to a long cable and a couple of big croc clips that I can connect to the batteries for emergency use in the engine bay or back of the cabin. I have a couple of sections of hose that I can quickly connect to it. I've also got a wet vac that I can run from the generator and I do have a permanently installed bilge pump under the cabin stairs just in case. It's never activated in anger but who knows? If the calorifier in the kitchen nearby sprang a leak while I was away it would help if most of those 60 litres were evacuated immediately before any damage was caused. I've even got a big karcher mains submersible pump that I bought form someone selling it second hand. Never used it but the more kinds of pumps available the better one's chances of dealing with a flood or water ingress. Edited June 25, 2021 by blackrose 1
Alan de Enfield Posted June 25, 2021 Report Posted June 25, 2021 37 minutes ago, blackrose said: Never used it but the more kinds of pumps available the better one's chances of dealing with a flood or water ingress. My deck-wash pump is supplied by being connected to a hull fitting and draws water directly from the Canal / River / Sea, It has simple 'click-in' connectors for the piping so I have made a roving hose pipe that can quickly replace the pump water supply and the end of the hose simply put into the relevant bilge area. The water is then directed overboard, It will suck-down to almost 'nothing' as the boat tends to have a bit of a slope one way or the other in each bilge, simply put the hose into the lowest corner and it gets it to almost dry. A wipe around with some 'Plenty' and its done. 1
