Rickent Posted June 29, 2020 Report Share Posted June 29, 2020 11 hours ago, TheBiscuits said: I use and often recommend Sunshine Solar for inverters that are cheaper than the big names but better than the noname ebay ones. For the difference in price, I'd go for a pure sine wave model. If you ever get anything more sensitive you'll be able to plug it in and not worry about it. https://www.sunshinesolar.co.uk/Category/PureSineWave12V (No connection, just a happy customer) We have a 1000w pure sine wave from Sunshine Solar, very happy with it so far. Link to comment Share on other sites More sharing options...
matty40s Posted June 29, 2020 Report Share Posted June 29, 2020 Or a £3.99 toothbrush from Boots where you have to exercise your arm a bit. Link to comment Share on other sites More sharing options...
OldGoat Posted June 29, 2020 Report Share Posted June 29, 2020 9 hours ago, TheBiscuits said: A High Frequency (HF) inverter runs the 12V DC through an ~20 kHz oscillator and feeds it into a small transformer, and typically weighs ~5Kg for a 3KW inverter. Clever electronics, but not ideal for very heavy loads. They also tend to draw < 1A when doing nothing, so can be left on 24/7. A Low Frequency (LF) inverter runs the 12V DC through an ~50-60 Hz oscillator and feeds it into a large transformer, and typically weighs ~25Kg for a 3KW inverter. Not clever electronics, but good at very heavy loads. They also tend to draw > 4A when doing nothing, or they have a "pulse sense" setting that allows them to claim lower draw in the brochure but won't start inverting when you have only a mobile phone charger plugged in. Ah... You've answered two queries running through my mind - but was afraid to ask. The HF unit I tested from Bimble came in a small box, ran TWO fridge freezers (because I had two to play with) without a hitchI wondered why they said the unit should not be run continuously on high power. It was very well priced The Sterling unit weighed a ton - with a massive transformer, but then it was a 2200W unit designed for large loads. It was disappointing that neither unit would start the fridges when in eco mode (which was the purpose of the test). I don't like unanswered questions - therefore thank you fo enlightening me!! Link to comment Share on other sites More sharing options...
Richard10002 Posted June 29, 2020 Report Share Posted June 29, 2020 14 hours ago, TheBiscuits said: You can get electric tooth brushes that take AA batteries rather than the induction charging systems that get killed by MSW ... Having killed one Braun/Oral B toothbrush charger with my 300W MSW inverter, I found a charger that is powered from a USB socket. A perfect outcome Link to comment Share on other sites More sharing options...
Richard10002 Posted June 29, 2020 Report Share Posted June 29, 2020 6 hours ago, matty40s said: Or a £3.99 toothbrush from Boots where you have to exercise your arm a bit. Our dentist tells us that our teeth are in much better condition since we started using electric tooth brushes. Link to comment Share on other sites More sharing options...
cuthound Posted June 29, 2020 Report Share Posted June 29, 2020 I've posted this before, but it will show the OP the waveform differences between the different types of inverter. Link to comment Share on other sites More sharing options...
Detling Posted July 1, 2020 Report Share Posted July 1, 2020 On 28/06/2020 at 18:34, Rat Gar said: I have a 600 watt 12v invertor which I bought from Maplins before it shut and it has served me well but I need a new one now and was wondering what to go for !!! It is not that long since Maplins closed so are we talking 2 or 3 years use? My Victron is 12 years old and touch wood still going strong, maybe thats why they cost more. Link to comment Share on other sites More sharing options...
WotEver Posted July 1, 2020 Report Share Posted July 1, 2020 (edited) On 29/06/2020 at 17:44, cuthound said: I've posted this before, but it will show the OP the waveform differences between the different types of inverter. That's actually a very good MSW. Most of the ones I've seen just look like a square wave with a single step. Here's a Yankee one as an example... Edited July 1, 2020 by WotEver Link to comment Share on other sites More sharing options...
