Lord Belvoir Posted March 19, 2020 Report Posted March 19, 2020 Do any of you know how to remove the extension shaft on the crank end on a lister ha2
Richard T Posted March 20, 2020 Report Posted March 20, 2020 This question might get answered if it were in the vintage engine section where RWLP might see it.
Athy Posted March 20, 2020 Report Posted March 20, 2020 46 minutes ago, Richard T said: This question might get answered if it were in the vintage engine section where RWLP might see it. Poor chap, his name has only four letters and yet he's the most misspelt member of the forum. Moved as suggested.
OptedOut Posted March 20, 2020 Report Posted March 20, 2020 (edited) Remove timing gear cover and undo the 4 bolts. Edited March 20, 2020 by OptedOut
Lord Belvoir Posted March 23, 2020 Author Report Posted March 23, 2020 On 20/03/2020 at 18:45, OptedOut said: Remove timing gear cover and undo the 4 bolts. Yes that's the extension shaft on the crankshaft pinion....I've removed the 4 bolts on the oil thrower...now on the flange which is part of the shaft theres about 3/4" depth that I can tap a 12mm thread in....then I could get 4×12×130 bolts in with a plate on top so could attach a slide hammer to......any thoughts on this or am I missing something?
Lord Belvoir Posted March 23, 2020 Author Report Posted March 23, 2020 Richard thanks for your reply.....mate I've tried everything been at it since Thursday....bloody things driving me nuts
RLWP Posted March 23, 2020 Report Posted March 23, 2020 (edited) 37 minutes ago, Lord Belvoir said: Richard thanks for your reply.....mate I've tried everything been at it since Thursday....bloody things driving me nuts Let me check so I can be certain, I'm pretty sure that the extension is bolted on and located with a dowel. The drive gear in the Lister Blackstone box is something like that and usually comes off with a little strategic hammering Let me see if I can find a gear so you can see what's on the back of the flange Richard Edited March 23, 2020 by RLWP
RLWP Posted March 23, 2020 Report Posted March 23, 2020 On 20/03/2020 at 17:50, Athy said: Poor chap, his name has only four letters and yet he's the most misspelt member of the forum. Moved as suggested. Disarranged my grandads again. They'll come and haunt you
Lord Belvoir Posted March 23, 2020 Author Report Posted March 23, 2020 Richard just quick one...when ordering bearing shells how do you know ya getting something decent and not something that's going to melt 3 months down the cut
RLWP Posted March 23, 2020 Report Posted March 23, 2020 1 minute ago, Lord Belvoir said: Richard just quick one...when ordering bearing shells how do you know ya getting something decent and not something that's going to melt 3 months down the cut Oh dear - it all depends Genuine Lister ones can be almost anything nowadays, I have just had to swap a pair in an SR3 because they didn't install properly. I fitted an identical pair and they were fine - genuine Lister, same manufacturer If you are lucky, we will have old stock bearing shells, otherwise it's pot luck Richard
bizzard Posted March 23, 2020 Report Posted March 23, 2020 Vandervill and Glacier were-are one of the most well known makers of shell bearings, which is what I always used on vehicle engines.
RLWP Posted March 23, 2020 Report Posted March 23, 2020 Just now, bizzard said: Vandervill and Glacier were-are one of the most well known makers of shell bearings, which is what I always used on vehicle engines. Good luck finding those Richard
bizzard Posted March 23, 2020 Report Posted March 23, 2020 2 minutes ago, RLWP said: Good luck finding those Richard
Lord Belvoir Posted March 23, 2020 Author Report Posted March 23, 2020 Will let you know when I get the crank out what size I need?
Stilllearning Posted March 23, 2020 Report Posted March 23, 2020 (edited) 2 hours ago, bizzard said: Vandervill and Glacier were-are one of the most well known makers of shell bearings, which is what I always used on vehicle engines. Vandervell , from Tony Vandervell of Vanwall Racing fame, and owner of Thinwall Bearings ETA his dad was the founder of CAV Edited March 23, 2020 by Stilllearning
