Everything posted by OptedOut
During our time in a private boat share we never changed any seals, same when we owned a Land Rover. Must have been lucky!
Probably the best option if the costs are mounting. Best of luck.
I suspect everything may be working OK but the pinion is not engaging with the flywheel properly. The assembly in the image is an overrun device to throw the gear out of engagement should the operator continue to hold the start button in after starting or trying to operating the starter whilst the engine is running. This seems to indicate a lack of engagement due to , (a) damaged pinion teeth, (b) Starter too close to ring gear due to worn engine register hole. If you slacken the starter mounting bolts slightly can the motor be pushed or pulled a little towards or away from engine gear ring?
"touches against the ring gear but does not engage fully and then just free runs at speed, clanging against the edge of the ring gear." Is it possible the second stage of the solenoid is operating too early?
Sounds like something is stopping the pinion from running up the helical rod.
I would suspect the cam which gives the longest valve opening time will operate the inlet valves.
"as you lose the cushioning effect at tdc." The cushioning effect is not present during the TDC at the exhaust/suction stroke with a 4 stroke engine.
"But if I can't find a press, I could look out some scaffolding tube and a heavy hammer." Whatever method you use make sure force is only applied to the appropriate race of the bearings, inner race when fitting to shaft, outer race when fitting to housing. i.e. try not to channel any force through balls or rollers.
" My question is : do they all need to be that tight a fit?" Yes they do. You could refit the bearings and gear with a suitable hammer and some tubular drifts plus something flat and solid to stand the shaft on.
Do you have an image of the gearbox you can post to confirm the presence or lack of a reduction box? Hope this info helps. http://listerparts.co.uk/LM100.html
Do you have an image of the engine and alternator?
There were no electronic governors on 'Startomatic' sets, more like early relay logic to sequence start up/shut down events. All HA generators are designed to operate indoors or in a protective enclosure and require the air ductwork to prevent recirculation of the cooling air.
It sounds like you have a 'Startomatic' house set and associated control gear?
At least 1/3 of the bell housing forms the air inlet as per the image. There is a cast iron spool piece bolted to the flywheel register face with an enlarged portion which the gearbox drive plate bolts to and also provides the correct alternator drive ratio, (high charge at low reves).
Our HA2 was an ex industrial pump with speed lever control and very convenient pump bell housing. Easiest option was to machine the housing to take a PRM260 box
Recommend some sealant on the shaft should there be any 'slack running' wear present.
Forgetting the high torque switch (and possible faults) for a while, is it possibly a case that the slow pre-engage torque is too low to rotate the pinion 1/2 a tooth into engagement?
Unfortunately not very specific, just mentions the threads used on the engine.
Looking at some SR2 starter motors the bolt holes appear to be outside the flywheel starter ring? The SR2 manual also mentions 7/16 unified threads are used on this engine. https://www.ebay.co.uk/i/392815175778?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=392815175778&targetid=908661247816&device=c&mktype=pla&googleloc=9045364&poi=&campaignid=10199631013&mkgroupid=105678538687&rlsatarget=pla-908661247816&abcId=1145987&merchantid=7298464&gclid=EAIaIQobChMI6JqO0-i96gIVArDtCh1PzAMyEAQYAyABEgJB9fD_BwE Our much larger HA2 has blind holes hence the shimming washers.
Canal plans & cruising times website
OptedOut replied to OptedOut's topic in Cruise Diaries & Reports
Thanks. That looks like the site, seems to have changed a bit since I was there last. I will sign up and see if the mapping is as convenient as it was. -
Not sure if this is the correct place to post. A while ago I had a link to a site with canal plans, cruising times and descriptions etc, lost the link in a drive failure. Does anyone know if this site is still about?
