NBDensie
PatronDonate to Canal World
About NBDensie
  • Birthday 13/05/1949
Contact Methods
  • Website URL
    http://www.nbdensie.blog.com
    Cambridgeshire
  • Occupation
    Retired
  • Boat Name
    Densie
  • Boat Location
    Aston Marina
4,220 profile views
NBDensie's Achievements
Collaborator
Collaborator (5/12)
23
  1. The battery in my old Huawei 5577C is dying. 3rd party replacement batteries seem to get bad reviews so I would like to buy a new Mifi. The problem is that the data sheets dont generally say whether the units have an external aerial socket. My existing aerial cables,I believe, are SMA with a TS9 adaptor cable so can deal with both types. Can anyone recommend a modern mid-range Mifi unit with external aerial sockets? Thanks for any suggestions.
  2. Did CRT borrow money to buy property? I think you will find CRT's property was simply transferred over from BW. In any case the % return must have a wide range of error since it depends on the estimated capital value of the property which in some cases could be rather difficult to sell.
  3. Is there now any problem with mooring at Market Harborough outside the basin? I have a possibly false memory that space there had been restricted. Thanks for any recent info.
  4. Isuzu filters are readily available - last time I looked Midland Chandlers sell them and many of the boat yards do also, eg Anglo Welsh at Great Heywood and Gayton Marina. I have been told that Canaline provide Isuzu parts and servicing but have not used them myself.
  5. I had the same problem with my last BSS test. The taps had seized during the winter and unseizing them caused the leaks. The hob was no longer manufactured so parts were unavailable and it had to be replaced. There were no hobs from anywhere with an appropriately sized cut-out. The nearest was a zanussi which required finding someone capable of recutting our granite worktop in situ. The cutout just fitted in the space with about 5mm spare. Nightmare!!
  6. We are due to be inspecting our hull next month for the first time since 2-pack was applied, 5 years ago. It has been suggested that we black it with normal blacking over the 2-pack to provide extra protection. It would also be a cosmetic improvement since the 2-pack has faded to battleship grey. Any views as to whether this is a good or bad idea? Many thanks.
  7. I agree completely with the principle. Now all I need is an expert - any recommendations for one that covers the East Midlands? Cost is not a major issue. However implementation is beyond my experience.
  8. Given the number of things that could go wrong I would be very grateful for any recommendations for someone in the Rugby or Braunston areas who could sort it all out
  9. IWA do hold a "Festival of Water" every year as a cut-down National. Locations have included include Pelsall on the Wyrley & Essington, Northampton, Saul, St Neots, the Erewash, Waltham and most recently Worcester The intention is to choose the outreaches. However feasiblity is limited by the need for a suitable space (eg council-owned park or common) to hold the event and sufficient moorings for up to 100 boats.
  10. Thanks all for your comments..... To answer one point: I have greased the the stern gear with silicone grease through the grease point every 6months-year. Based on your comments, my current thoughts on what to do next...... 1) I need to get the boatyard to recheck that the new engine mounts are appropriate for my engine. Engine mounts specifically stated to be suitable for an Isuzu 35 are available and look like my old ones. The new mounts look different. 2) The engine alignment should be rechecked. 3) Whether a coupling is right for water lubricated stern gear ("cutlass bearing"?) and what sort is open to question. Since the boat worked perfectly well without any stern gear leaks for 10 years with no coupling I think I wont pursue it. 4) I am not clear whether incorrect mounts could cause the increased noise levels and the change in tone. I now find the boat unpleasant to drive so need to do something. Perhaps get the mount situation confirmed first. 5) No one has suggested getting the stern gear checked - perhaps the rubber shaft seals and the prop/bearings should be checked for wear? Hopefully this can be done withoiut taking the boat out of the water.
  11. Recently we have had problems with engine vibration and gearbox "rattle" on our Isuzu 35 powered narrowboat. The local boatyard found that the engine was mis-aligned and the mounts were in poor condition. These were replaced. This seems to have cured the vibration and rattling problems. However, since then the engine has sounded louder and rougher. Previously in deep water and low revs it "purred" not much louder than a car engine. Walkers on the towpath had asked whether the boat was electric! I cant see that happening now. Do new mounts take a while to bed-in or should I look elsewhere for a solution? Note that we have Vetus water lubricated stern gear. When new it did not leak at all but for some years, prior to the vibration problems, it has leaked about a tablespoon (15ml) of water a day. Now it is leaking about 1litre/day, but only leaks when the prop is turning.. I was hoping that stopping the vibration would improve matters but it didnt. Any links to the vibration or is it probably simply a matter of replacing the rubber seals? Any thoughts much appreciated.
  12. 4 years ago Densie was blacked with 2-pack. Since then the colour has steadily got lighter and now the hull is a white/silver colour though it's black when wet. Is this normal? Is this a problem? The coating looks solid with no signs of rust and minimal rubbing. The only downside is that I have had comments to the effect that it looks like it isnt cared-for. Do people normally cover their 2-pack with regular blacking? Many thanks for any thoughts/comments or suggestions.
  13. If it's just to keep the batteries topped up wouldn't a small solar panel with an appropriate controller be sufficient? That is what we used last winter when we could not get to the boat for about 4 months and it worked very well. Personally I would be nervous about keeping a boat powered from the mains unattended for a long period.
  14. Some hire boat companies use Isuzu 35s. I pick up filters for my Isuzu 35 when passing Anglo Welsh at Great Haywood or ABC at Gayton Marina.
  15. I bought a solar battery charger to keep the batteries going during the winter. The panel is wired into the controller which is wired to the battery terminals. To make setup and removal easier I would like to put an unpluggable connector on the cable between the panel and the charger. The right thing for the job seemed to be an Anderson connector which seems to be what caravanners use.. However I cannot see how to connect the cable to the terminals which in turn plug into the connector. They seem to be made of solid stainless steel or perhaps aluminium so there is no way they can be crimped to the cable. Any ideas? Can one buy terminals which can be crimped? Are there other connectors which will do the job? MJany thanks.
