Tractor
2,256 profile views
Tractor's Achievements
Contributor
Contributor (4/12)
21
  1. Sugar Soap, many products are laden with salt (Fairy), silicone additives will make paint repair difficult.
  2. Using a Log Periodic antenna for some time; 'Antenna Finder' provides the right direction to point. Having tried and failed with a signal meter from Screwfix, Is there a recommended device available?
  3. Can there ever be a greater waste of material, time, and effort than this? Loop deck by ‘artist’ Alex Chinneck, sculpture.
  4. Roger Bisby, London Canal System
  5. T Stud, usually made of cast, then welded to a mild steel. Unless care is taken to weld this combination, the join will be subject to corrosion and failure.
  6. A traditional motor for a washing machine has been a 'universal' motor with carbon brushes, speed control provided by a Thyristor Voltage controller. The result is reliable apart from brush replacement after some years and black dust inside the enclosure. The 'Inverter Motor' is a 3 phase device using a combination of permanent magnets an bars within the rotor, with no carbon brushes or commutator. Speed control provided by an 'Inverter', converting a single phase supply into a variable 3 phase supply frequency, for the 'speed' control and reverse. Assuming this machine is for a boat with supply derived from an inverter, then it all gets a bit 'nebulous' as installations are created from a variety of line side components, making the single phase ac from a 12 DC, to be 'mashed about' by the drive system in the washing machine?? The are some success stories here which are useful, but there is a measure of luck getting a working combination; not much help I am afraid but I hope useful?
  7. Mooring between St Johns Lock and Halfpenny Bridge, Lechlade. Watch out for Heffers in this field, they go around in a juvenile 'mob', and will not only lick the boat, and lean on it, but try to eat the rubber window surrounds and the cratch cover A guy will turn up to collect mooring fees, to explain all this but before this be on the look out for the Heffers.
  8. It seems odd that, a mere sum (£650K), can be floating around in some CRT account which has not got a proper justification. With licence and mooring fees increasing, the prospect of maintaining this lifestyle is fast loosing its justification. I have now doubt many will carry on, and maintain this heritage; sadly this may not be for me. Apologies for this, depression will lift tomorrow..
  9. The bridge close to Dukes Cut is a road crossing which is best to remain closed. For the remainder which are not used for access ‘what is the point’ of installing a mechanism which is costly to install, will require maintenance, and is not necessary.
  10. Brushes stick in the holders with corrosion? Give them a wiggle, or rub down, and a good run to clean the commutator.
  11. The motor, to have a suitable rpm would be 6 or possibly 8 pole. The stator however appears small, there was no mention of power rating, it looked to be no more than 2 or 3kW. Interesting project, I envy the ability to code the systems.
  12. I have two pumps connected in parallel, selected by individual pressure switches. If high pressure is achieved, one pump runs, if high pressure is not achieved two pumps run. This is made by adjusting pressure switches.
  13. The water pipe feeding the rads, not the pipe connected to the pump, slip this of slightly until you get a slight spill of water, and push back, secure with hose clip. If header is up to level, this ensures no air in the heat exchanger.
  14. Firefly had a large white gas tank fitted across the bow, forward of the fwd access doors. Leakage could be spilled overboard in the usual way for LPG.
  15. Lift the motor, by releasing the four bolts which secure the motor flange. Check the the drive coupling is secure.
