Everything posted by jonesthenuke
I would also suggest there is a delay in the reading starting to rise after starting to recharge batteries, nothing seems to happen for the first 30 minutes or so, even though a lot of current is going in. Once these behaviours are known, the meter is a useful pice of kit as it's the discharge monitoring that is most useful in my opinion. PS also, they are very easy to set up in comparison to most battery monitors.
With a Smartguage, the gauge indicates what is left in the battery as a percentage. The gauge neither knows nor indicates the capacity (total Ah) of the battery. The gauge works out the state of the battery solely from monitoring the battery terminal voltage over time. I find that when charging has finished and the battery starts to be "used", the gauge stays at 100% for some time and only then starts to drop. Regarding the OP, if the gauge has indicated 100% for some time during charging, then the battery holds as much as it can and I would expect to behave as I have indicated above. Note if your battery bank is old/degraded/sulphated the capacity (the useable Ah) will be far far less than when the batteries were new. The gauge will still go to 100% when the battery has absorbed as much charge as it can, but will drop more quickly under discharge as the capacity of the bank is reduced.
Plum Barlaston Neil Morrissey pub
jonesthenuke replied to Annie cariad's topic in Cruise Diaries & Reports
It's good food at a reasonable price. We stop there every time we pass by. -
The glass in ours was scratched like that for years and did not fail. This year I have bought replacement glass from local glazing company and fitted it, so the old glass is held as spares.
Lovely house, but I agree the noise there is terrible.
If there is an accumulator there will normally be a delay in the pump starting after opening a tap. Increasing the flow resistance with filters will reduce the flow from the tap and consequently increase the time taken to get to the pump cut in pressure. If the flow is adequate it would not seem to be a problem, However 12V pumps that are typically used are not designed with filtration systems in mind so problems may well ensue, especially as the filters foul (and on canal water that would seem likely). If further filtration/water purification is added (as suggested in the OP) then greater problems may well arise with water flow rates if a single pump is used to push water through the whole system
I do not see that being a worthwhile purchase at the price and with the additional issue of the access charge.
Best wishes for the Hip operation.
Re the 10 or 11 thou exhaust clearance, the smaller value was in the earlier manuals and 11 thou in the later versions. I doubt the difference will be of any import. I set ours to 10 thou as that is what is cast into the rocker cover, the engine is circa 1960, the later version of the manual is from (I think) 73.
I agree but it is still the wrong dimension, should be 5 thou inlet and 11 thou exhaust according to the manual.
And these are the torque settings, but note they are in pound-inches not pound-feet And the head should be tightened like this. LW Head tightening.pdf
I suggest following the instructions in the Gardner manual valve clearances.pdf If you need a manual PM me
How to chose a new starter battery?
jonesthenuke replied to pedroinlondon's topic in Boat Building & Maintenance
The blue item in the far bottom left of the photo looks like a diode splitter, if so that needs to be included when drawing the schematic. Also if only one battery is now installed, how has it been connected (so looking at the photo of the original setup may be a distraction?}. -
A regular visit to The Crow locks on the BCNS provides a nice coating of oily tar on the surface of the Hull (though probably dissolves any bitumen blacking at the same time). One of the most polluted sections of canal that we have been to.
There are videos on coal gas manufacture on Youtube. The first one below gives some idea of the byproducts that were collected/made and is thus relevant to the tanker trade (the sound is terrible but just about intelligible). The second gives a more hands on view of the actual gas making.
I agree that water was used to quench the coke, however, my recollection is that the raw gas was passed through water to remove the denser components and reduce the smell. The result would be water saturated with oils, creosote, ammonia etc. This was a valuable source of chemicals and was thus collected and transported to chemical processing works for extraction of useful chemicals
Our Gardner 3LW came from a Smiths crawler crane. Apparently they had two engines, one for the caterpillar tracks and one for the winch, ours being the track engine. No idea what type the other engine was.
Try agricultural merchants like TFM if you want Golden Film and buy 20L rather than 5 (you will use it). Golden Film commands a premium price from many suppliers (morris included if you order direct) Alternatively try Smith and Allan or Westway Oils, look for oils which are both SAE30 and API CC (thus a low detergent oil like Golden Film), plenty of listings on eBay and these will include delivery.
Fungal growth on deck board
jonesthenuke replied to umpire111's topic in Boat Building & Maintenance
Try Wet and Forget, it's a biocide. Follow instructions, do not drink, do not pour in canal, etc etc -
I am curious about the standardised design for BCN gates. Does it utilise a frame faced with planks as shown in your coloured drawing or is it constructed in the current style with thick timbers placed side by side and held together with long transverse bolts? A couple of years ago I have a long conversation with a CRT guy who explained to me that the modern style tend to bow under water pressure as they age and this causes the paddles to stick in their frames. I would appreciate a look at the new design if that is possible.
Correct engine oil for Vetus M4.17
jonesthenuke replied to dan01eb's topic in Boat Building & Maintenance
Just use the oil from Westway, it is the spec you originally asked for.- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
This supplier provides 15W40 in API CC. I have used oil from this supplier before and it's been fine, though I have not used this particular oil as I need a straight SAE30. The price includes delivery. PS The company is adjacent to the Staff and Worcs canal in Wombourne https://www.westwayoils.co.uk/products/15w40-mineral-classic-oil-high-zinc-zddp?_pos=6&_sid=725db1702&_ss=r- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
Land Slip - Easenhall Cutting, Brinklow, Oxford Canal
jonesthenuke replied to RAB's topic in Stoppages
On the Bradley Canal restoration there is a large tree with three trunks below the lowest lock. The tree sits in the bed of the canal where the bywash used to emerge. The CRT ecologist will not allow us to remove it even though it's in the bed of the canal. D'Oh!
