dan01eb
dan01eb's Achievements
Explorer (2/12)
0
Correct engine oil for Vetus M4.17
dan01eb replied to dan01eb's topic in Boat Building & Maintenance
I've finally received the oil I ordered online after waiting for more than a week but it's not the same as the oil I ordered. Could anyone help me out by confirming if the oil I've received is equivalent or still suitable? I ordered the E7 on the first photo and received the E2 in the second photo. Thanks..- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
dan01eb started following Pitting on hull requiring spot welding. Survey , Different sort of boat , Caldon canal and 2 others
What the duck is that? 😅
High zinc?- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
Excellent canal
Thanks for all the help, I'm now more confused about oil specs than when I first asked the question 😅.- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
The engine isn't new, it's approx 2007 and has just over 3000 hours. I'm thinking of ordering the following if the spec looks correct enough? I'm about to service the engine for the first time since acquiring the boat.. Status Car Care 15W40 E7 Super MINERAL ENGINE OIL E7 5L 5 Litre £24.49 15W/40 E7 SL/CI-4 is a top-tier mixed-fleet multi-grade engine oil suitable for use in the latest heavy duty diesel and petrol engines. 15W/40 E7 SL/CI-4 meets the latest ACEA and API performance levels and is formulated for use in Euro III and Euro IV technology vehicles where low SAPS levels are not specified. 15W/40 E7 SL/CI-4 meets exhaust emission standards implemented in 2002, sustains engine performance where exhaust gas recirculation (EGR) is used and can be used with diesel fuels containing up to 0.5% sulphur. Wide Ranging Fleet Product for Diesel and Petrol Engines Excellent Protection for European, US and Japanese Engines. Protects against Wear and Ring Sticking at High Temperatures, maintaining Engine and Oil Performance. Low Oil Consumption and Extended Oil Drain Intervals Excellent High and Low Temperature Performance Long Lasting Dispersant, Anti-wear and Corrosion Protection API SL/CI-4 ACEA: A3/B3, A3/B4, E3, E5, E7 Cummins: CES 20071, 72, 76, 77, 78 Mack: EO-M Plus MB: 228.3, 229.1 VW: 505.00 quality Volvo: VDS-3 MAN: M3275 RVI: RLD Global: DHD-1- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
Hi, I'm trying to identify the correct engine oil for a Vetus m4.17. The manual says CC or CD grade 15w - 40 mineral oil. Could anyone confirm if the part synthetic from Halfords would will be ok? If not hopefully the status car care E7 mineral is correct? Cheers https://www.halfords.com/motoring/engine-oils-and-fluids/engine-oil/halfords-15w40-part-synthetic-oil-2---5-litres-285286.html https://shop.statuscarcare.com/product/status-car-care-15w40-e7-super-mineral-engine-oil-e7-5l-5-litre/
- 31 replies
- engine oil
- oil
(and 3 more)
Tagged with:
It's my first time buying a NB. I found that after I'd viewed around 6 to 8 boats I could compare them against each other. After viewing approx 15 boats I ended up going back to one of the previously viewed boats and liked it more than I did on the first viewing. To get an idea if you can get to a marina/broker with a few boats and view 2 or 3 at a time it's obviously easier and quicker than 2 or 3 separate viewings at different locations.
Is there anywhere that can black the bottomplate or just Debdale? The stern tube post and 6 patches of pitting on the hull are being welded this weekend. Along with bitumen blacking and 8 new anodes being fitted. However the bottomplate isn't being blacked because the work is being done in a drydock. I'll hopefully be able to get her out the water again in around a year's time to be inspected, then I'll either arrange for another blacking including the bottomplate or Debdale if affordable at the time.- 37 replies
- narrowboat
- survey
- (and 6 more)
The educational boat trip from the lift to Northwich town and back is good. Not a bad little tour boat either.
The survey report has arrived. There aren't any recommendations but quite a few advises. Some of the results are attached. Any input would be appreciated. Thanks- 37 replies
- narrowboat
- survey
- (and 6 more)
She's 57ft, 2007 Mike Christian with Beta 38 engine. Well equipped. Paint and interior in reasonable to good condition. Will hopefully get the full survey report later today to find out the amount and depth of the pitting.- 37 replies
- narrowboat
- survey
- (and 6 more)
Almost certain. Why do you ask? Would pitting and needing welding not usually be expected on a 16 year old boat?- 37 replies
- narrowboat
- survey
- (and 6 more)
I'm not sure yet, I'll have to wait for the full survey report in the next couple of days. I just saw pitting and welding and feared the worst.- 37 replies
- narrowboat
- survey
- (and 6 more)
dan01eb posted a topic in Boat Building & Maintenance
Hi, I'm in the process of buying my first narrowboat to live aboard. It was surveyed today and I've just received a quick update from the surveyor saying there's some pitting on the hull that needs spot welding. I'll receive the full survey report in the next couple of days. The boat is 16 years old and is for sale for just over 50k. Is pitting that requires spot welding a serious problem? Thanks in advance.- 37 replies
- narrowboat
- survey
- (and 6 more)
