Roadsteam
Everything posted by Roadsteam
  1. Natural England wont permit the required bank repairs there due to water voles is what i hear. Now the farmer has fenced the4 field with barb wire you cant even utilise the gaps in the hedge to walk along the field.
  2. But if the sign has not got the CRT header on it its not official so as said bin it.
  3. When checking the oil level make sure that the reverse box dipstick is the shorter of the two. I had an LH150 that would not come out of forward and investigation showed that both boxes had dipsticks for the reduction box, result that even on the high mark the oil pump was sucking air.
  4. When were the fuel filters last changed? it could be fuel starvation if it has got worse as time has gone on or has it always been like it?
  5. Lock 2 had a binding top offside paddle last week, maybe that has jammed up.
  6. Metal on metal pipe joints no goo needed unless its taper threads then a turn of PTFE tape.
  7. Edit. What Tim leach says as his reply appeared while i composed my reply
  8. In Oxford and Banbury i have actualy been hit by cyclists passing too close and too fast with no warning of their approach from behind and its my fault acording to them.
  9. Strapping 20 tons of boat with the rope around its neck will see how well its anchored down.
  10. Use it as a bollard, woops its fallen over.
  11. HR, ST etc, no problem with returning to the filter, its how ours were piped from the factory.
  12. Roadsteam
    Oil for SR2
    API CC, any higher will not be a good idea, i had to glaze bust and re ring a bunch of hand crank listers which had been run on Castrol RX Super 15w40 which was something like API CE. I removed an oil filler cap on a running engine which was a bit of a pig to start(they all were) and it shot the filler cap the length of the workshop followed by a blast of oil which left a black sprayed line on the underside of the roof about 10ft above. All the engines were badly glazed in the bores. The glaze bust and re-ring cured the starting while using the manufacturers recomended spec of API CC.
  13. Roadsteam
    3J5
    I asked because i got the chap with it at Llandudno to demonstrate the reversing for me and i thought that it might interest some to see it. To reverse it without altering the revs setting you wind the direction handwheel(painted red) to mid gear and just before the engine stops turning wind rapidly into gear the other way giving the start air valve a quick lift to help. I believe that at full air pressure the built in linkage from the direction control should be enough. The Pochins engine is the other of the pair also pictured on here.
  14. Roadsteam
    3J5
  15. Roadsteam
    3J5
    Anybody got any footage of the starting and reversing of a 3J5.
  16. You can even buy a tractor that has snapped in half!
  17. the access to Kings Sutton lock is the just an unbound stone farm track. For 3K a year i would want tarmac.
  18. Its all i have ever seen and that includes modern boats.
  19. Rose Narrowboats have a slipway which would probably be cheaper than a dry dock and from your route you are passing right thro the yard.
  20. Any idea which farm or the name of the farmer?
  21. Ron Withey is the steersman in the pic, the other is Simon Ainley waterway manager for the OX/GUCC patch. When Bramble left Buckby where it had been residing on the bank it went to Bob Knowles's yard at Leicester along with Centauri, the bottom plate had gone thro at the bow on Bramble. After a while both then went from Knowles's yard to BW Newark and then disposal.
  22. Absolutely no CRT showers or toilets between Hawsbury and Braunston.
  23. Quite right as the other year the idiots kept piling thro even tho there was noware to go and caused absolute caos, hence now when one lock is out the whole flight gets restricted.
  24. CRT do know, my informed source is an employee who was with the engineer when they did an annual length inspection the other week.
  25. Its the summit pound not far from Marston Doles and its on the uphill side of the cut. In fact its the same farmer who has several times blocked the canal due to a dispute with BW/CRT over a leak he claims is flooding his field, but has never been seen leaking as i was told by somebody very in the know. The pictures dont show it but the nikospan soft bank protection has been torn out and not replaced.
