rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 1 minute ago, Flyboy said: Forget it. The pitch of an M10 bolt is too fine and the thread depth is too shallow. I was just trying an m10 tap in softwood(its the only size tap I have), to see if I could tap it.If I do tap the wood it will be m5 or m6 Link to comment Share on other sites More sharing options...
Flyboy Posted April 26, 2018 Report Share Posted April 26, 2018 Just now, rusty69 said: I was just trying an m10 tap in softwood(its the only size tap I have), to see if I could tap it.If I do tap the wood it will be m5 or m6 Even worse. Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 (edited) 1 minute ago, Flyboy said: Even worse. Oh. So you reckon tapping isnt the way to go? Edited April 26, 2018 by rusty69 Link to comment Share on other sites More sharing options...
nicknorman Posted April 26, 2018 Report Share Posted April 26, 2018 1 minute ago, rusty69 said: Oh. So you reckon tapping isnt the way to go? Why would you want to tap wood (apart from a xylophone!), wood screws were invented to securing things to wood, why try to re-invent the wheel? Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 (edited) 4 minutes ago, nicknorman said: Why would you want to tap wood (apart from a xylophone!), wood screws were invented to securing things to wood, why try to re-invent the wheel? So I don't have to drill more holes in the cabin side to secure the battens that are currently held in with the screws.I would need to do this if I use machine screws instead of woodscrews. The battens beneath may not be good enough to excepts a bigger screw, hence the machine screw idea. Simples (not). ETA I spose I could plug the wood beneath with a wooden plug and glue and use the same size screws as I currently have. Edited April 26, 2018 by rusty69 Link to comment Share on other sites More sharing options...
Flyboy Posted April 26, 2018 Report Share Posted April 26, 2018 1 minute ago, rusty69 said: Oh. So you reckon tapping isnt the way to go? Tapping into wood is not an option. 1 Link to comment Share on other sites More sharing options...
nicknorman Posted April 26, 2018 Report Share Posted April 26, 2018 2 minutes ago, rusty69 said: So I don't have to drill more holes in the cabin side to secure the battens that are currently held in with the screws.I would need to do this if I use machine screws instead of woodscrews. The battens beneath may not be good enough to excepts a bigger screw, hence the machine screw idea. Simples (not) Ok well, still a bad idea, sorry! Just use wood screws! Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 1 hour ago, rusty69 said: Anyone tried tapping softwood? ETA. Just tried tapping an m10 hole in a piece of pine. Looks pretty good. I wonder if it will be good enough! any thoughts anyone? I wouldnt tap it and just drill out to 8mm and screw straight into the timber. it does work as i have done it but with M6 machine screw. Not sure how good a grip it will give though for pulling in the frame. Experiment time Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 2 minutes ago, W+T said: I wouldnt tap it and just drill out to 8mm and screw straight into the timber. it does work as i have done it but with M6 machine screw. Not sure how good a grip it will give though for pulling in the frame. Experiment time Thanks Wayne . Have decided to drill holes in cabin to hold battens and drill and tap cabin to except m6 flanged button head machine screws. Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 How about if you can and dont mind the look or can cover them, not to obtrusive though. Use these Interscrews on the inside and which ever SS machine screw head type on the outside http://www.interscrew.co.uk/ Pull it nice and tight with M6 screws. Link to comment Share on other sites More sharing options...
TheBiscuits Posted April 26, 2018 Report Share Posted April 26, 2018 2 hours ago, rusty69 said: Anyone tried tapping softwood? ETA. Just tried tapping an m10 hole in a piece of pine. Looks pretty good. I wonder if it will be good enough! any thoughts anyone? It is not only the pine that is tapped! 1 Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 3 minutes ago, W+T said: How about if you can and dont mind the look or can cover them, not to obtrusive though. Use these Interscrews on the inside and which ever SS machine screw head type on the outside http://www.interscrew.co.uk/ Pull it nice and tight with M6 screws. There is no access to the back (inside) of the window frame as it is covered with the wooden frame, so not sure they would work. Thanks though Link to comment Share on other sites More sharing options...
David Mack Posted April 26, 2018 Report Share Posted April 26, 2018 11 minutes ago, W+T said: http://www.interscrew.co.uk/ Also known as sex bolts !!! Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 12 minutes ago, rusty69 said: There is no access to the back (inside) of the window frame as it is covered with the wooden frame, so not sure they would work. Thanks though I was thinking more to get screws to go all the way through to the other side to the Interscrews on the inner cabin side. 4 minutes ago, David Mack said: Also known as sex bolts !!! You been on the cut to long i think lol Link to comment Share on other sites More sharing options...
Neil Smith Posted April 26, 2018 Report Share Posted April 26, 2018 Drill the cabin side to 5.5mm and use 5mm stainless or brass wood screws, you could do as you said and plug the holes in the battens first. Neil Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 2 minutes ago, W+T said: 16 minutes ago, rusty69 said: I was thinking more to get screws to go all the way through to the other side to the Interscrews on the inner cabin side. Ah. I see what you mean.Yes it would work, not sure it would look too good though. 20 holes per window too! 2 minutes ago, Neil Smith said: Drill the cabin side to 5.5mm and use 5mm stainless or brass wood screws, you could do as you said and plug the holes in the battens first. Neil Yep.They would need plugging with wood, or perhaps injecting epoxy and drilling. Will go down the drill and tap route and see how it goes. Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 2 minutes ago, rusty69 said: Ah. I see what you mean.Yes it would work, not sure it would look too good though. 20 holes per window too! Yep.They would need plugging with wood, or perhaps injecting epoxy and drilling. Will go down the drill and tap route and see how it goes. Head banging annoying with a twisted wrist and no way of lifting a pint after a few hundred tapped holes lol. 1 Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 1 minute ago, W+T said: Head banging annoying with a twisted wrist and no way of lifting a pint after a few hundred tapped holes lol. Its only two leaking at the moment, so I will tackle them as and when they leak. Hopefully two a year = 40 holes= well earned pint with a straw (if Mrs May hasn't banned them) Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 3 minutes ago, rusty69 said: Its only two leaking at the moment, so I will tackle them as and when they leak. Hopefully two a year = 40 holes= well earned pint with a straw (if Mrs May hasn't banned them) Eee by eck lad this is a real straw for our drinks ( Cider ) no namby pamby plastic tubes. http://www.ecostrawz.co.uk/titanium-drinking-straw-straight-337-p.asp 1 Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 (edited) 5 minutes ago, W+T said: Eee by eck lad this is a real straw for our drinks ( Cider ) no namby pamby plastic tubes. http://www.ecostrawz.co.uk/titanium-drinking-straw-straight-337-p.asp Stainless here x 4 with brush https://www.amazon.co.uk/MIU-Reusable-NON-TOXIC-Stainless-including/dp/B00EUVPRPI/ref=pd_lpo_vtph_bs_tr_t_1?_encoding=UTF8&psc=1&refRID=MWJ4C37WJMRAXEJW2NJ8 Edited April 26, 2018 by rusty69 1 Link to comment Share on other sites More sharing options...
W+T Posted April 26, 2018 Report Share Posted April 26, 2018 9 minutes ago, rusty69 said: Stainless here x 4 with brush https://www.amazon.co.uk/MIU-Reusable-NON-TOXIC-Stainless-including/dp/B00EUVPRPI/ref=pd_lpo_vtph_bs_tr_t_1?_encoding=UTF8&psc=1&refRID=MWJ4C37WJMRAXEJW2NJ8 Is the brush to clean out residue crushed Co-Codamol out the straws ? 1 Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 Whilst the windows were out, I have rubbed down the wooden frames. Anyone used wax instead of varnish? e.g https://www.amazon.co.uk/Liberon-BBPWMO150-150ml-Bison-Paste/dp/B000TAPBDW/ref=sr_1_1?ie=UTF8&qid=1524769539&sr=8-1&keywords=liberon+wax+polish Link to comment Share on other sites More sharing options...
WotEver Posted April 26, 2018 Report Share Posted April 26, 2018 49 minutes ago, David Mack said: Also known as sex bolts !!! From that link: Socket Nuts, Tube Nuts, Connector Bolts, Clamp Bolts, Sex Bolts, Barrel Nuts, Screws with Internal Threads, Sleeve Nuts etc 1 Link to comment Share on other sites More sharing options...
WotEver Posted April 26, 2018 Report Share Posted April 26, 2018 (edited) 16 minutes ago, rusty69 said: Whilst the windows were out, I have rubbed down the wooden frames. Anyone used wax instead of varnish? Many times. It’s unsuitable for anything that’ll regularly get wet. Many of those panelled Victorian rooms with very dark oak are that colour as a result of wax finishes. Smoke from coal fires plus dust settles on the wood and sticks to the wax. Another coat of wax seals it in. Keep doing that for 100 years and you end up with that dark colour. Scrub the wood with white spirit and it comes back a lovely golden colour like it should be. Edited April 26, 2018 by WotEver Spillung 1 Link to comment Share on other sites More sharing options...
rusty69 Posted April 26, 2018 Author Report Share Posted April 26, 2018 2 minutes ago, WotEver said: 17 minutes ago, rusty69 said: Many times. It’s unsuitable for anything that’ll regularly get wet. Any good for window frames then on a boat? I hate varnishing! Link to comment Share on other sites More sharing options...
