Dave Bebb Posted December 6, 2017 Report Share Posted December 6, 2017 Quote Quote Hi all I need a battery charger to charger 4 x 110 battery's and have them on permanenty hooked up to 240 volt pod I have this one but not sure if I can leave it on permanently thanks Link to comment Share on other sites More sharing options...
Tony Brooks Posted December 6, 2017 Report Share Posted December 6, 2017 (edited) If the photo shows all the controls and indicators then no, do not leave it permanently on because it is probably an old car one that has no voltage control so given time it would ruin the batteries. The web seems to indicate it has a crude meter the other side of the lable, that is another indication its not voltage regulated. You can use it but monitor the voltage. When it gets to about 14.5 or 14.6 turn it off but NOTE the batteries may not be fully charged. If left on the voltage is likrly to keep rising until you either load the batteries or you boil the acid. Edited December 6, 2017 by Tony Brooks chage 14.5 to 24.6 to 13.5 to 14.6 Link to comment Share on other sites More sharing options...
mross Posted December 6, 2017 Report Share Posted December 6, 2017 (edited) It would be better to have a dedicated marine battery charger. That looks more like a vehicle charger and might even stop charging when the battery is 'full'. You want one designed to keep the batteries topped up on a long-term basis. And these are normally left connected all the time when mains is available. Can you photograph the label, possibly on the back, with the full model number and specs. Or the instructional manual page showing these? Looking on the internet I could not find that exact model. But similar ones seem OK to leave connected long term. But it should be replaced soon to give your batteries the care they need. Your charger is not rated to charge 4 x 110Ah batteries, more like 225Ah i.e. it is too small. Here is the manual for the closest current model to yours http://www.absaar.com/v2/en/products/professionnal-chargers Edited December 6, 2017 by mross Link to comment Share on other sites More sharing options...
Dave Bebb Posted December 6, 2017 Author Report Share Posted December 6, 2017 1 hour ago, Tony Brooks said: If the photo shows all the controls and indicators then no, do not leave it permanently on because it is probably an old car one that has no voltage control so given time it would ruin the batteries. The web seems to indicate it has a crude meter the other side of the lable, that is another indication its not voltage regulated. You can use it but monitor the voltage. When it gets to about 14.5 or 14.6 turn it off but NOTE the batteries may not be fully charged. If left on the voltage is likrly to keep rising until you either load the batteries or you boil the acid. Thanks Link to comment Share on other sites More sharing options...
Dave Bebb Posted December 6, 2017 Author Report Share Posted December 6, 2017 Thanks lads looks like Ii will be looking for a new battery charger one that can charge 4 110 and that can be permanently Link to comment Share on other sites More sharing options...
mross Posted December 6, 2017 Report Share Posted December 6, 2017 Tony is spot on as usual. Here it says that charger must be disconnected after use. http://www.absaar.com/v2/en/products/professionnal-chargers shows that it is a 'Standard' type add here, in the generic ABSAAR manual it defines 'Standard' Link to comment Share on other sites More sharing options...
mross Posted December 6, 2017 Report Share Posted December 6, 2017 (edited) What sort of budget do you have? Do you cruise a lot or basically stay in one place with mains available? Forum members will then suggest suitable chargers. Just don't buy one with crocodile clamps, you need one connected permanently. Edited December 6, 2017 by mross 1 Link to comment Share on other sites More sharing options...
Richard10002 Posted December 6, 2017 Report Share Posted December 6, 2017 If I was buying a battery charger today I’d probably go for one of Sterling’s Pro Charge Ultra. 40A or above for a 440Ah bank. Link to comment Share on other sites More sharing options...
MtB Posted December 6, 2017 Report Share Posted December 6, 2017 19 minutes ago, Richard10002 said: If I was buying a battery charger today I’d probably go for one of Sterling’s Pro Charge Ultra. 40A or above for a 440Ah bank. Yes but you're loaded. You've seen the price of them?! Link to comment Share on other sites More sharing options...
mross Posted December 6, 2017 Report Share Posted December 6, 2017 £300 plus! What would you buy MtB? Link to comment Share on other sites More sharing options...
rusty69 Posted December 6, 2017 Report Share Posted December 6, 2017 2 minutes ago, mross said: £300 plus! What would you buy MtB? A whispergen and two dodgy smartgauges.....pay attention 1 Link to comment Share on other sites More sharing options...
mross Posted December 6, 2017 Report Share Posted December 6, 2017 (edited) https://sterling-power.com/collections/clearance/products/bb1260-battery-to-battery-charger-very-small-crack-on-plastic-casing-new-unit?variant=44923987541 for £150 30a or £200 60A used, 6-month warranty. Prices include VAT as do all prices on their website. Many vendors quote prices ex VAT so bear in mind if shopping around. Edited December 6, 2017 by mross Link to comment Share on other sites More sharing options...
MtB Posted December 6, 2017 Report Share Posted December 6, 2017 15 minutes ago, mross said: £300 plus! What would you buy MtB? I bought a Sterling Pro Charge Ultra 24v 30a. This is how I know Richard10002 must be loaded! 1 1 Link to comment Share on other sites More sharing options...
DHutch Posted December 7, 2017 Report Share Posted December 7, 2017 As said, to advise we really need to know more about when and for what the OP wants to use it. Obviously his requirements include being able to be left on permanently, for a reasonable size bank. If we then know the use and time between us we can suggest if a smaller 'maintaince' type charger such as a CTEK is enough just to keep it up, or if they need something with a bit more poke to provide good charge, 20-40amp say. If you're pulling the power out at the same time, maybe even with an inverter (?) you can go even bigger, assuming the 240vac supply can keep up. Daniel Link to comment Share on other sites More sharing options...
Sea Dog Posted December 7, 2017 Report Share Posted December 7, 2017 (edited) 53 minutes ago, DHutch said: As said, to advise we really need to know more about when and for what the OP wants to use it. Obviously his requirements include being able to be left on permanently, for a reasonable size bank. If we then know the use and time between us we can suggest if a smaller 'maintaince' type charger such as a CTEK is enough just to keep it up, or if they need something with a bit more poke to provide good charge, 20-40amp say. If you're pulling the power out at the same time, maybe even with an inverter (?) you can go even bigger, assuming the 240vac supply can keep up. Daniel You have a point Daniel. Since the demise of my Mastervolt inverter/charger, with my batteries not too far from full on commencement, my little Ctek mxs5.0 has kept a 400Ah bank floating nicety. It also kept up with my 12V domestic needs too, although it was getting a bit warm when the fridge was drawing current so I took the fuse out. Of course, the batteries provide a buffer if the 12v draw exceeds the power supply capacity temporarily. I now have a Victron 30amp Bluesmart charger, which has no issues keeping up with my 12v domestics at all. My previous charger was 100 amp, but I've never needed that sort of current from my shore supply charger. Normally I arrive at my berth with a good charge level, so the batteries are back to float pretty quickly. If a charge from very low is required, it'll either take a bit longer at 30 amps or my alternator can do the bulk of the work. The only time when a large charge current is required routinely is when the batteries are depleted overnight when out cruising when, of course, the alternator does the work and the charger is a passenger. The exception to this might be those who perhaps cruise less frequently and use a generator to power their charger. Edited December 7, 2017 by Sea Dog Last sentence. Link to comment Share on other sites More sharing options...
Dave Bebb Posted December 7, 2017 Author Report Share Posted December 7, 2017 53 minutes ago, DHutch said: As said, to advise we really need to know more about when and for what the OP wants to use it. Obviously his requirements include being able to be left on permanently, for a reasonable size bank. If we then know the use and time between us we can suggest if a smaller 'maintaince' type charger such as a CTEK is enough just to keep it up, or if they need something with a bit more poke to provide good charge, 20-40amp say. If you're pulling the power out at the same time, maybe even with an inverter (?) you can go even bigger, assuming the 240vac supply can keep up. Daniel I need a charger for permanently conectod when not on the nb Link to comment Share on other sites More sharing options...
Sea Dog Posted December 7, 2017 Report Share Posted December 7, 2017 2 minutes ago, Dave Bebb said: I need a charger for permanently conectod when not on the nb Then see my post above which crossed with yours. Hope thats helpful Link to comment Share on other sites More sharing options...
smileypete Posted December 7, 2017 Report Share Posted December 7, 2017 For just keeping a few leisures topped up on shoreline a 10A or 20A Numax\Electroquest one should do: https://electroquestuk.com/chargers/leisure-battery-chargers-marine-battery-chargers/fully-automatic-marine-leisure-battery-charger-12v-10a https://www.tayna.co.uk/Numax-Commercial-Battery-Charger-20A-P6139.html Link to comment Share on other sites More sharing options...
mross Posted December 7, 2017 Report Share Posted December 7, 2017 If he is permanently on the mains he doesn't actually need a charger or any batteries. Link to comment Share on other sites More sharing options...
smileypete Posted December 7, 2017 Report Share Posted December 7, 2017 24 minutes ago, mross said: If he is permanently on the mains he doesn't actually need a charger or any batteries. Sure you can buy a decent 12V power supply for buttons these days, plenty for LED lights, 12V fridge and water pump; but most (98%?) of boaters want something 'fit and forget' and are prepared to pay for it. Link to comment Share on other sites More sharing options...
mross Posted December 7, 2017 Report Share Posted December 7, 2017 7 minutes ago, smileypete said: Sure you can buy a decent 12V power supply for buttons these days, plenty for LED lights, 12V fridge and water pump; but most (98%?) of boaters want something 'fit and forget' and are prepared to pay for it. You may have missed my point If he is on a permanent, residential mooring he does not need 12v. He could have only 240v sockets and dispense with batteries, inverters and chargers. We need the OP to tell us how he uses the boat. I suspect he does not understand why we would like to know all this. Without such info we can't offer him much useful advice. Link to comment Share on other sites More sharing options...
rusty69 Posted December 7, 2017 Report Share Posted December 7, 2017 7 minutes ago, mross said: You may have missed my point If he is on a permanent, residential mooring he does not need 12v. He could have only 240v sockets and dispense with batteries, inverters and chargers. We need the OP to tell us how he uses the boat. I suspect he does not understand why we would like to know all this. Without such info we can't offer him much useful advice. He doesn't need an engine either, perhaps have that removed and use the space to stable a horse Link to comment Share on other sites More sharing options...
smileypete Posted December 7, 2017 Report Share Posted December 7, 2017 (edited) 27 minutes ago, mross said: You may have missed my point If he is on a permanent, residential mooring he does not need 12v. He could have only 240v sockets and dispense with batteries, inverters and chargers. We need the OP to tell us how he uses the boat. I suspect he does not understand why we would like to know all this. Without such info we can't offer him much useful advice. I would say 99% of canal and river boats have a 12V pump and some 12V lights (or 24V of course), so my general advice should be appropriate. If on a mains supplied mooring 24/7 with such a boat, then yes, you don't neeeeed a £££££ charger, but.... If people have some wierd and wonderful setup, chances are they don't need advice. Edited December 7, 2017 by smileypete Link to comment Share on other sites More sharing options...
