Days Won
3
Everything posted by mross
'Time period' filter defaulted to 365 days?
mross replied to mross's topic in Technical & Account Support
We had her for two years; we also moored at Yelvertoft. But now we live in the far north of Scotland it became impractical so we sold. The engine burnt a lot of oil so it was quite smokey! Did the air-conditioning work when you had her? -
When did you own Anonimity? Martin Ross -
Thanks. I also complained to ASA and heard from them recently. I did some more reading and found that IR heaters are quite successful in high-ceiling warehouses but people still need to get the air temp up to 21C or so to be comfortable. Somewhere in their ads they say the panel heaters operate at a surface temperature of 22 to 24C. So they can't radiate any heat to a human body at 37C !!! They are just convectors.
OP replied to a PM saying engine was running. It was an oil pipe, not a fuel pipe. I don't think he's been back since!
- 7 replies
- russell newbery
- dm2
(and 1 more)
Tagged with:
Do you mean the decompressor? You don't need to touch this. Leave it in the running position. 20psi oil pressure is OK. Can you try the extra fuel? Lift the brass flap on the fuel rod and make sure the rod is free to move. It's normal to oil this daily.
- 7 replies
- russell newbery
- dm2
(and 1 more)
Tagged with:
I do not understand this bit; what top?
- 7 replies
- russell newbery
- dm2
(and 1 more)
Tagged with:
Anyone know...can an oil fired range run on Red Diesel?
mross replied to 4LeggedGrasshopper's topic in Living Afloat
"Oil Used in Central Heating Just about all oil fired central heating used in Britain on a domestic level uses 28sec oil. This oil is sometimes referred to as Kerosene. The "sec" part of the oil description refers to seconds. This seconds part is used to define the viscosity (or thickness) of the oil. Originally this was measured by the time it takes for a ball bearing of a set size and diameter to pass through a set distance of the oil. 28sec oil burns very cleanly leaving minimal deposits such as smoke and soot on afterburn. 28sec oil can also be used in popular kitchen ranges like AGA. The other type of oil that can be used in a domestic situation is 35sec oil. You may be thinking, "how do I tell these two oil types apart?" There is quite an easy way of doing so by checking the colour of the oil: 28sec Oil = Yellow 35sec Oil = Red" http://www.diydoctor.org.uk/projects/centralheatingoil.htm So, the answer is probably 'yes'. But, as others say, 'get advice from the supplier'- 20 replies
- stove; oil
- heating
(and 1 more)
Tagged with:
In post 51, you said, "When Keeping Up posed the fuel question, he provided a formula in which the rate of consumption was proportional to speed." but he didn't, he said speed cubed.
So, are you admitting that you were mistaken? Your quote is exactly what I said!
He never said this! He said, ab initio, that consumption was proportional to RPM cubed. We are agreed that RPM is proportional to speed. ( roughly)
What's the name of that contactor sensor thingy in a washing machine? It's used instead of a push-button on/off switch. Something like a true power device? This is so pernickety it can prevent the machine from switching on.
Ergs anyone?
Joules are not dependant on volts; 10MJ is 10MJ regardless of volts. Our meters already measure Joules but a calibrated in kWh. The meters measure true power, so they take account of volts amps and power factor.
some boats are 24V
kJ or MJ would be the most correct units to use for energy. As you know, 1 kWh is equal to 1,000 joules per second for one hour or 3,600,000 Joules = 3.6MJ. MJ's work equally for any voltage, unlike Amp-hours.
Were they definitely Brillo pads? Some people put scoureers in their kettles inhard water areas to trap the scale. But, generally, they were of stainless steel. I think Brillo pads would make the tea pink and soapy.
I have been reading up on Legionnaires all morning. Here is a source of balanced, evidence-based medical research which supports my contention that showers are not dangerous. It is now suggested that a common route to infection is aspiration, where fluid is accidentally taken into the lungs by people whose choking reflex is defective or absent. Smoking being a big risk factor. Where people caught LD in a hospital type setting they always found Legionella in the water system. In some countries it is mandatory to test nearby cooling towers for the bacterium and this is why cooling towers were implicated so often, test of water taps was not mandatory so the true source was often missed. There are many different species (50 plus) and nowadays the true source can be more readily identified. This is a copy of my January post in a similar thread.
Most of us; UK tap water, containing traces of chlorine, IS sterile.
Marinas are still allowed to sell FAME-free diesel.
Now you are getting there!
The mother of the idiot is always pregnant!
NO! Amp-hours have time but are NOT a rate.
No, 3.33Ah is a quantity! I suspect you meant to type 3.33A.
20a for six hours is a quantity, not a rate! Anyway, you should listen to TB as he knows his onions. You will have to understand Ampere-hours or Watt-hours if you want to understand batteries.
Crocodile clips will cause a rapid build up of white salts if there's any humidity in the air. This corrodes away the battery posts. This is why it is better to have permanent connections. Also putting them on/taking them off created sparks. Charging batteries produce hydrogen. In a confined space this is unwise..........................
