nicknorman Posted November 24, 2017 Report Share Posted November 24, 2017 16 minutes ago, Mike the Boilerman said: As explained in post 37 Oh yes, so you did. But that was hours ago and anyway I explained it better Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 8 minutes ago, nicknorman said: Oh yes, so you did. But that was hours ago and anyway I explained it better Ah yes I forgot. You youngsters no longer read the threads here before posting. Is that considered OK over at chunderboat too? Link to comment Share on other sites More sharing options...
RLWP Posted November 24, 2017 Report Share Posted November 24, 2017 1 hour ago, Tony Brooks said: Thanks Richard. It's one of those things that are obvious when you think about it, but not at first glance. Richard Link to comment Share on other sites More sharing options...
nicknorman Posted November 24, 2017 Report Share Posted November 24, 2017 22 minutes ago, Mike the Boilerman said: Ah yes I forgot. You youngsters no longer read the threads here before posting. Is that considered OK over at chunderboat too? My problem is that my head is so big and full of clever stuff that sometimes the stuff in there gets lost and I can’t find it! 1 Link to comment Share on other sites More sharing options...
cereal tiller Posted November 24, 2017 Report Share Posted November 24, 2017 12 minutes ago, nicknorman said: My problem is that my head is so big and full of clever stuff that sometimes the stuff in there gets lost and I can’t find it! Is it ever a Peaceful Place? Link to comment Share on other sites More sharing options...
nicknorman Posted November 24, 2017 Report Share Posted November 24, 2017 3 minutes ago, cereal tiller said: Is it ever a Peaceful Place? Sometimes. But echoey, like a large cave. ”Hello”? helloelloelloelloello Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 1 hour ago, nicknorman said: Sometimes. But echoey, like a large cave. ”Hello”? helloelloelloelloello So if it's all echo-y in there, it must be empty. So where is your brain? Ooh I've just figured it out! Link to comment Share on other sites More sharing options...
Ex Brummie Posted November 24, 2017 Report Share Posted November 24, 2017 3 hours ago, nicknorman said: The problem is that in order to encourage the flow to go down the 10mm pipes to the rads at the end of the run, you will have to throttle the rads near the boiler by turning down their lock shield valves (ie balancing the system) and so the point of the larger bore pipes to the rads nearer the boiler is somewhat lost. It would have been better if the near rads were in 10mm and the distant ones in 15mm but hey ho, it is what it is! Throttling down the radiators near the boiler, i.e balancing, only slows down the flow through the radiator. There is still a larger bore pipe through the flow and return to protect the boiler. Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 5 minutes ago, Ex Brummie said: Throttling down the radiators near the boiler, i.e balancing, only slows down the flow through the radiator. There is still a larger bore pipe through the flow and return to protect the boiler. I'm still totally lost as to why the boiler needs 'protecting'. Protecting from what, exactly? Link to comment Share on other sites More sharing options...
rusty69 Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, Mike the Boilerman said: I'm still totally lost as to why the boiler needs 'protecting'. Protecting from what, exactly? the boilerman 1 Link to comment Share on other sites More sharing options...
Tacet Posted November 24, 2017 Report Share Posted November 24, 2017 3 hours ago, RLWP said: It's one of those things that are obvious when you think about it, but not at first glance. Richard For the domestically inclined, put one's hand to block the vacuum cleaner hose and you'll hear the revs rise. 1 Link to comment Share on other sites More sharing options...
cereal tiller Posted November 24, 2017 Report Share Posted November 24, 2017 15 minutes ago, rusty69 said: the boilerman Assumed it was the Bogeyman? Link to comment Share on other sites More sharing options...
rusty69 Posted November 24, 2017 Report Share Posted November 24, 2017 1 minute ago, cereal tiller said: Assumed it was the Bogeyman? Fungus the....? Link to comment Share on other sites More sharing options...
cereal tiller Posted November 24, 2017 Report Share Posted November 24, 2017 1 minute ago, rusty69 said: Fungus the....? MtB is clean Shaven these Days Link to comment Share on other sites More sharing options...
Ex Brummie Posted November 24, 2017 Report Share Posted November 24, 2017 (edited) 51 minutes ago, Mike the Boilerman said: I'm still totally lost as to why the boiler needs 'protecting'. Protecting from what, exactly? low flow causing overheating. Edited November 24, 2017 by Ex Brummie Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, Ex Brummie said: low flow causing overheating. You have some really weird ideas about heating. Link to comment Share on other sites More sharing options...
Ex Brummie Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, Mike the Boilerman said: You have some really weird ideas about heating. I might think the same about you. Lack of flow through a pressure jet low water content oil boiler will damage it. Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 1 minute ago, Ex Brummie said: I might think the same about you. Lack of flow through a pressure jet low water content oil boiler will damage it. What a load of borrox. Link to comment Share on other sites More sharing options...
Ex Brummie Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, Mike the Boilerman said: What a load of borrox. If that's what you think .............. Link to comment Share on other sites More sharing options...
cereal tiller Posted November 24, 2017 Report Share Posted November 24, 2017 3 minutes ago, Ex Brummie said: I might think the same about you. Lack of flow through a pressure jet low water content oil boiler will damage it. Have seen that happen. Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, cereal tiller said: Have seen that happen. I haven't. Link to comment Share on other sites More sharing options...
cereal tiller Posted November 24, 2017 Report Share Posted November 24, 2017 Just now, Mike the Boilerman said: I haven't. You should get out more? 4 minutes ago, Mike the Boilerman said: What a load of borrox. Fernox is better.. Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 Although on reflection, I've never seen a low water content pressure jet boiler. I rather doubt such a thing exists. Link to comment Share on other sites More sharing options...
Ex Brummie Posted November 24, 2017 Report Share Posted November 24, 2017 2 minutes ago, Mike the Boilerman said: Although on reflection, I've never seen a low water content pressure jet boiler. I rather doubt such a thing exists. Webasto's and Mikuni's are pretty well there. Link to comment Share on other sites More sharing options...
MtB Posted November 24, 2017 Report Share Posted November 24, 2017 2 minutes ago, Ex Brummie said: Webasto's and Mikuni's are pretty well there. They are not pressure jet, silly! Link to comment Share on other sites More sharing options...
