Electroquest 30 Amp Charger difficulties - Maximum Battery Bank Size?
22 minutes ago, WotEver said:
Which is kinda the point. As an extreme example if you had a charger of only 1% of the bank capacity (and no loads) the time taken to stabilise would be zero seconds, but all of your charging would be in Bulk.
Unfortunately this is symptomatic of Victron’s ‘Adaptive Charging’ feature. It does the exact opposite of what is required.
Actually that was with adaptive charging disabled.  It was set for max 8hr absorption then it would go to float (26.8v) and from then on it wold take a minimum of 24hrs to stabilise.
Ahh, okay :)
Probably way too short at 8hr Absorption
20 minutes ago, nb Innisfree said:
I used to wonder how long it would take to stabilise if on permanent absorption but was a bit wary, worried they might dry out.
A lot less time ;)
As to how long, that’s difficult to guess. However, if on shore-line for extended periods then it’s a lot better for the Batteries to get up there gently on float.
ETA I have no idea why my phone occasionally capitalises Batteries
11 minutes ago, WotEver said:
A lot less time ;)
Yes low and slow. Gibbo reckoned our batteries were down to 45% capacity but after several prolonged charges over a few months at a higher voltage they seemed to make a complete recovery, whether that would have happened on shorter absorption ones I have no idea.
Capitalised because Batteries are very important to boaters.
Edited by nb Innisfree
Also I couldn't get any improvement with equalisation charges, gave up after several.
9 hours ago, Mike the Boilerman said:
I too find the tail current never stabilises. I've spent a whole day charging and checking every 45 mins. It's always a little bit lower each time I look.
Yeah but you're another one with knackered (sulphated) batts.
And, hate to say it but they got knackered largely because you were NOT monitoring tail current, but relying on some shiny box that was telling fibs. :unsure:
Oh yeah, the SmartGauge!
But more seriously, why would a half-sulphated battery three months old behave differently from a battery half the capacity in the first place?
I think the main takeaway there is to carefully check any newly supplied batts where possible. Terminal voltage, SG check, acid levels (note carefully for future), discharge check, the more the better.
If this all sounds a bit onerous, then I'd have to say the 24/365 provision of decent amounts of guaranteed off grid power, from batts instead of a spinning engine, is just not a "no brainer" unfortunately, it needs "something"... :unsure:
Having said that, for 95% of boaters who don't need that, their interests would best be probably best be served by getting decent brand leisure batts. :)
(Not saying that life will be perfect for that 95%, but that the above brief advice can't really be improved in any way - except to say if possible, get the batts from a decent supplier, baby them initially, then monitor carefully for any drop in performance...)
Edited by smileypete
11 hours ago, nb Innisfree said:
Yes, because I initially thought they were the older type AGMs I charged at 14.2v, realising they were later type I increased to 14.4-6v, that together with several long raised absorption charges recovered them, they lasted another few years.
Didn't have the bottle to go to 14.8v even though Multicell recommended that.
Is that the manufacturers recommended charge voltage for your batts?
What was the manufacturers recommended 'EQ voltage' if any? Were you using that voltage?
The charge and discharge curves are completely different. That’s why Gibbo always said that all bets were off with SmartGauge and Batteries at less than 50% remaining capacity. It simply couldn’t accurately track them.
As to WHY the curves are different, that’s down to the black magic that goes on inside a lead-acid battery ;)
Oh look, it capitalised Batteries again. It must think they’re awfully important.
Were you using the recommended voltage to equalise?
On 31/10/2017 at 12:05, smileypete said:
Echo?
Heeelloooooooo! :)
Curiously, Mr Innisfree last logged in on 21 Oct according to his profile, yet his last post on here was a little over two hours ago.
Another 'site improvement' by InVision perhaps?
No, he’s signing in invisibly. It’s an option. Obviously his posts won’t be invisible though ;)
No, I meant Tony/Wotever asked exactly the same question as I did an hour before the post right above. :) See post 60/61.
Perhaps he's a Time Lord? :P
See the bottom left button?
No idea, just used Victron EQ mode, 16v? (32v in my case) can't remember, long time ago now. Multicell the suppliers said use 14.8v normal charge to recover them.
I'm the invisible man.
Yes, Tony B had a falling out with them over this. They sell these batteries for boaters then state “charge at 14.8V”. How?
Ah, OK, so it sounds like Multicell gave good advice, it just took a loooong time to recover capacity.
ISTR reading somewhere that such charges are often known as 'passive equalization', some googling brought up:
http://www.theequalizer-bacs.com/files/117265231.pdf
So where the cells are highly imbalanced, the relatively low gassing rate means they take far longer to even out. :)
Seems eminently sensible to me, better than trying to pretend they can be charged at 14.4V, which some suppliers seem to do.
It's up to the boater to check suitability, eg a 2hp outboard can't push a narrowboat against a strong Thames stream, is it therefore 'not for boaters'?
That marine chargers have been sold with different voltage settings for many years suggests there's no standard charging voltage for batteries on boats, not sure why Tony thinks there should be otherwise...
I would like to emphasize for anybody just browsing this thread that to use an SG effectively it is essential to read the supplied installation manual thoroughly from cover to cover. It is very detailed in its description of what it can and can't do and when.
Which alternators charge at 14.8V then?
How many marine chargers charge at 14.8V?
If you buy those Multicell Batteries you will probably have to replace your existing charger and will also have to invest in an alternator controller. So doubling the cost of the Batteries.
Do you really believe that the average boater will appreciate those facts when looking at a ‘better-than-el-cheapo’ battery?
Indeed :)
Everything that’s been said here (plus a lot more) is all in the extensive manual.
Lord knows! Do I want to spend my time finding out? I think not! :D
My latest take is that 95% of boaters would be best off with decent brand leisure batts (aka reasonable 'el cheapos'). Why? Because they're not terribly interested in batts, and I can't say I blame them.
The other 5% who have do a genuine long term interest probably already know what batts suit them best.
So should people without a genuine interest in batts buy Trojans or AGMs? No and no, in my mind. A third way might be to employ a marine electrical specialist to use their expertise to make the best choices.
Sure there are people who want oodles of off grid inverter power 24/365 but aren't interested in it that much, or spending on someone who does. I think there's just not an easy answer there...
Am I being a bit harsh? Probably. But if someone's got a better answer then I'm all ears. :)
