gavanic isolating transformer
You only need them for when you are plugged into shore power. If you are planning to do that for long periods, they are a good idea. If not, no point.
There are pros and cons for GI and ITs. ITs are better in some ways but also more expensive. Again, if you are only going to be on shore power from time to time I would go for a GI. If you are going to be on shore power most of the time, maybe the investment of an IT is worth it.
Edited by nicknorman
Isolating Transformers are much better that Galvanic Isolation, no contest really with reliability and peace of mind.
You can get cheap ones if you know what to ask for and where to look, by cheap i mean a proper price rather than an inflated price for something used on a boat.
Start looking for a 240 to 240 site transformer. They are blue in colour not yellow like all the 110v ones. But you are still going to have to isolate the earth on the boat, make shure its not connected to the earth on the shoreline.
Heres some info
http://www.bcet.co.uk/marine-isolation-transformers.html
Why would you need 10kva that would power a small cruise ship !!!
3600va is plenty http://www.airlinktransformers.com/boating_transformers/
Sorry for thread hijack.....
Going to wire boat for 32A supply. Will be using 2.35 kw oven, in addition to perhaps 2 kW of electric heaters, underfloor heating, fridge/freezer.
Just noticed on airlink they have other 10kVA isolating transformers (non 'boaty') with the same IP rating....
boating one im looking at: http://www.airlinktransformers.com/boating_transformers/BT10230/
industrial one http://www.airlinktransformers.com/industrial_transformers/enclosed_isolating_industrial_transformers/WN10014/
7kva one: http://www.airlinktransformers.com/industrial_transformers/enclosed_isolating_industrial_transformers/WM7501/
Would prefer to stay at 10KVa as it means if it is under a 32A load, its not running at full whack, and will hopefully last a bit longer.
Can anyone tell me the difference between the boating one and the industrial one?
Ray those seem to be galvanic isolators?
Edited by clbrof
I've just purchased one of the Airlink 3600VA 230 - 230V isolating transformers, not yet plugged in, but opted for the yellow resin cased one rather than the wall mounted one.
Worth a note however, Airlinks prices are plus VAT, so the one i bought, listed at £250 eventually was much more.
However, buy it through Amazon, and it's £250 inc. VAT!!
Regards
Dan
You will need a 3.6 kVA (rating of power, power triangle blah blah long winded stuff) in order to have an output of 16A
edit: 3.6kva not 3 kva, thanks nick, I shouldn't be on forum and do uni work at same time.....
Edited by clbrof
So the 3600kva is the one then and at £250 not a bad price unless anyone knows of one cheaper of course.
Neil
Sorry to be a pedant...but
3.6kVa is what you need...3600kVa is a bit overkill!
I knew what you meant but just to be sure?
Cheers
Gareth
