Tom and Bex Posted April 1, 2014 Report Share Posted April 1, 2014 Thinking of fitting an oil pressure gauge for my Lister ha3 to the pigeon box so I can keep an eye on the engine when cruising. What would people recommend, electrical or mechanical and what range should I be looking for? I guess the ha3 oil pressure is not that high. Also any tips on installing it and any recommendations for gauges (preferably traditional looking) would be welcome. Thanks Tom Link to comment Share on other sites More sharing options...
David Mack Posted April 1, 2014 Report Share Posted April 1, 2014 Ebay is a good source of cheapish brass pressure gauges. Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 1, 2014 Report Share Posted April 1, 2014 Would the oil from a Lister get that high, 70in. Link to comment Share on other sites More sharing options...
furnessvale Posted April 2, 2014 Report Share Posted April 2, 2014 Would the oil from a Lister get that high, 70in. I have a 35lb Gardner with two gauges, one on the engine the other on the roof. Assuming both gauges are accurate, I lose 3lbs in the rise to the roof. HTH By the way, I would mount the gauge behind the pigeon box, not on it, to give it a bit of protection. George ex nb Alton retired Link to comment Share on other sites More sharing options...
frangar Posted April 2, 2014 Report Share Posted April 2, 2014 I once knew someone who had a mech pressure gauge mounted on the pigeon box with a marine JP.....let's just say having a few gallons of oil come out of a fractured feed pipe to the gauge makes a bit of a mess in the engine room.... Much as I like traditional stuff I think I would go for an electric gauge if it's mounted away from the engine....you can always run the cable through a cooper pipe to keep the vintage look. Cheers Gareth Link to comment Share on other sites More sharing options...
by'eck Posted April 2, 2014 Report Share Posted April 2, 2014 I got my roof top one with custom dial from S.M. Gauge Co. Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 3, 2014 Report Share Posted April 3, 2014 Thinking of fitting an oil pressure gauge for my Lister ha3 to the pigeon box so I can keep an eye on the engine when cruising. What would people recommend, electrical or mechanical and what range should I be looking for? I guess the ha3 oil pressure is not that high. Also any tips on installing it and any recommendations for gauges (preferably traditional looking) would be welcome. Thanks Tom So what is the hot oil pressure of a HA3 ? Link to comment Share on other sites More sharing options...
mark99 Posted April 3, 2014 Report Share Posted April 3, 2014 (edited) So what is the hot oil pressure of a HA3 ? If you get a bourdon type gauge, it's best to get one that sits about 2/3 to 3/4 max gauge deflection. In other words, say your oil pressure should be 45 PSIG, get a gauge that does to 60 PSIG (not 50 or 100 PSIG). Here's mine - engine pressure (45psig) and gearbox oil pressure (circa 320 psig). Edited April 3, 2014 by mark99 Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 3, 2014 Report Share Posted April 3, 2014 If you get a bourdon type gauge, it's best to get one that sits about 2/3 to 3/4 max gauge deflection. In other words, say your oil pressure should be 45 PSIG, get a gauge that does to 60 PSIG (not 50 or 100 PSIG). Here's mine - engine pressure (45psig) and gearbox oil pressure (circa 320 psig). By the look of those readings you have a problem Link to comment Share on other sites More sharing options...
ChimneyChain Posted April 3, 2014 Report Share Posted April 3, 2014 To be fair they look very very nice and its a credit to you but they are pretty pointless when out on the boat, the time you realise you've got a problem you've seized your engine. Darren Link to comment Share on other sites More sharing options...
mark99 Posted April 3, 2014 Report Share Posted April 3, 2014 (edited) Well there's one (engine oil pressure) on the roof too Darren. I have to start the engine in the engine room and if you know Gardners, they take a little while to pressurise so I can await the pressure rise without having to go outside to look. Yes it's bling too There are no problems DC with the readings - as I explained to you last time you said something similar. If you have forgotton, the engine pressure gauge does not zero but I've rigged to it be accurate in the range (30 - 50 PSIG) it needs to be by repeat testing with a pressure test rig and altering the adjustment levers to suit. Edited April 3, 2014 by mark99 Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 3, 2014 Report Share Posted April 3, 2014 Well there's one on the roof too Darren. Yes it's bling There are no problems DC - as I explained to you last time you said something similar. It does look nice Link to comment Share on other sites More sharing options...
ChimneyChain Posted April 3, 2014 Report Share Posted April 3, 2014 Your boat looks and sounds bloody lovely, wasn't trying to be negative mark sorry. Daren Link to comment Share on other sites More sharing options...
mark99 Posted April 3, 2014 Report Share Posted April 3, 2014 Your boat looks and sounds bloody lovely, wasn't trying to be negative mark sorry. Daren Hey, I never took anything as negative I have a weakness for brass. It's a pain to clean. Link to comment Share on other sites More sharing options...
ChimneyChain Posted April 3, 2014 Report Share Posted April 3, 2014 You and me both, next time your in Uxbridge I'll buy you a pint. Darren Link to comment Share on other sites More sharing options...
Tom and Bex Posted April 3, 2014 Author Report Share Posted April 3, 2014 Thanks. I'll keep a look out on eBay for a nice looking gauge. Still not sure what oil pressure to expect though for an HA3? Link to comment Share on other sites More sharing options...
kevinl Posted April 4, 2014 Report Share Posted April 4, 2014 If there's no low oil pressure warning like a buzzer then definitely fit a warning of some sort for oil pressure but if you just want to monitor everything all the time then where do you stop? A big plastic fertiliser bag approaching your propeller warning would be nice. You can't monitor all of life's problems away, can't remember the last time I drove a car with an oil pressure gauge! K Link to comment Share on other sites More sharing options...
Tom and Bex Posted April 4, 2014 Author Report Share Posted April 4, 2014 There's an oil warning light and buzzer in the engine room but not much use when steering. Don't think I'd hear the buzzer above the noise of the lister so don't even know why it's installed! Link to comment Share on other sites More sharing options...
ditchcrawler Posted April 4, 2014 Report Share Posted April 4, 2014 Put a second buzzer back near the steering position. Link to comment Share on other sites More sharing options...
by'eck Posted April 5, 2014 Report Share Posted April 5, 2014 I have a 35lb Gardner with two gauges, one on the engine the other on the roof. Assuming both gauges are accurate, I lose 3lbs in the rise to the roof. HTH By the way, I would mount the gauge behind the pigeon box, not on it, to give it a bit of protection. George ex nb Alton retired That's how mine is mounted. Interesting point regarding the difference in displayed pressure although my roof one consistently reads only 1 psi less. Since oil is incompressible would it be caused by a greater volume of air trapped in the pipe of the roof one, which is tee'd off the one on the engine room bulkhead. Link to comment Share on other sites More sharing options...
mark99 Posted April 5, 2014 Report Share Posted April 5, 2014 (edited) That's how mine is mounted. Interesting point regarding the difference in displayed pressure although my roof one consistently reads only 1 psi less. Since oil is incompressible would it be caused by a greater volume of air trapped in the pipe of the roof one, which is tee'd off the one on the engine room bulkhead. It's the weight of the oil head - if you have 27 inches height of water that's 1psig. Ok oil is less dense than water so let's say 30". So every 30" of height you extend vertically, you lose a PSIG. Or put another way, it's another 1 psig pushing back down from top of roof down to engine. If your oil pressure is taken at sump level, you could have 60" difference between sump and roof = 2 psig loss. If the fluid you were measuring was lighter than air gas rather than oil, you actually gain gauge pressure with altitude increase. Edited April 5, 2014 by mark99 Link to comment Share on other sites More sharing options...
by'eck Posted April 5, 2014 Report Share Posted April 5, 2014 It's the weight of the oil head - if you have 27 inches height of water that's 1psig. Ok oil is less dense than water so let's say 30". So every 30" of height you extend vertically, you lose a PSIG. Or put another way, it's another 1 psig pushing back down from top of roof down to engine. If your oil pressure is taken at sump level, you could have 60" difference between sump and roof = 2 psig loss. If the fluid you were measuring was lighter than air gas rather than oil, you actually gain gauge pressure with altitude increase. Thanks for that. George (furnessvale) must have a very tall boat then Link to comment Share on other sites More sharing options...
furnessvale Posted April 6, 2014 Report Share Posted April 6, 2014 Thanks for that. George (furnessvale) must have a very tall boat then No, but my oil gauge is on a 6ft high stalk. Seriously, the top gauge, or indeed the bottom gauge, may be a couple of lbs out, but in 35 it hardly matters. George ex nb Alton retired Link to comment Share on other sites More sharing options...
