Monkey 1 Posted April 25, 2012 Report Share Posted April 25, 2012 The shower room is almost finished on our boat now so It's time to decide what shower fittings to use. This is completely new to me so I'm lost! Are there any you would recommend for a narrowboat? I'm guessing a household shower wouldn't be very powerful on a boat as the water pressure won't be as high, am I right to think that? 1 Link to comment Share on other sites More sharing options...
RLWP Posted April 25, 2012 Report Share Posted April 25, 2012 Our current shower is a cheapo one from B&Q and works fine. Mind you, we have two pumps, one for hot water, one for cold so flow is rarely a problem Richard Link to comment Share on other sites More sharing options...
Keeping Up Posted April 25, 2012 Report Share Posted April 25, 2012 Our current shower is a cheapo one from B&Q and works fine. We have just one pump and flow is rarely a problem Link to comment Share on other sites More sharing options...
GSer Posted April 25, 2012 Report Share Posted April 25, 2012 (edited) I used a household one, the cheap(ish)'ceramic seals' type from B&Q, my pump does both hot and cold but it's a nice enough shower. I used a separate pump for the bathroom to prevent any filling up the kettle in the galley/scalding in the shower episodes. Edited April 25, 2012 by GSer Link to comment Share on other sites More sharing options...
Guest Posted April 25, 2012 Report Share Posted April 25, 2012 The shower room is almost finished on our boat now so It's time to decide what shower fittings to use. This is completely new to me so I'm lost! Are there any you would recommend for a narrowboat? I'm guessing a household shower wouldn't be very powerful on a boat as the water pressure won't be as high, am I right to think that? Ours looks like ones we have had in caravans before, in fact ours needs changing (broken wall clip) and this was what I was going to get. We have no problems with flow or pressure. It's supplied by two Shurflo pumps. (Though seeing the posts above I may go the B&Q route too.) Link to comment Share on other sites More sharing options...
Monkey 1 Posted April 25, 2012 Author Report Share Posted April 25, 2012 That's great thank you! Makes life easyer So just a standard mixer like this should do the job? I guess if the shower does turn out to be a bit weak, a new head with smaller/less holes would help perhaps. Or a better water pump. Link to comment Share on other sites More sharing options...
GSer Posted April 25, 2012 Report Share Posted April 25, 2012 Yes, i've seen that type used in a fair few hire boat installations so i'd guess they are reliable or easy to fix if broken. Link to comment Share on other sites More sharing options...
Barry Posted April 25, 2012 Report Share Posted April 25, 2012 Be careful what you buy Some shower mixers are designed for the lower pressures found in gravity fed systems in houses - others are designed to be used with the higher pressures in a pumped system Oh and double check when the B&Q guy tells you that what you have selected is the correct one for your needs Don't ask me how I know this.... Link to comment Share on other sites More sharing options...
bizzard Posted April 25, 2012 Report Share Posted April 25, 2012 Mines a watering can rose fed from a Paloma gas water heater,cheap and excellent. 1 Link to comment Share on other sites More sharing options...
steelaway Posted April 25, 2012 Report Share Posted April 25, 2012 That's great thank you! Makes life easyer So just a standard mixer like this should do the job? I guess if the shower does turn out to be a bit weak, a new head with smaller/less holes would help perhaps. Or a better water pump. Hi I have a similar one on my boat from a single pump. The shower head will be only a few inches above your head because of the hight restrictions and it's more than enough. Remember to take it of in winter, they can freeze and split. Alex Link to comment Share on other sites More sharing options...
Monkey 1 Posted April 25, 2012 Author Report Share Posted April 25, 2012 Thanks for the tip Bazza, I'll watch out for that. Bizzard, I like your style! That arrangement would be more than adequate for me, but my wife? I'm not so sure Steelaway, I'm 6ft so i'll be lucky to get it over my head at all I'll be crouching to wash my hair, what's left of it anyway. My wife is small so she will be ok. Link to comment Share on other sites More sharing options...
bizzard Posted April 25, 2012 Report Share Posted April 25, 2012 Thanks for the tip Bazza, I'll watch out for that. Bizzard, I like your style! That arrangement would be more than adequate for me, but my wife? I'm not so sure Steelaway, I'm 6ft so i'll be lucky to get it over my head at all I'll be crouching to wash my hair, what's left of it anyway. My wife is small so she will be ok. If let into the ceiling with a nice posh bezzel surround they look like a big LED light. Link to comment Share on other sites More sharing options...
system 4-50 Posted April 25, 2012 Report Share Posted April 25, 2012 Is there a mixer that is good at being drained down without having to remove it? Link to comment Share on other sites More sharing options...
Dekazer Posted April 25, 2012 Report Share Posted April 25, 2012 We bought a completely normal one from B&Q, which works very well with our 1 pump plus accumulator set up. Seriously though, how expensive are taps?! I almost wept when I saw the prices Link to comment Share on other sites More sharing options...
bizzard Posted April 25, 2012 Report Share Posted April 25, 2012 We bought a completely normal one from B&Q, which works very well with our 1 pump plus accumulator set up. Seriously though, how expensive are taps?! I almost wept when I saw the prices I use just one standard steam or water red wheeled gate valve,about £4 i think it was. Link to comment Share on other sites More sharing options...
Robbo Posted April 25, 2012 Report Share Posted April 25, 2012 Are there any you would recommend for a narrowboat? I'm guessing a household shower wouldn't be very powerful on a boat as the water pressure won't be as high, am I right to think that? You'll have a power shower on the boat so it will be better than most home showers! Check your pump it will say how many litres a minute it can do, most shower heads will be around 10. Link to comment Share on other sites More sharing options...
dor Posted April 25, 2012 Report Share Posted April 25, 2012 Our current shower is a cheapo one from B&Q and works fine. Mind you, we have two pumps, one for hot water, one for cold so flow is rarely a problem My mixer was a basic thermostatic one from Wickes. Screwfix do similar thermostatic mixers for around £30. I initially had two pumps with separate circuits for hot & cold. Problem was the thermostat couldn't react fast enough when one or the other pumps cut in. I have now linked the two sides and just use one pump (ParMax 2.9) and it is more than adequate. Some shower mixers are designed for the lower pressures found in gravity fed systems in houses - others are designed to be used with the higher pressures in a pumped system Although the system is pumped on a boat, I would still go for the gravity-fed lower pressure mixer not the high pressure ones as these are designed to operate on mains pressure (with a combi) which is normally much higher than boat water pump pressure. Link to comment Share on other sites More sharing options...
steelaway Posted April 25, 2012 Report Share Posted April 25, 2012 Is there a mixer that is good at being drained down without having to remove it? I think the design of these mixer bars stops them emptying even when you take of the shower hose. I know mine is always still full of water when I take it of. Alex Link to comment Share on other sites More sharing options...
Monkey 1 Posted April 25, 2012 Author Report Share Posted April 25, 2012 Although the system is pumped on a boat, I would still go for the gravity-fed lower pressure mixer not the high pressure ones as these are designed to operate on mains pressure (with a combi) which is normally much higher than boat water pump pressure. This was my concern, I wasn't aware of gravity fed mixers, assuming all mixers had to be fitted with a combi boiler. You learn something every day Link to comment Share on other sites More sharing options...
Barry Posted April 25, 2012 Report Share Posted April 25, 2012 Although the system is pumped on a boat, I would still go for the gravity-fed lower pressure mixer not the high pressure ones as these are designed to operate on mains pressure (with a combi) which is normally much higher than boat water pump pressure. Good point well made Link to comment Share on other sites More sharing options...
Bimbly1 Posted April 25, 2012 Report Share Posted April 25, 2012 If you install a bar thermostatic shower, be aware that this type don't withstand prolonged freezing conditions. I have had two where the hot side inlet valve has stuck in the closed position. Once I managed to fix it with gentle persuasion; on the next occasion, (winter 20120/11), my powers of persuasion broke it for good. That said, the one I have at the moment was fine over this winter, with a little heater on during the cold spells. You may remove it as part of your winterisation process if you don't live aboard. To save water you may want to try installing a Venturi shower head handset. I have heard mixed reports, so depends on your pump setup I suspect. Where they work well, water consumption is considerably reduced. Good luck. Bob. Link to comment Share on other sites More sharing options...
smileypete Posted April 26, 2012 Report Share Posted April 26, 2012 (edited) I think the design of these mixer bars stops them emptying even when you take of the shower hose. I know mine is always still full of water when I take it of. They have internal non return valves on the H+C inlets. I'd expect if some NRVs and drain valves (washing machine taps?) are put in the pipework further back the internal ones could be removed. Anyway the bar mixers are dead easy to remove for winterising. cheers, Pete. Edited April 26, 2012 by smileypete Link to comment Share on other sites More sharing options...
