Jim Shead's site off air?
churchward
I had similar problems a couple of days ago. Didn't work on Internet Explorer but did on Firefox.
Then it worked on IE, now it isn't again.
I was using Firefox too and doesn't work on IE either.
...and me, using FF
can you supply URL you are using maybe it has changed from what I have?
try opening up a command prompt and typing
ping www.jim-shead.com
If you get a reply you can see the host, so the problem is likely to be browser related.
If you get no reply then try
tracert www.jim-shead.com
and see where it stops, probably your isp if it does not get to webfusion.com
thanks I have tried both but no go. the trace just says "Unable to resolve target system name"
So sounds like you are not getting DNS.
try ping 212.67.210.22, the IP address of www.jim-shead.com
That should work and proves routing is ok.
Now not certain, but the DNS entry for www.jim-shead.com loosk like a dynamic hosting arrangement to me (reverse DNS look up give the host name as supanames-22.supanames.co.uk), so it could be your isp's DNS is messing up.
I get get a response from the IP address.
I guess it is the DNS but I suppose it could be my router?
Odd though I have had the router for a couple of months now and not experienced problems before. I don't know if I have tried Jim Sheads site on it successfully before though. I have certainly been able to access Jim's site through the same ISP in the past.
Just tried it on Chrome, IE, Firefox and Opera and it does not work for me.
I suspect a DNS problem. My ISP is TalkTalk (ex Tiscali).
Jim's Shed, however is working :cheers:
****Edited to add it works ok on my blackberry using Opera Mini which uses a different DNS to my home computer ISP
Edited by Allan(nb Albert)
I am Talk Talk but ex-Pipex. I just tried it on my work Laptop through the same router going through the companies network and it finds Jim shead's site without a problem. So can't be router I guess. It must be the DNS with the ISP.
