13 hours ago, ditchcrawler said:
Is that the one at Tesco
Does the dry dock even exist? I haven't moored outside Bulls Bridge Tescos since 2008 or 2009 but it was well and truly closed then with the entrance covered by a thick concrete wall. Has it reopened? I'm not a facebooker and the other links don't work for me.
Not the same dry dock,the one being discussed is a few metres south of the disused one
At the southern end of Tesco's
That's Matt Miller who runs it. Good guy, glad you've got in contact.
Interesting fact: there's no pumps in the dry dock, it was an old BW maintainence depot. It fills from the canal as you'd expect, but there's a 1' culvert which empties the dock into a largely unmapped underground river which passes under the canal. No one knows where it ends up, but it has got blocked in the past apparently.
It might be routed to the river which flows under the canal just the other side of the main road bridge. .
can't remember the name of it but it is low down. I imagine the original dry dock now defunct probably drained there as well.
River Crane
The dry dock in question is about where the little compass rose is at the bottom right. Its quite a long way to the river Crane but seems a likely drainage route.
I bet it takes a long time to empty then! It's not like emptying a lock.
Many years ago I tried filling up the disused dock at Tesco. I got it about half full before I gave up, filling was very slow. But it emptied very quickly. And it does drain down into be River Crane at the nearby aqueduct. The Crane eventually flows into the Thames at Isleworth.
Yes but to be fair with a dry dock there is no time constraint. The desirable outcome is for it to be draining once empty more quickly than it fills from leakage in the gates or planks.
This is a lot nicer than relying on a pump.
I wonder if the drain gets coconuts in it.
