IanD Posted January 17, 2021 Report Share Posted January 17, 2021 (edited) 18 hours ago, Alan de Enfield said: Presumably it didn't have an egg whisk, it would have had a proper LARGE propeller. Which certainly helps, but can't work miracles --- it still won't have propellor efficiency much above 60% and a (properly sized) egg whisk will be at least 50%, so at best it's equivalent to a 20% more powerful engine. Marine engineering facts which no amount of eulogising about LARGE propellors will change... ? Edited January 17, 2021 by IanD Link to comment Share on other sites More sharing options...
cuthound Posted January 18, 2021 Report Share Posted January 18, 2021 (edited) On 17/01/2021 at 00:17, IanD said: Power is one problem (which is what I was asking about), endurance is the other. Can do at least 3 hours with a 15kW motor.(and 30kWh of batteries and a 7kW genny), but this is where it gets tricky -- a more powerful motor (e.g. 25kW) is great for power, but then the batteries run out after less than 2 hours... The Ribble link is probably the most difficult problem for electric boats to solve... Couldn't the solar panels be rigged as temporary sails...? ???? Edited January 18, 2021 by cuthound To remove a duplicate post Link to comment Share on other sites More sharing options...
Alan de Enfield Posted January 18, 2021 Report Share Posted January 18, 2021 1 hour ago, cuthound said: Couldn't the solar panels be rigged as temporary sails...? ???? Fine as long as you are going downwind. Link to comment Share on other sites More sharing options...
TheBiscuits Posted January 18, 2021 Report Share Posted January 18, 2021 5 hours ago, Alan de Enfield said: What idiot fitted a cratch cover to a surfboard? Link to comment Share on other sites More sharing options...
Popular Post Hudds Lad Posted January 18, 2021 Popular Post Report Share Posted January 18, 2021 11 minutes ago, TheBiscuits said: What idiot fitted a cratch cover to a surfboard? i've seen those, they're Hipster traps you put a piece of homemade bread and a craft ale on the paddle board which will coax any nearby beardy, man-bunned buffoons onto it. then, whilst they endlessly waffle on about the rustic and artisinal nature of the provisions, you quickly loose the ropes and drop the tent thus trapping them. you can then proceed to lightly kill them with a suitable piece of 2x4, or hobnail boots if so attired, before they escape and open a cereal café or vegan microbrewery. jobs a good 'un 1 4 Link to comment Share on other sites More sharing options...
DHutch Posted January 18, 2021 Report Share Posted January 18, 2021 We did it with EmilyAnne, which will usually do just about about 5kn 6mph in open water with the wind behind her, and then made a monumental mess of the firing due mainly to some poor grade and an untested mixed blend of coal. We got down to 1mph over land, creeping up the edge, and having missed the Savick brook window, arrived at Preston well after the deadline and where let in anyway thankfully. The return trip was less dramatic, but at worst case we would have dropped anchor and gone again next tide I guess, we had also asked about where outside Preston was safe to dry out for a tide. The trip back was I am told much less exciting and or badly fired. Daniel Link to comment Share on other sites More sharing options...
Tacet Posted January 19, 2021 Report Share Posted January 19, 2021 10 hours ago, DHutch said: We did it with EmilyAnne, which will usually do just about about 5kn 6mph in open water with the wind behind her, and then made a monumental mess of the firing due mainly to some poor grade and an untested mixed blend of coal. We got down to 1mph over land, creeping up the edge, and having missed the Savick brook window, arrived at Preston well after the deadline and where let in anyway thankfully. A case of underheating on the Ribble Link rather than the more common overheating? Link to comment Share on other sites More sharing options...
DHutch Posted January 19, 2021 Report Share Posted January 19, 2021 4 minutes ago, Tacet said: A case of underheating on the Ribble Link rather than the more common overheating? I guess so! Link to comment Share on other sites More sharing options...
