Joel_C Posted June 23, 2020 Report Share Posted June 23, 2020 Hi all, recently bought a trad stern narrowboat with rotten back boards which need replacements cutting. Going to go for marine ply of the same thickness as the original boards unless anyone on here has a better/ more standard suggestion? 2nd part is just a quick enquiry about the insulation we found under the stern boards over the engine- is this for heat insulation to prevent the boards from engine heat? What would you guys recommend for this sort of insulation? Cheers all Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 23, 2020 Report Share Posted June 23, 2020 Buffalo board - several topics n here about it. I suspect the insulation is to deaden sound so you need proper fire resistant sound deadening foam. Midland Chandlers used to sell it, probably still do. Link to comment Share on other sites More sharing options...
PhilR Posted June 23, 2020 Report Share Posted June 23, 2020 2 minutes ago, Joel_C said: Hi all, recently bought a trad stern narrowboat with rotten back boards which need replacements cutting. Going to go for marine ply of the same thickness as the original boards unless anyone on here has a better/ more standard suggestion? 2nd part is just a quick enquiry about the insulation we found under the stern boards over the engine- is this for heat insulation to prevent the boards from engine heat? What would you guys recommend for this sort of insulation? Cheers all The *insulation* will most likely be sound insulation.. I am due to replace my rotten 40 year old deckboards this week. I will be using WISA hexagrip Link to comment Share on other sites More sharing options...
Joel_C Posted June 23, 2020 Author Report Share Posted June 23, 2020 Thanks both- looking at the other chains RE Buffalo board would you recommend sealing cut edges after getting it to size? Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 23, 2020 Report Share Posted June 23, 2020 Yes, some advocate Endsell, I used Wests epoxy. 1 Link to comment Share on other sites More sharing options...
Bewildered Posted June 23, 2020 Report Share Posted June 23, 2020 Or you can seal the ends with bitumen blacking Link to comment Share on other sites More sharing options...
Nightwatch Posted June 23, 2020 Report Share Posted June 23, 2020 58 minutes ago, PhilR said: The *insulation* will most likely be sound insulation.. I am due to replace my rotten 40 year old deckboards this week. I will be using WISA hexagrip Hexagrip is, in my opinion, a better board. I believe theres a difference in price though. Link to comment Share on other sites More sharing options...
cuthound Posted June 23, 2020 Report Share Posted June 23, 2020 If you look for local van fitting out companies, they often have small offcuts left over, which are big enough to make deckboards from. They will sell these at low prices just to get rid of them. Link to comment Share on other sites More sharing options...
reg Posted June 24, 2020 Report Share Posted June 24, 2020 On 23/06/2020 at 15:03, Tony Brooks said: Buffalo board - several topics n here about it. I suspect the insulation is to deaden sound so you need proper fire resistant sound deadening foam. Midland Chandlers used to sell it, probably still do. I asked Midland Chandlers Braunstone, approx 18 months ago, if they sold it but they didn't however they suggested the yard next door who said they could supply this board. Unfortunately I can't remember the name of the company but I'm sure others on here could supply that info. Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 25, 2020 Report Share Posted June 25, 2020 9 hours ago, reg said: I asked Midland Chandlers Braunstone, approx 18 months ago, if they sold it but they didn't however they suggested the yard next door who said they could supply this board. Unfortunately I can't remember the name of the company but I'm sure others on here could supply that info. Are you talking about the board or the insulation? I bought a sheet of sound insulation from MC a good number of years ago and that is what I was talking about. There are better types of sound insulation than that I bought from MC though. Link to comment Share on other sites More sharing options...
Flyboy Posted June 25, 2020 Report Share Posted June 25, 2020 On 23/06/2020 at 16:03, Nightwatch said: Hexagrip is, in my opinion, a better board. I believe theres a difference in price though. Agreed. 1 Link to comment Share on other sites More sharing options...
Duck-n-Dive Posted June 25, 2020 Report Share Posted June 25, 2020 I have used the sound insulation from Sound Services and can recommend it http://www.soundservice.co.uk Link to comment Share on other sites More sharing options...
reg Posted June 25, 2020 Report Share Posted June 25, 2020 (edited) 8 hours ago, Tony Brooks said: Are you talking about the board or the insulation? I bought a sheet of sound insulation from MC a good number of years ago and that is what I was talking about. There are better types of sound insulation than that I bought from MC though. Sorry I should of made myself clearer I was referring to the board. Should also of made it clearer, because I chose not to pursue it, that I am not sure which brand they sell. Edited June 25, 2020 by reg Link to comment Share on other sites More sharing options...
