Joel_C
    London
  • Boat Name
    Suzanne Melody
Joel_C's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. Hi all, we've been keeping warm through winter but have notice damp patches appearing on the interior fabric wall below our cabin window oon our narrowboat. Having noticed condensation building up around the window frames and being concerned that there might be water leaking through I've recaulked around the frame on the inside, but the patches haven't abated. I've read that if it is a leak through the windows We need to get them reset- is there any way of finding out if this is the case before taking the windows out? Does anyone have experience of similar damp spots and could there be another cause worth ruling out? Thanks all
  2. Hi all, my 60A alternator has given up and I need a replacement/ repair job done. I've tried to take the alternator to car parts dealers recently, but no luck. The serial number on the unit has worn away, but the engine is a Beta four-cylinder keel cooled diesel engine. Any ideas of where to go to get a replacement, or if it can be assessed for repair?
  3. Thanks both- looking at the other chains RE Buffalo board would you recommend sealing cut edges after getting it to size?
  4. Hi all, recently bought a trad stern narrowboat with rotten back boards which need replacements cutting. Going to go for marine ply of the same thickness as the original boards unless anyone on here has a better/ more standard suggestion? 2nd part is just a quick enquiry about the insulation we found under the stern boards over the engine- is this for heat insulation to prevent the boards from engine heat? What would you guys recommend for this sort of insulation? Cheers all
